Please school me 1st Gen mini Cooper NA
CA
thinking to pick up a 1st gen Mini Cooper stick shift.... what areas to look for? Are these really that terrible? In general, how long can these Chrysler engine last? Thanks
A buddy had one to dominate H-Street for autocross. He got rid of it as he was used to Honda's where most major components last the lifetime of the car. I recall he replaced the rad and coolant tank, steering rack, abs controller, some electrical stuff, no huge bills but enough.
He got good mileage and I was thinking of picking it up as he had put alot of work into it, but decided not too. One with a good maintenance history, and lots of parts replaced might be good. One that has "needed nothing" would be scary.
I'd ask your question on the North American Motoring Forums. On the other hand, you can wait here; you will soon be receiving negative responses from a few self-proclaimed "experts" who have never even sat in a Cooper.
In my research I found some indications that the 2nd Generation Coopers are a bit more reliable, but I suspect that a thorough service history and a PDI from a tech who knows Coopers are the real dispositive factors.
A family member has an 06 S model. Really fun car. Its had some issues, but the worst thing about MINI issues is that they are expensive issues. Its a cheapish car (in the preowned market) that has pricey parts and labor rates. If you plan on doing all the work yourself you'll save a bundle. This first gen cars I believe had some sludge issues. Something to do with MINIs 15k interval recommendations. Not sure if this mostly affected the S models, or the NA as well.
Unlike the later Prince engines, the tritec (especially in justa form) are rock solid. I've seen them go well over 300,000 mikes but don't recall seeing any go to 4000,000 yet. Look for a 2004 or later as the early transmissions were a week spot - the midlands 5 speed and CVT. Look for rust on the hatch, failed low speed controller on the radiator fan, and failing power steering. All these are easily fixable but a bargaining chip if you find them on one you like.
Originally Posted By: Reddy45
These had Chrysler engines?! Weren't they manufactured by BMW?
They were produced in Brazil in a partnership between Chrysler and BMW. It also found its way into some Neons.
Get the latest model year you can. The manual transmissions in these cars loved to take a dump often and it got less bad after 2004 but still happens.
Radiator fan wiring and speed controller as stated above is basically garuenteed to fail and will need sorted out. Not a super complicated fix.
Rust is an issue with these for sure near door hinges and on the hatch. But you can find clean ones.
I have had a few friends with these and it's mostly the little nit-picky stuff that gets you. Small electrical gremlins for example add up to $$$ after a little while.
Very fun cars though. Even in base model form they are great to drive. Probably the second best fwd vehicle I have driven.
thanks guys, you all are great people.. i was looking at Miata too, but wife said no on 2 seater! Not sure what else i should look into for a fun to drive now....? 1st gen Mini indeed needs a lot of work..... may need to scratch it. It fits into my toy car budget though....
What kind of budget are you looking at? Another great option from that time period would be an Acura RSX, or RSX-S. Or even a 2006 Civic Si.
What work do they need that would make it be scratched off?
Originally Posted By: cadfaeltex
Care to share the first?
Dc2 integra type R.
The engine bay is tight. Almost like they shrunk the car around the engine. Takes all the fun out of maintenance. Not that uncommon anymore.
Rod
My friend had in total 3, Cooper S, Cooper, and now facelift 1.6 diesel. He swears by them, in terms of quality and especially road manners. One thing to watch is gearbox on early (-04), only Cooper with Midland box, S is different (Getrag) and strong.
General quality is OK, but you have to be aware that this is a little car, and little cars aren't built as tough as big ones.
if i add up the electrical problems and the gear box and some other stuff, basically i need to replace everything but the interior and body? i can understand its a 15 years old car; but it indeed needs a lot of work... every mini cooper that i checked; none of them have any repair record.... i can spend 2500 on it and end up spending another 2000 for repairs...
Just because things were listed as possible doesn't mean that they are likely or will be found on every car. When I bought my current '08 R52 with 68k miles all I've had to do is change the oil. Not problem one.
My first car was a 03 red mini cooper 5 speed manual. I absolutely loved the thing...but I didn't know how to work on cars then and the repair bills were insane. Spent 3k fixing it and crashed it a week later
Overall id probably buy one again now if I had the money and time to work on it. Probably the best feeling shifter OEM I've experienced.
