Pennzoil Platinum 5w30 vs 10w30
by Snagglefoot
06/24/18 09:09 AM
LM MoS2. Honest, if not appropriately tested?
by wemay
06/24/18 09:03 AM
Brisket flat on charcoal
by 04SE
06/24/18 08:45 AM
Weird Oil level question
by audia6
06/24/18 08:27 AM
DNA test and opening a can of worms
by WhyMe
06/24/18 08:11 AM
Ghetto testing a wheel speed sensor
by Nayov
06/24/18 06:23 AM
dash cam
by DAC2018
06/24/18 05:08 AM
WoO driver Jason Johnson injured
by bdcardinal
06/24/18 01:08 AM
Plastic burning smell when WOT
by Jaha24k
06/24/18 12:57 AM
Duckham's 15w50 Oil 12 one liter bottles
by Lolvoguy
06/24/18 12:00 AM
Ruger LCP .380
by PW01
06/23/18 11:24 PM
Launching boat with stick shift
by troutfisher
06/23/18 11:22 PM
Free oil
by Spitter
06/23/18 10:53 PM
Porsche Panamera buying advice
by CharlieBauer
06/23/18 10:04 PM
RC cars
by red7404
06/23/18 09:36 PM
Any Good 4K Movies ?
by Warstud
06/23/18 09:06 PM
Gray on Oil Dipstick?
by chinee
06/23/18 08:41 PM
Clear plastic scratch remover?
by Quattro Pete
06/23/18 08:15 PM
Parking wars show.
by Chris142
06/23/18 08:15 PM
set for years
by 93cruiser
06/23/18 08:07 PM
bwechols, bowupid, pod423, lemaitrix, azzid0906
65303 Registered Users
81 registered (87sammy, 04SE, 2015_PSD, 2004tdigls, 9 invisible), 1345 Guests and 46 Spiders online.
65303 Members
67 Forums
285897 Topics
Page 1 of 2 1 2 >
#4563271 - 11/03/17 06:59 PM Which high mileage oil has the most seal swelling?
HKPolice Online   content
Loc: Toronto, Canada
1MZ-FE Camry just started to leak oil from the valve cover which is a common issue. Willing to give HM oil a chance, which brand has the most seal swelling additives? I'm partial to M1 but will buy whatever has the highest chance of stopping the leak.
Thanks for your inputs!
#4563273 - 11/03/17 07:01 PM Re: Which high mileage oil has the most seal swelling? [Re: HKPolice]
LaCocina27 Offline
Loc: America
I always liked Valvoline MaxLife. That's a really spectacular high mileage oil.
#4563283 - 11/03/17 07:05 PM Re: Which high mileage oil has the most seal swelling? [Re: HKPolice]
ammolab Offline
Loc: Ruidoso, NM USA
I have found the HM oils good on tired front or rear main seals...not so good at valve cover gasket leaks.
I change them.
2009 Honda CR-V
2011 BMW R1200R
2005 Kaw Ninja 250
1994 Jeep Wrangler 2.5L
2016 Chevy SS Sport Sedan
#4563284 - 11/03/17 07:06 PM Re: Which high mileage oil has the most seal swelling? [Re: HKPolice]
tig1 Offline
Loc: Illinois
IF your engine is the V6 and it's the back VC then HM oil will not work for you. My grandsons 2002 Camry had to have the VC gasket replaced twice which is a real pain. He tried everything . No dice.
2007 Ford Fusion 227,000 miles
M1 0-20 EP
2017 Ford Fusion 49K
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
#4563287 - 11/03/17 07:09 PM Re: Which high mileage oil has the most seal swelling? [Re: tig1]
LaCocina27 Offline
Loc: America
What about Mobil 1 HM? Will that work?
#4563289 - 11/03/17 07:11 PM Re: Which high mileage oil has the most seal swelling? [Re: HKPolice]
ST2008 Offline
Loc: Canada
If I were you, I would replace the valve cover gasket. It's very easy to replace it and the gasket is very cheap. You can find lot of DYI video in Youtube.
#4563297 - 11/03/17 07:21 PM Re: Which high mileage oil has the most seal swelling? [Re: HKPolice]
Merkava_4 Offline
Loc: Clovis, CA
I don't think the HM seal swellers have any effect on silicone seals. I think they have to be rubber. The auto industry has been slowly moving away from rubber seals.
#4563298 - 11/03/17 07:22 PM Re: Which high mileage oil has the most seal swelling? [Re: HKPolice]
WillsYoda Offline
Loc: MN
I have the same engine. In winter M1 HM 5w30, and in summer Maxlife.
#4563299 - 11/03/17 07:23 PM Re: Which high mileage oil has the most seal swelling? [Re: ST2008]
SilverSnake Offline
Loc: Florida
This ^
2016 Charger, 6.4L-485 HP (PUP 0W-40)
2017 BMW 330i, 2L-248 HP (BMW 0W-20)
2018 Jeep GC, 5.7L-360 HP (PUP 5W-20)
2008 20KW Generac (Amsoil 10W-30/30)
#4563306 - 11/03/17 07:26 PM Re: Which high mileage oil has the most seal swelling? [Re: SilverSnake]
The Critic Offline
Loc: CA
This ^
It is a 4hr job to replace the valve cover gaskets on both banks. The rear valve cover requires removing the manifold and moving the engine wiring harness a bit. Not a easy job by any means.
I still encourage replacing the gaskets. No amount of seal swelling will fix this problem.
2011 Toyota Prius - 168k - ServicePro Dexos 0W-20
2007 Honda Accord 2.4 - 128K - Idemitsu 5W-20
#4563313 - 11/03/17 07:29 PM Re: Which high mileage oil has the most seal swelling? [Re: HKPolice]
Mackelroy Offline
Loc: Florida /Texas
Seal swell agents are 50/50 whether they make the issue worse. Be sure and come back with results
#4563320 - 11/03/17 07:31 PM Re: Which high mileage oil has the most seal swelling? [Re: ST2008]
slacktide_bitog Offline
Loc: USA
Are you kidding? The valve cover gaskets are almost IMPOSSIBLE to replace on the 1MZ and almost any transverse V6 mad LOL crzy no-no trolling liar stooges
If you do replace them, get either Beck/Arnley or Mahle/Victor Reinz. Either brand will be reboxed OEM gaskets. While you're back there, replace the spark plugs and wires. Get NGK wires, and Bosch Platinum Ir Fusion spark plugs. I know a lot of people don't like Bosch, but the 1MZ uses special 2-prong double plugs, and in a transverse V6 with no cutouts for the back plugs without complete disassembly, iridium is a MUST! And the only multi-prong iridium made for the 1MZ is the Bosch Platinum Ir Fusion (it has 4 prongs, which should be fine). Iridium should last at least 100k, whereas platinum is only good for 60k.
#4563331 - 11/03/17 07:44 PM Re: Which high mileage oil has the most seal swelling? [Re: slacktide_bitog]
Mr Nice Offline
Loc: Orlando, FL
Better yet, don't buy a vehicle with that type of engine.
#4563332 - 11/03/17 07:44 PM Re: Which high mileage oil has the most seal swelling? [Re: HKPolice]
buck91 Offline
Loc: West Michigan
Did VC gaskets on a Olds Aurora (transverse V6). Wasn't stupidly easy but wasn't too hard, either. Worst part was sopping up the oil out of the spark plug wells first. Yes, it was leaking that bad.
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
#4563337 - 11/03/17 07:50 PM Re: Which high mileage oil has the most seal swelling? [Re: Merkava_4]
Silk Offline
Loc: New Zealand
If you had rubber oil seals in your engine, the swelling would be impressive. They moved away from leather seals, but there was no rubber seals to move away from.
1987 BMW R65 - Penrite V Twin 20/50
2005 Nissan Expert - Gulf Western 10W-40
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Page 1 of 2 1 2 >
