Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Purolator P1 14476 CUT OPEN
by 53' Stude. 12/12/18 06:00 PM
Which car to buy?
by jrcowboys. 12/12/18 04:55 PM
New Tire Cracking
by robd. 12/12/18 04:43 PM
SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
24 registered members (Aero540T, Bailes1992, anndel, DirtyOilGuy, bbhero, 3 invisible), 894 guests, and 36 spiders.
Topics295,007
Posts4,925,886
Members66,664
Most Online2,553
Oct 27th, 2018
'16 Colorado - 6,647 miles on oil - RP 5/30 #4563059
11/03/17 01:16 PM
11/03/17 01:16 PM
NY
c5z06 Offline OP
c5z06  Offline OP
NY
2016 Colorado v6 Z71
6,647 miles on oil
11,749 miles on motor
RP 5/30
K&N filter
I refilled with RP / K&N filter, but after that I am going PUP 5w30 with a Fram Ultra.
Re: '16 Colorado - 6,647 miles on oil - RP 5/30 [Re: c5z06] #4563089
11/03/17 02:03 PM
11/03/17 02:03 PM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
Iron looks high compared to universal averages, but the engine is still new. Looks like pretty healthy dose of fuel in the oil as well. The Royal Purple isn't really a boutique oil, nor does it really impress here. I'd be looking for another choice of oil as well.
Thanks for the report!
Luke
Re: '16 Colorado - 6,647 miles on oil - RP 5/30 [Re: FlyNavyP3] #4563090
11/03/17 02:07 PM
11/03/17 02:07 PM
NY
c5z06 Offline OP
c5z06  Offline OP
NY
I haven't been impressed with RP (Dexos) oil at all. Very pricey for what you actually get. I ran PUP in other vehicles in the past and I will go back to that. I am interested in the UOA and will publish them once I get enough miles.
Re: '16 Colorado - 6,647 miles on oil - RP 5/30 [Re: c5z06] #4563137
11/03/17 03:16 PM
11/03/17 03:16 PM
Pennsylvania
340_Magnum Offline
340_Magnum  Offline
Pennsylvania
That 3.6 V6 Colorado is a nice little truck. I usually run either Pennzoil Platinum 5w-30 or Quaker State Ultimate Durability 5w-30 in mine alone with a Fram Ultra filter.
Re: '16 Colorado - 6,647 miles on oil - RP 5/30 [Re: c5z06] #4563193
11/03/17 04:18 PM
11/03/17 04:18 PM
NJ, USA
davison0976 Offline
davison0976  Offline
NJ, USA
That's nothing for a 11,000 miles old engine. I had similar or worse wear on my V6 engines at that mileage.
I wouldn't read to much into wear numbers until you at least over 40,000 miles.
Re: '16 Colorado - 6,647 miles on oil - RP 5/30 [Re: c5z06] #4563195
11/03/17 04:26 PM
11/03/17 04:26 PM
Texas (south)
FermeLaPorte Offline
Texas (south)
Chevy and Ford are pretty unreliable. Just change your oil regularly and I bet you will be fine.
Always Mobil 1
2014 1.6L Nissan Versa Sedan, 5 spd, 5k OCI.
2011 3.5L Chevrolet Impala, Automatic, 5k OCI.
Re: '16 Colorado - 6,647 miles on oil - RP 5/30 [Re: c5z06] #4563241
11/03/17 05:27 PM
11/03/17 05:27 PM
New York
pbm Offline
pbm  Offline
New York
RP changed their formula about 1.5 years ago....it went from a high sodium, VSP clone to a no sodium, high moly and boron formula. I like this newer formula better but only when I can get it as cheap as other syns.
'Journalism is Dead'
Re: '16 Colorado - 6,647 miles on oil - RP 5/30 [Re: c5z06] #4563454
11/03/17 09:25 PM
11/03/17 09:25 PM
Washington, USA
Onug Offline
Onug  Offline
Washington, USA
I donít know anything about GM engines, but I bet youíre still working through break-in metals. Iím guessing fuel dilution is whatís causing the oil to drop out of spec. I wouldnít run the OCI any longer than you have until that works itself out. Any maybe try another oil to see if it holds up better...
2016 F-150 3.5L Ecoboost
Current Oil: Castrol Magnatec 5W-30 and Fram Ultra filter
Re: '16 Colorado - 6,647 miles on oil - RP 5/30 [Re: Onug] #4563572
11/04/17 04:03 AM
11/04/17 04:03 AM
Grand Rapids, Michigan
Toto Offline
Toto  Offline
Nothing wrong with PUP or Royal Purple but if I had a GM vehicle I would use MOBIL 1, it has all the GM certifications(no warranty hassles) , it's readily available and you can find a deal somewhere on it, plus use the oil light monitor if your truck has one.
Best of luck
TOTO.
AMSOIL-OE 0W 20-XL 10W 30-AGL 80W 90
NAPA GOLD
Re: '16 Colorado - 6,647 miles on oil - RP 5/30 [Re: c5z06] #4563652
11/04/17 07:13 AM
11/04/17 07:13 AM
Virginia
bigt61 Offline
bigt61  Offline
Virginia
What kind of usage does this truck see? How much & how heavy are you towing?
92 Suburban 2500 7.4L 58k M1_0w40 5yr OCI
99 Olds Aurora 4.0L 91K M1_5w30 5yr OCI
13 Dodge Dart 2.0L 30k PP 0w20 OLM OCI
70 Camaro 5.7L 59k
Re: '16 Colorado - 6,647 miles on oil - RP 5/30 [Re: bigt61] #4563839
11/04/17 10:33 AM
11/04/17 10:33 AM
NY
c5z06 Offline OP
c5z06  Offline OP
NY
Towed 600 miles on this oil, otherwise its a 50/50 mix of city and highway.
Re: '16 Colorado - 6,647 miles on oil - RP 5/30 [Re: Toto] #4563841
11/04/17 10:34 AM
11/04/17 10:34 AM
NY
c5z06 Offline OP
c5z06  Offline OP
NY
If I used the OLM on the truck I would have easily went a 1000 miles or more past where I changed it, 38% when changed.
