1984 fury 318.
by red7404. 01/20/19 10:48 PM
Dual Wrench (Humor)
by StevieC. 01/20/19 10:33 PM
Got A Tip For Everyone
by NYEngineer. 01/20/19 10:30 PM
Ford Truck (Humor)
by StevieC. 01/20/19 10:10 PM
Lucas and fresh oil
by Ls1z. 01/20/19 09:42 PM
NewEngland vs KC what a 4th quarter/ and OT
by JimPghPA. 01/20/19 09:19 PM
Albuquerque
by pkunk. 01/20/19 09:11 PM
Adding negative camber for trailer towing
by motor_oil_madman. 01/20/19 08:21 PM
Non-working snowblower
by 97prizm. 01/20/19 08:17 PM
Yellow color valvoline ?? Help needed with oil leak....
by seekingbuddha. 01/20/19 08:10 PM
Recommend me a 225/50R17
by redhat. 01/20/19 08:09 PM
Which 5W40 do you like best?
by 21Rouge. 01/20/19 07:50 PM
bike freewheel disabled by the cold
by Number_35. 01/20/19 07:49 PM
Genuine Toyota filter vs PREMIUM GUARD PG5608
by brianw. 01/20/19 07:37 PM
Miles Lubricants
by mobilaltima. 01/20/19 07:27 PM
Cent. Fl oil stash swap?
by RichardS. 01/20/19 06:02 PM
New remote dual system for 5.4 Ford
by JimmyM. 01/20/19 03:34 PM
"I've been everywhere, man..."
by A_Harman. 01/20/19 03:33 PM
Damo5422, Ls1z, Mark963, tommost, Gew
66997 Registered Users
47 registered members (anndel, billpace1956, carloz, Brad_C, Ammofirst, BikeWhisperer, 4 invisible), 1,094 guests, and 30 spiders.
Topics296,903
Posts4,961,300
Members66,997
Most Online2,688
Jan 19th, 2019
New Starter? #4563185
11/03/17 04:08 PM
11/03/17 04:08 PM
Michigan
jkasch Offline OP
jkasch  Offline OP
Michigan
I've inherited the volunteer job of mowing my church's grounds with a 100 Series John Deere that has a 31F707 Briggs engine. When trying to start it, the starter just clicks but doesn't engage or spin.
I installed a new fully charged battery and cleaned all the connections, but got the same result. However, giving the starter a couple good swift kicks with my foot did the trick and it started next try. It also seems to start fine when it's warmed up.
Any suggestions other than just installing a new starter?
Thanks
Re: New Starter? [Re: jkasch] #4563190
11/03/17 04:17 PM
11/03/17 04:17 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
Kick it every time? Install a used starter? smile
Re: New Starter? [Re: jkasch] #4563194
11/03/17 04:18 PM
11/03/17 04:18 PM
Alabama, USA
TLAR640 Offline
TLAR640  Offline
Alabama, USA
On John Deere mowers powered by Kawasaki v-twins, I've had luck disassembling and lubing sticky starters. It would be worth a try.
16 Colorado, 09 CTS, 14 Aprilia Dorsoduro 750, 15 KTM 500 EXC
Re: New Starter? [Re: EdwardC] #4563206
11/03/17 04:42 PM
11/03/17 04:42 PM
Michigan
jkasch Offline OP
jkasch  Offline OP
Michigan
LOL. Kicking it may be my plan until spring.
Re: New Starter? [Re: jkasch] #4563211
11/03/17 04:47 PM
11/03/17 04:47 PM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
The symptoms stink of a failed starter solenoid. It could also be the starter, maybe worn brushes, but they can all be rebuild for little cost, assuming the Church has no money. Not a difficult job for the handy, even if it's your first time. Check to see if there is a kit with all the replaceable parts included for that starter.
Hard to say what it would cost, but by way of example the kit to rebuild the older 65Amp Chevy alternators are like $20, versus three or more times that for a rebuilt one. If brushes alone, maybe $4.
You can test the solenoid to see if it's the problem.
Lots of replacement parts for those if you decide rebuilding the starter is beyond you, although brush replacement only is quite easy.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: New Starter? [Re: Johnny2Bad] #4563221
11/03/17 05:03 PM
11/03/17 05:03 PM
Michigan
jkasch Offline OP
jkasch  Offline OP
Michigan
Thanks. When I search for starter solenoids for the engine, I see what appear to be like a sending unit thats separate from the starter itself, but there must be a solenoid within the starter that pushes the gear up to engage. Is that what were talking about?
Re: New Starter? [Re: jkasch] #4563261
11/03/17 05:45 PM
11/03/17 05:45 PM
Michigan
jkasch Offline OP
jkasch  Offline OP
Michigan
Thanks for replies. Been watching some YouTube videos. Pretty sure I'm all set on how to proceed.
Re: New Starter? [Re: jkasch] #4563311
11/03/17 06:29 PM
11/03/17 06:29 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Check for loose/dirty connections before buying anything
Thick oil is better grin2
Re: New Starter? [Re: jkasch] #4563348
11/03/17 07:06 PM
11/03/17 07:06 PM
ME
eljefino Offline
eljefino  Offline
ME
Check for various interlocks under the seat etc that could prevent engagement.
The starter solenoid, if its separate, will have two big wires from the battery and starter and at least a third skinny wire to control it.
Sometimes this sort of thing clears up the more you use it, as you scrape the corrosion off the moving electrical parts.
Also, church is spelled with a small "c" unless you're worshiping church itself, not that bearded guy with the capital C.
Re: New Starter? [Re: jkasch] #4563490
11/03/17 10:23 PM
11/03/17 10:23 PM
Central Wisconsin
dwendt44 Offline
dwendt44  Offline
Central Wisconsin
e-bay has starters for many B&S engines.
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Re: New Starter? [Re: jkasch] #4563492
11/03/17 10:28 PM
11/03/17 10:28 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Here's your starter motor:
Part# 693551
ebay
A little bit pricey for a Genuine Briggs & Stratton, but they have Chinese knock-offs for about $30.
Instead of paying tithing next month, just buy a starter. shrug
Re: New Starter? [Re: eljefino] #4563601
11/04/17 05:02 AM
11/04/17 05:02 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
I've had that be an issue with various riding mowers. You get a relay click but no joy. Sometimes you need to jumper safety switches one at a time to find the culprit.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: New Starter? [Re: eljefino] #4563807
11/04/17 10:06 AM
11/04/17 10:06 AM
Michigan
jkasch Offline OP
jkasch  Offline OP
Michigan
Thanks for the tips.
Im not the one who used an upper case c, but since were being fussy, a noun should be capitalized if used in place is a proper noun. For example: We cant see Mom today. Then again, this is an oil forum, so....
Re: New Starter? [Re: Merkava_4] #4563949
11/04/17 12:40 PM
11/04/17 12:40 PM
Michigan
jkasch Offline OP
jkasch  Offline OP
Michigan
Part# 693551
ebay
Thanks. Bookmarked.
Re: New Starter? [Re: jkasch] #4564472
11/05/17 04:43 AM
11/05/17 04:43 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
Brushes are worn out in the starter.
The "thinking" man's friend.
