Will wider rims change off-set?
NY
Put on new wheels for my Outback a few weeks ago. These cars are known to have weak wheel bearings and will get upset if the offset is off.
The factory spec wheels are 225/65/17 on 17x7 rims +55 offset. New wheels are 235/60/18 on 18x8.5 rims +55 offset. The 18s weigh about 10lbs more each.
Wheel diameter is 0.59" and Width is 0.39" bigger than stock. We're talking around 1/2" differences here. Will I need spacers or will this set up be fine in the long run? It doesn't rub at full lock and driveabity is fine. I just want to set things up to run within factory specs since don't want any future repairs due to improper modification.
The factory upgrade option is 18x7.5 with 225/60/18s with the same +55 offset.
If the offset is the same, that's what you want. Both rim flanges are just 3/4 in further away from that measurement, so track width remains the same. Besides, adaptors, and spacers are never a great idea anyway.
What year is your Outback? Outbacks have had a much more robust wheel bearing design than Foresters and Imprezas for a long time now. Unless you are late 90s/early 2000s (I think the design changed around 03-04) you shouldn't have any issues.
It's a 2017. I've never really messed with anything other than factory wheels for my past 3 Subarus but I've always heard about them going bad. And my 2004 Outback had one go bad, but it was a used and I had no clue what caused it.
Why can't people just keep the stock wheels sizes? I never could understand that.
If the offset is the same, but the wheel is 1.5" wider, that means the inside rim of the wheel is 1.5" closer to the inside of the car, and that the centerplane of the wheel is .75" further from the wheel mount flange than with the original wheels. This will put more bending moment on the wheel bearing, and will decrease the effective wheel rate of the suspension. To compensate for the 1.5" wider wheel, the offset should be decreased to 36 mm to restore the original dimension between the wheel centerplane and mounting flange.
That's not correct.
Offset is the difference between the center of the wheel and the actual mounting surface. It is not affected by wheel width. His new wheels have identical offset from the stock ones, and since they are 1.5" wider then that difference is going to be split evenly between the inside and outside, .75" each.
The only thing detrimental to his wheel bearings in this case will be added tire/wheel weight and any increased cornering loads a 'better' tire may allow the car to generate. The tire/wheel centers will be the same.
That's not correct.
Oops, you're right. I forgot the definition of offset while I was typing the note.
If I remember correctly, when you go to a wider wheel, they tend to try to keep the distances the same on the inside - so the offset increases (or decreases if you started off positive) by half the amount of the width change.
Note: I may have the sign wrong on the offset. But both Discount Tire and Tire Rack can set you up with proper fitting wheels - and that's what I would recommend doing.
What?
I thought you said the first thing you did to your Buick was upgrade to those spinny bro wheels?
Well … when I ran 265’s on my Canyon it was pretty limited … then I tried 285’s:
With the width of the rim I couldn't run the factory 225. Even if I ran a stretched tire the rim would still be wider then OE. I could have done a 18x7.5 rim except they were all aftermarket trash lol(didn't like the 18" upgrade wheels). These 18x8.5s came off a STI
I did a quick search on tire rack with a 18X8.5 rim set up on my car and it's showing 45mm-50mm depending on what rim I buy
I'm gonna hope Subaru updated the bearing design(bolt patterns 5x114 and not 5x100 like they used to be). Otherwise I'll throw my factory wheels back on and run the wheels as a winter set up.
