New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
6.2 f250 6.4 ram 2500 towing with a gasser
by FLORIDA. 03/24/19 05:55 PM
T5 15w40 for my bike?
by Degreaser. 03/24/19 05:47 PM
Studded tires in warm weather
by y_p_w. 03/24/19 05:28 PM
ST 15W40
by mobilaltima. 03/24/19 05:02 PM
I need a filter cutter person
by Marco620. 03/24/19 03:21 PM
VIRGIN BOSCH D+ 3421 CUT OPEN
by 53' Stude. 03/24/19 02:45 PM
My first cut. Donaldson P502503
by BeerCan. 03/24/19 02:25 PM
Sludge and Facebook's infinite wisdom
by RDY4WAR. 03/24/19 02:05 PM
Gear lube 75W90 Synthetic GM# 88900401
by rcbob. 03/24/19 01:47 PM
Rislone Rebates
by Nickdfresh. 03/24/19 01:42 PM
IndyCar Classic at COTA
by bdcardinal. 03/24/19 12:29 PM
STP 500 at Martinsville
by bdcardinal. 03/24/19 12:27 PM
Source For Microfiber Towels
by Wrenchturner44. 03/24/19 12:26 PM
SUPREME C3-X SYNTHETIC 5W-30
by 21Rouge. 03/24/19 12:17 PM
Jcountry, CMichael, dude59, Petrolhead, stp
67608 Registered Users
107 registered members (ArrestMeRedZ, addyguy, 2004tdigls, arowbat, 2002 Maxima SE, 10 invisible), 2,213 guests, and 62 spiders.
Topics286,351
Posts4,906,907
Members67,608
Most Online2,967
Mar 10th, 2019
Page 1 of 5 1 2 5
Distilled vs Purified Drinking Water #4564162
11/04/17 05:57 PM
11/04/17 05:57 PM
D/FW Metroplex
The_Nuke Offline OP
The_Nuke  Offline OP
D/FW Metroplex
I recently drained the radiator in my car and refilled with some 100% HOAT coolant (G-05) and Purified Drinking Water. It didn't occur to me at the time, but what I have used in the past was always Distilled Water (gallon jugs of Walmart's house brand). But it's starting to creep into my head as a possible liability. Anyone ever had issues with using purified drinking water versus the distilled kind?
Maybe I'm making a mountain out of a mole-hill, but my car's engine cooling system is pretty important, given my geographic location and the intense summers I put it through. So if there's going to be a problem later on the down the road from using the purified drinking kind of water, I'd rather just drain the whole system and refill with distilled now while I have the luxury of deciding when/where to do such a task.
2012 Charger Pursuit aka "The Bacon Hauler"
- 5.7L + NAG1 (A5) + 2.62 (215mm)
Re: Distilled vs Purified Drinking Water [Re: The_Nuke] #4564171
11/04/17 06:09 PM
11/04/17 06:09 PM
Great Lakes
Quattro Pete Offline
Great Lakes
'02 530i (Edge 0W-40)
'15 Q5 3.0T (Edge 5W-40)
'18 Charger SRT (PUP 0W-40 SRT)
Re: Distilled vs Purified Drinking Water [Re: The_Nuke] #4564174
11/04/17 06:10 PM
11/04/17 06:10 PM
South Florida
bubbatime Offline
bubbatime  Offline
South Florida
Drinking water has elements in it to make it taste better. Distilled is perfectly clean water.
17 Chrysler Pacifica Edge Syn 5W30
13 Yamaha XT250 Valv MC 10W40
10 Acura TSX 2.4 SuperTech Syn 5W20
06 GMC Sierra SuperTech 10W30
Re: Distilled vs Purified Drinking Water [Re: The_Nuke] #4564183
11/04/17 06:18 PM
11/04/17 06:18 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Distilled water has all the minerals taken out of it. It's the minerals that scale up the inside of radiators.
Re: Distilled vs Purified Drinking Water [Re: The_Nuke] #4564192
11/04/17 06:23 PM
11/04/17 06:23 PM
Where the wind comes sweepin'
Reddy45 Online shocked
Reddy45  Online Shocked
Distilled would be the correct one to use. However, there are some people who insist that Drinking Water is the correct one to use, but they can never provide a scientific answer.
Re: Distilled vs Purified Drinking Water [Re: The_Nuke] #4564207
11/04/17 06:35 PM
11/04/17 06:35 PM
D/FW Metroplex
The_Nuke Offline OP
The_Nuke  Offline OP
D/FW Metroplex
Yes, distilled is always better, I get that. In hindsight, i should have noticed i grabbed the wrong kind, but what's done is done. I was wondering if the purified water, while not as god as distilled, could still be good enough. The answer to that is much more nebulous it seems though, so if I want to err on the side of caution, I'll need to do another drain and fill i guess.
Oh well, at least it's not 125F in the garage like it is during summer. Maybe this D&F will be a little easier to get done without stroking out half-way thru...which remind me, I still need to figure out a way to out an a/c unit in there before next summer. That would make life truly worth living for me!
Thanks for the quick replies,
Nuke
Re: Distilled vs Purified Drinking Water [Re: The_Nuke] #4564211
11/04/17 06:42 PM
11/04/17 06:42 PM
MN
TmanP Offline
TmanP  Offline
MN
Distilled water is optimal but realistically you will likely never see a difference. Distilled water is, in theory, pure H20, while "Drinking water" probably came out of a municipal source, was filtered, and may have had additional minerals added back for taste. Our GMs spec "clean, drinkable water" in the owners' manual for mixing with the full-strength coolant. So you should be fine. I wouldn't worry. Many people just use water out of the hose.
2012 Toyota Camry 2.5 30,000 mi
2015 Chevy Silverado LT Z71 5.3 V8 30,000 mi
2010 Toyota Sienna 3.5 V6 150,000 mi
Re: Distilled vs Purified Drinking Water [Re: The_Nuke] #4564213
11/04/17 06:46 PM
11/04/17 06:46 PM
TX
fields Offline
fields  Offline
TX
Go with it. You will be fine.
Re: Distilled vs Purified Drinking Water [Re: The_Nuke] #4564215
11/04/17 06:49 PM
11/04/17 06:49 PM
Florida
Dumc87 Offline
Dumc87  Offline
Florida
I just went through this yesterday, as distilled water is kind of hard to find locally for some reason. Lots of purified water though. To make the plot even more interesting, a few gallons of purified water had "Purified via deionization and distillation"
So... Perhaps some purified water is even more "pure" than distilled?
16 titanxd
15 journey
'09 Matrix - QS UD 0w20
Re: Distilled vs Purified Drinking Water [Re: The_Nuke] #4564219
11/04/17 06:56 PM
11/04/17 06:56 PM
DFW
DBMaster Offline
DBMaster  Offline
DFW
The "drinking" water is most likely purified via reverse osmosis. I have an R/O system and that's the only water I use for such purposes. The total dissolved solids is VERY low. There is very little added to the drinking water to make it taste less flat. I would not worry about it at all.
Re: Distilled vs Purified Drinking Water [Re: The_Nuke] #4564235
11/04/17 07:16 PM
11/04/17 07:16 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
Even though I have multiple filters and an R.O. unit I still use distilled water to make sure it's as pure as possible or buy the pre-mix stuff if it's a reasonable price.
'18 Dodge Grand Caravan GT - 25k KM - AMSOIL SS 0w20
Fear 20wt oils if you want your engine to last. smirk2
Re: Distilled vs Purified Drinking Water [Re: fields] #4564253
11/04/17 07:35 PM
11/04/17 07:35 PM
D/FW Metroplex
The_Nuke Offline OP
The_Nuke  Offline OP
D/FW Metroplex
You don't happen to work in a shop that sells or services radiators do you??
I'll go ahead and put a mark in the "Leave It" column of the "Change It/Leave It" spreadsheet I've got to tally votes on the topic, but I'm afraid I will need to see some documentation about current employment to make sure you aren't just trying to drum up some future business laugh
Re: Distilled vs Purified Drinking Water [Re: DBMaster] #4564256
11/04/17 07:38 PM
11/04/17 07:38 PM
D/FW Metroplex
The_Nuke Offline OP
The_Nuke  Offline OP
D/FW Metroplex
It could be, but given that I did not buy the premium brand or anything, I would not be surprised if it was actually one of those deals where they just pay some city for their municipal water and resell it without doing anything to it one way or the other. That would be the worst case scenario, sure, but luckily I will not have to worry about it and can actually rest easy now (see next post).
Re: Distilled vs Purified Drinking Water [Re: The_Nuke] #4564258
11/04/17 07:45 PM
11/04/17 07:45 PM
'murica
Ethan1 Offline
Ethan1  Offline
'murica
Most people don't even change their coolant until something fails in their cooling system. We all need to remember that by simply changing our coolant, we're probably in the top 5-10% of car owners in terms of maintenance.
The same thing applies when have thread after thread full of hand-wringing over when to change our gear oil. Most vehicles probably go to the junkyard with the original gear oil.
Re: Distilled vs Purified Drinking Water [Re: The_Nuke] #4564267
11/04/17 07:52 PM
11/04/17 07:52 PM
DFW
DBMaster Offline
DBMaster  Offline
DFW
I would be EXTREMELY surprised if the water was not ultra filtered or treated with reverse osmosis. I think far too much emphasis has been placed on the water used to mix coolant.
Page 1 of 5 1 2 5
