Walmart Canada doesn't have the Supertech brand, but instead the "Tune it!" brand.
This gear oil sells for CAD$7 regular price, which is quite the deal.
I read somewhere that Walmart USA had some labeling issue in the past about identifying as "limited slip" its Supertech gear oil while it shouldn't have been.
I plan on using it in a 1998 Yamaha Big Bear 4x4. Front diff is limited slip, rear gear is just a regular gear on solid shaft. Yamaha recommends limited slip oil front and regular gear oil rear.
Is this oil too good to be true, $7 for limited slip approved gear oil? All the other limited slip oil I could locally found were synthetic and between CAD$18-22 a quart.
