2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
Mobil 1 Cartridge Filters On Clearance at WM
by IndyFan. 03/25/19 06:19 PM
Ford Unibody Pickup
by SubLGT. 03/25/19 05:52 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
86 registered members (Aichiguy, alphadog, agpatel, AdditiveOCD, 77GrandPrix, 11 invisible), 1,426 guests, and 62 spiders.
Topics286,436
Posts4,908,161
Members67,622
Most Online2,967
Mar 10th, 2019
Dipsticking! #4563256
11/03/17 06:40 PM
11/03/17 06:40 PM
Douglas County, Colorado
bigj_16 Offline OP
bigj_16  Offline OP
We have two F-150 2.7 Ecoboosts. I have been checking the oil extremely often since we bought them. I was sampling the one today, and I checked the oil before started it, after it had been setting all night ( about 33 deg. F.) I have checked it after setting overnight before, but when temps were in the 50's or 60's overnight. I noticed then, as now, there is a huge difference between hot and cold. Even more so today. It is consistently a quart less reading off the dipstick when dead cold compared to 20-30 minutes after shutdown when hot. I think this is probably the biggest disparity I have seen on one of my personal vehicles.
Re: Dipsticking! [Re: bigj_16] #4563259
11/03/17 06:44 PM
11/03/17 06:44 PM
PNW
ZeeOSix Offline
ZeeOSix  Offline
PNW
A whole quart difference due to colder ambient temperature seems extreme. I usually only see ~20% change in oil level between say 60~70 deg F and 190~200 deg F when the oil is hot 20 after shutdown. Wouldn't expect that another 30 degrees colder in ambient temps wouldn't make the level then go down another 80% on the dipstick. Maybe it's only 1/2 qt between lower and upper marks on your dipstick?
Re: Dipsticking! [Re: bigj_16] #4563334
11/03/17 07:46 PM
11/03/17 07:46 PM
MI
HorseThief Offline
HorseThief  Offline
MI
perhaps the relationship is not linear due to a number of things - shape of pan or volume of components or pickup higher up in the pan. Also, the dipstick may feed in at a varying angle. in my experience, ford doesn't really go out of the way to make any of their dipsticks linear and incremental like other manufacturers have. I certainly wish topping off my transmission after exchanging fluid didn't take me a half hour of incremental adding and driving for the last half quart
I saw a brown dog
Re: Dipsticking! [Re: bigj_16] #4563343
11/03/17 07:57 PM
11/03/17 07:57 PM
Georgia
Charlie2015 Offline
Charlie2015  Offline
Georgia
On the 2.7L ecoboost, you need to get it up to temperature, then shut it off and wait 15 minutes to check the oil.
1998 Honda Accord EX 2.3L Auto (Sold) 214k mi
2009 Scion tC Manual (Daily Driver) 165k mi
Re: Dipsticking! [Re: bigj_16] #4563444
11/03/17 10:17 PM
11/03/17 10:17 PM
Washington, USA
Onug Offline
Onug  Offline
Washington, USA
My last few Fords (Explorer and my current F-150) have had horrible dip sticks. Iíve found I have to insert them just the right way (the humps/bumps facing down) to get a repeatable reading. I also have to give the dip stick at least 4-5 minutes to soak after Iíve cleaned it off, otherwise it wonít have a correct reading. I havenít noticed a difference between hot and cold. Not sure how the 2.7 is, but I donít have any confidence itís any better.
2016 F-150 3.5L Ecoboost
Current Oil: Castrol Magnatec 5W-30 and Fram Ultra filter
Re: Dipsticking! [Re: bigj_16] #4563470
11/03/17 10:44 PM
11/03/17 10:44 PM
US-WA
Dyusik Offline
Dyusik  Offline
US-WA
I get over a quart difference on my IS, cold seasons show higher levels(fuel in oil). No measurable difference between hot and cold engine though.
95 Cherokee 190K DELO 10W30, XG8
07 IS250 106K STP syn HM 10w30, FULL
04 YZF-R1 19K DELO 15w40, XG7317
99 HD XL1200S 21K VR1 20w50, NG1515
14 RX450h 40k Idemitsu 0w20, 57047
Re: Dipsticking! [Re: Onug] #4563494
11/03/17 11:32 PM
11/03/17 11:32 PM
bigj_16 Offline OP
bigj_16  Offline OP
"My last few Fords (Explorer and my current F-150) have had horrible dip sticks. Iíve found I have to insert them just the right way (the humps/bumps facing down) to get a repeatable reading. I also have to give the dip stick at least 4-5 minutes to soak after Iíve cleaned it off, otherwise it wonít have a correct reading. I havenít noticed a difference between hot and cold. Not sure how the 2.7 is, but I donít have any confidence itís any better."
Totally agree. I usually have to make 8-10 pulls over a few minutes to get any consistent readings. My daughter's Focus is even worse.
