Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
114 registered members (ArrestMeRedZ, 2012AccentSE, Arminius, albenjoseph, 55Test, addyguy, 14 invisible), 2,024 guests, and 63 spiders.
Topics286,147
Posts4,903,006
Members67,565
Most Online2,967
Mar 10th, 2019
Need to replace oil pan in the odyessy, which? #4564017
11/04/17 02:56 PM
11/04/17 02:56 PM
DFW
Timo325 Offline OP
Timo325  Offline OP
DFW
As the subject line suggests I need to replace the oil pan in the 2011 Odyssey Touring Elite.
Should I go OEM on this or get something like a Dorman 264-380.
I really value your input on this as I'm worried the non-OEM will not hold up or fit right.
Anyone have experience with this?
Thank You!
2011 Odyssey Touring Elite 80k mi. M1 EP, 0W-20, FU
2008 Mustang GT 81k mi. Edge EP (Gold) 5W-20, FU
Re: Need to replace oil pan in the oddyessy, which? [Re: Timo325] #4564021
11/04/17 03:01 PM
11/04/17 03:01 PM
PimTac Offline
PimTac  Offline
I would go with OEM. What happened to the original pan?
Cannot see signatures any longer so it doesn’t matter.
Re: Need to replace oil pan in the oddyessy, which? [Re: Timo325] #4564023
11/04/17 03:02 PM
11/04/17 03:02 PM
Twin Cities MN USA
Inspecktor Offline
Inspecktor  Offline
Twin Cities MN USA
I have a Dorman transmission pan on my Buick, no problems with fit and finish.
2001 Ranger 3.0 168,000 mi
2006 Dakota 4.7 156,000 mi
1986 GL1200A 73,500 mi
2001 Buick LeSabre Limited 292,000 mi
Re: Need to replace oil pan in the oddyessy, which? [Re: Timo325] #4564024
11/04/17 03:03 PM
11/04/17 03:03 PM
DFW
Timo325 Offline OP
Timo325  Offline OP
DFW
Thanks PimTac.
Cracked it putting an aftermarket plug in it. Not a Fumoto.
Re: Need to replace oil pan in the oddyessy, which? [Re: Timo325] #4564028
11/04/17 03:06 PM
11/04/17 03:06 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Dorman is OK for nuts and bolts but I would never (if given the choice) buy a part from them.
Re: Need to replace oil pan in the oddyessy, which? [Re: Timo325] #4564046
11/04/17 03:25 PM
11/04/17 03:25 PM
MN
14Accent Offline
14Accent  Offline
MN
There's nothing wrong with a Dorman pan. Just use good quality sealant. Either "The Right Stuff" or OEM Honda-bond.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: Need to replace oil pan in the oddyessy, which? [Re: Timo325] #4564061
11/04/17 03:44 PM
11/04/17 03:44 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
An OEM oil pan is $80. Go to a dealer and if they wanna charge you full tilt MSRP, tell them you can buy one from a dealer that does online sales for $80; if you can match the price, I'll buy one today.
Me: 13' VW GTI 3 door 6 speed manual
Re: Need to replace oil pan in the oddyessy, which? [Re: Timo325] #4564068
11/04/17 03:50 PM
11/04/17 03:50 PM
WI
HoosierJeeper Offline
WI
I've heard good things about Dorman pans, if there's a huge price difference I'd go dorman.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Need to replace oil pan in the oddyessy, which? [Re: Timo325] #4564132
11/04/17 05:22 PM
11/04/17 05:22 PM
Utah
CKN Online content
CKN  Online Content
Utah
Originally Posted By: Timo325
Thanks PimTac.
You get a pass on BITOG because your not a dealer-otherwise this thread would be 6 pages long about how incompetent someone else is cracking the oil pan.
Re: Need to replace oil pan in the odyessy, which? [Re: Timo325] #4564216
11/04/17 06:50 PM
11/04/17 06:50 PM
DELAWARE
Hootbro Online content
Hootbro  Online Content
DELAWARE
I have used Dorman oil and transmission pans with good results. Only advise is you have the time is fully temp install the pan dry for a day to get and flex memory out of the stamping and the bolt holes to mount up. Doing it with a 15 minute tack cure with RTV already on the pan and getting the holes to align and bolts inserted can be a pain.
2019 Toyota Tacoma 3.5L (MileSyn 0W-20)
2017 Jeep Renegade 2.4L (Idemitsu 0W-20)
Re: Need to replace oil pan in the oddyessy, which? [Re: Inspecktor] #4564248
11/04/17 07:31 PM
11/04/17 07:31 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Maybe their oil pans are OK, but I watched a guy on YouTube installing a Dorman made lower intake manifold on his Buick 3800. The V-angle of the lower intake manifold did not match the cylinder heads. The part did not seal and caused a huge internal leak. Oil pan was full of coolant.
Re: Need to replace oil pan in the oddyessy, which? [Re: Timo325] #4564260
11/04/17 07:46 PM
11/04/17 07:46 PM
USA
slacktide_bitog Online content
slacktide_bitog  Online Content
USA
You could probably get one from the junkyard at a good price. Oil pans don't normally go bad smile
OEM is probably better than Dorman, but I recommend Dorman pans for transmissions that don't have a drain plug because Dorman includes one. If the OEM pan has a drain plug, or for any engine oil pan, get OEM.
Re: Need to replace oil pan in the oddyessy, which? [Re: Timo325] #4564417
11/05/17 12:08 AM
11/05/17 12:08 AM
Maryland USA
rubberchicken Offline
Maryland USA
is the original pan a stamped steel pan, or a cast aluminum pan ? I can see the cast pans being significantly higher priced. I am not suggesting they are interchangeable though.
How good a shape is the Honda ? If its in real good shape and you want to keep it long term, then that might give you more justification for the OEM.
Re: Need to replace oil pan in the oddyessy, which? [Re: Timo325] #4564494
11/05/17 06:59 AM
11/05/17 06:59 AM
Southeastern USA
FowVay Offline
FowVay  Offline
Southeastern USA
It appears to be a cast aluminum pan. The OEM can be had for $80 mail-order (Bernardi or other on-line wholesaler) and RockAuto has a Spectre (the radiator people) version for $53.00.
I have replaced the oil pan on a Toyota Camry and I chose to go OEM. If I were to do it again I'd get the aftermarket pan and save the cost difference. Often the aftermarket will have a drain plug/gasket while the OEM will be only the pan.
For ref: Honda P/N 11200-RN0-A01 or 11200-5MH-A00. I don't know the difference but these are the two part numbers that come up on Honda's parts catalog.
