This is the "Blue Grease" I know: General industrial grease designed for applications involving high heat, water, extreme pressure and high loads. Blue Grease HT™ will not separate, soften or run in applications involving heavy loads.
• Resists washout from water or steam
• NLGI Grade 1-1/2 covers applications requiring a NLGI 1 or 2 grease
• Wide temperature range: 13°F to 399°F (–10°C to +224°C)
• Calcium sulfonate complex base
• Dropping point (ASTM D-2265): 550°F (287°C)
• Water washout (ASTM D-1264): 3% loss at 175°F (80°C)
• Four ball wear (ASTM D-2266): 0.45mm scar dia.
• Mobility: 13.6g/minute at 0°F (18°C)
• Timken OK Load (ASTM D-2509): 65 lbs.
• Bearing rust test (ASTM D-1743): Pass
• Applications include outdoor equipment and machinery, bearings, mechanical hoists, water pumps and generators, forklifts, exposed gears and drives, fifth wheel and universal joints
