7.3 powerstroke water pump
by mobilaltima. 12/13/18 07:10 AM
98 Jeep Cherokee, what oil is spec'd?
by otis24. 12/13/18 06:31 AM
fixing LED Christmas lights
by danez_yoda. 12/13/18 06:30 AM
Things are not as they seem to be..
by CourierDriver. 12/13/18 06:09 AM
Oz Ranger Raptor
by Shannow. 12/13/18 05:22 AM
Shop vac recommendations
by dlundblad. 12/13/18 05:06 AM
Internet Network Issues
by ZeeOSix. 12/13/18 04:13 AM
Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Purolator P1 14476 CUT OPEN
by 53' Stude. 12/12/18 06:00 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
91 registered members (aquariuscsm, andyd, Alfred_B, 53' Stude, Astro14, 4WD, 4 invisible), 1,460 guests, and 39 spiders.
Topics295,011
Posts4,925,930
Members66,664
Most Online2,553
Oct 27th, 2018
Will wider rims change off-set? #4563850
11/04/17 10:41 AM
11/04/17 10:41 AM
Central NY/Arkansas
avacado11 Offline OP
Central NY/Arkansas
Put on new wheels for my Outback a few weeks ago. These cars are known to have weak wheel bearings and will get upset if the offset is off.
The factory spec wheels are 225/65/17 on 17x7 rims +55 offset. New wheels are 235/60/18 on 18x8.5 rims +55 offset. The 18s weigh about 10lbs more each.
Wheel diameter is 0.59" and Width is 0.39" bigger than stock. We're talking around 1/2" differences here. Will I need spacers or will this set up be fine in the long run? It doesn't rub at full lock and driveabity is fine. I just want to set things up to run within factory specs since don't want any future repairs due to improper modification.
The factory upgrade option is 18x7.5 with 225/60/18s with the same +55 offset.
2017 Subaru Outback - 0w20 FS - Falken ziex s/tz05
2014 Lexus IS250 - 0w20 FS - Conti Extreme DWS
2014 BMW i3 - Bridgestone Ecopia
Re: Will wider rims change off-set? [Re: avacado11] #4563891
11/04/17 11:23 AM
11/04/17 11:23 AM
America's Dairyland
LotI Offline
LotI  Offline
America's Dairyland
03 Honda Interceptor
11 Kawasaki KLR 650
12 Ford E450
17 VW GTI
[IMG]http://badges.fuelly.com/images/sig-us/803455.png[/IMG]
Re: Will wider rims change off-set? [Re: avacado11] #4563896
11/04/17 11:35 AM
11/04/17 11:35 AM
iowa
Traction Offline
Traction  Offline
iowa
If the offset is the same, that's what you want. Both rim flanges are just 3/4 in further away from that measurement, so track width remains the same. Besides, adaptors, and spacers are never a great idea anyway.
Certified Tire Service Instructor since 2009
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: Will wider rims change off-set? [Re: avacado11] #4563900
11/04/17 11:37 AM
11/04/17 11:37 AM
The land of USA-made Subies!
SubieRubyRoo Offline
What year is your Outback? Outbacks have had a much more robust wheel bearing design than Foresters and Imprezas for a long time now. Unless you are late 90s/early 2000s (I think the design changed around 03-04) you shouldn't have any issues.
Re: Will wider rims change off-set? [Re: SubieRubyRoo] #4563910
11/04/17 11:55 AM
11/04/17 11:55 AM
Central NY/Arkansas
Central NY/Arkansas
It's a 2017. I've never really messed with anything other than factory wheels for my past 3 Subarus but I've always heard about them going bad. And my 2004 Outback had one go bad, but it was a used and I had no clue what caused it.
Re: Will wider rims change off-set? [Re: avacado11] #4563926
11/04/17 12:25 PM
11/04/17 12:25 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Why can't people just keep the stock wheels sizes? I never could understand that. crazy
Re: Will wider rims change off-set? [Re: avacado11] #4563945
11/04/17 12:38 PM
11/04/17 12:38 PM
Idaho
CT8 Online content
CT8  Online Content
Idaho
Yes, just bigger tires add load on the bearings.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: Will wider rims change off-set? [Re: avacado11] #4563970
11/04/17 01:08 PM
11/04/17 01:08 PM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
If the offset is the same, but the wheel is 1.5" wider, that means the inside rim of the wheel is 1.5" closer to the inside of the car, and that the centerplane of the wheel is .75" further from the wheel mount flange than with the original wheels. This will put more bending moment on the wheel bearing, and will decrease the effective wheel rate of the suspension. To compensate for the 1.5" wider wheel, the offset should be decreased to 36 mm to restore the original dimension between the wheel centerplane and mounting flange.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
Re: Will wider rims change off-set? [Re: avacado11] #4563992
11/04/17 01:25 PM
11/04/17 01:25 PM
Occupied Virginia
Bottom_Feeder Offline
Occupied Virginia
That's not correct.
Offset is the difference between the center of the wheel and the actual mounting surface. It is not affected by wheel width. His new wheels have identical offset from the stock ones, and since they are 1.5" wider then that difference is going to be split evenly between the inside and outside, .75" each.
The only thing detrimental to his wheel bearings in this case will be added tire/wheel weight and any increased cornering loads a 'better' tire may allow the car to generate. The tire/wheel centers will be the same.
Re: Will wider rims change off-set? [Re: Bottom_Feeder] #4563999
11/04/17 01:36 PM
11/04/17 01:36 PM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
That's not correct.
Oops, you're right. I forgot the definition of offset while I was typing the note.
Re: Will wider rims change off-set? [Re: avacado11] #4564535
11/05/17 07:00 AM
11/05/17 07:00 AM
Somewhere in the US
CapriRacer Offline
CapriRacer  Offline
Somewhere in the US
If I remember correctly, when you go to a wider wheel, they tend to try to keep the distances the same on the inside - so the offset increases (or decreases if you started off positive) by half the amount of the width change.
Note: I may have the sign wrong on the offset. But both Discount Tire and Tire Rack can set you up with proper fitting wheels - and that's what I would recommend doing.
CapriRacer
Visit my web site: www.BarrysTireTech.com
Re: Will wider rims change off-set? [Re: Merkava_4] #4564844
11/05/17 12:32 PM
11/05/17 12:32 PM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
What?
I thought you said the first thing you did to your Buick was upgrade to those spinny bro wheels?
03 Jeep WJ 4.0 202k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: Will wider rims change off-set? [Re: Merkava_4] #4564861
11/05/17 12:50 PM
11/05/17 12:50 PM
Texas & Global
4WD Online confused
4WD  Online Confused
Texas & Global
Well when I ran 265s on my Canyon it was pretty limited then I tried 285s:
2018 Chevy 1500 Z71 4WD
2017 Chevy Tahoe LT 4WD
2014 Fusion Hybrid Titanium
2013 Cruze LTZ - RS Turbo
Re: Will wider rims change off-set? [Re: Merkava_4] #4578771
11/19/17 09:39 AM
11/19/17 09:39 AM
Central NY/Arkansas
Central NY/Arkansas
With the width of the rim I couldn't run the factory 225. Even if I ran a stretched tire the rim would still be wider then OE. I could have done a 18x7.5 rim except they were all aftermarket trash lol(didn't like the 18" upgrade wheels). These 18x8.5s came off a STI
Re: Will wider rims change off-set? [Re: CapriRacer] #4578786
11/19/17 09:49 AM
11/19/17 09:49 AM
Central NY/Arkansas
Central NY/Arkansas
I did a quick search on tire rack with a 18X8.5 rim set up on my car and it's showing 45mm-50mm depending on what rim I buy frown
I'm gonna hope Subaru updated the bearing design(bolt patterns 5x114 and not 5x100 like they used to be). Otherwise I'll throw my factory wheels back on and run the wheels as a winter set up.
