Looking for Fram Ultra XG30 and XG5 cut open
by rubberchicken. 12/12/18 10:27 PM
92 f150 332 code
by ram_man. 12/12/18 10:05 PM
Mixing brands of brake fluid / gear lube
by SureshR. 12/12/18 09:26 PM
45,000 miles in the Caprice.
by ls1mike. 12/12/18 09:21 PM
Quality oils?
by Horsehaulin. 12/12/18 09:16 PM
Exhaust fumes in cabin
by Skater4life27. 12/12/18 08:40 PM
Squeaky sunroof
by dishdude. 12/12/18 08:09 PM
Liqui Moly Top Tec 1800
by Chuckh. 12/12/18 07:56 PM
2006 Pathfinder Transmission Shudder
by Bluestream. 12/12/18 07:10 PM
Maybe E-10 is better? - PentaStar (Flex Fuel)
by StevieC. 12/12/18 06:52 PM
Shipping cost
by Fitter30. 12/12/18 06:45 PM
Purolator P1 14476 CUT OPEN
by 53' Stude. 12/12/18 06:00 PM
Which car to buy?
by jrcowboys. 12/12/18 04:55 PM
New Tire Cracking
by robd. 12/12/18 04:43 PM
SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Horsehaulin, JLew, bmrk1100, Rrrracer, jefe_de_estado
66664 Registered Users
23 registered members (Char Baby, 53' Stude, FordCapriDriver, bbhero, FordBroncoVWJeta, dishdude, 2 invisible), 795 guests, and 38 spiders.
Topics295,007
Posts4,925,897
Members66,664
Most Online2,553
Oct 27th, 2018
Page 1 of 3 1 2 3
FlexFuel Ecoboost #4562522
11/02/17 08:03 PM
11/02/17 08:03 PM
Crawfordville FL
SilverFusion2010 Offline OP
Crawfordville FL
Why doesn't this exist? With the turbos the effective compression ratios should be high enough to not take a big mileage hit and make lots more power.
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: FlexFuel Ecoboost [Re: SilverFusion2010] #4562538
11/02/17 08:22 PM
11/02/17 08:22 PM
Lima, Ohio, USA
earlyre Offline
earlyre  Offline
Lima, Ohio, USA
I've wondered this myself...
or really, why don't they just make ALL the cars flex capable, even knowing full-well most folks won't/cant take advantage of it.
we're talking maybe $100 difference in their costs to build the car.(roughly what the aftermarket sensors cost, I'm sure an OEM can get 'em much cheaper in bulk.
Mine:
09 Mercury Sable : 6qts AutoQuest(Meijer/Warren) 0w20, WIX 51516
Mine to Maintain:
03 Pontiac Vibe : 4.5qts VWB 5w30,WIX 51394
Re: FlexFuel Ecoboost [Re: SilverFusion2010] #4562614
11/02/17 10:33 PM
11/02/17 10:33 PM
Douglas County, Colorado
bigj_16 Offline
bigj_16  Offline
In a very general, broad sense, and without going into any detail, I would say that the Ecoboost engines are so very specifically tuned that Ford is not going to muck it up by throwing E85 into the mix. Just my opinion. No facts.
Re: FlexFuel Ecoboost [Re: SilverFusion2010] #4562645
11/03/17 12:06 AM
11/03/17 12:06 AM
Festus MO
rodinator1234 Offline
Festus MO
It has everything to do with direct injection and the way the system operates with a high pressure fuel pump. In its basic form HPFP is a fixed displacement pump with no way to vary the volume of fuel necessary to adjust for the difference in BTU value between E85 and E10 or any mixture in between to maintain an AFR within acceptable burn limmits for engine protection and emissions compliance. There are no directed injected engines made by any manufacturer besides Mercedes that advertise E85 capability and they have significant long term issues.
E85 compatible vehicles all use electric variable displacement/variable voltage pumps that along with adjusting the pulse width of the injectors can inject more or less fuel to maintain the AFR.
HPFP are cam driven fixed displacement piston pumps that are feed by a electric fuel pump. They can not adjust volume of fuel. For example, E85 has 2/3 the energy of E10, therefore the HPFP would have to be able to deliver 2/3 more fuel at the maximum fuel demand rate to maintain enough fuel pressure and volume to provide enough fuel to maintain the AFR. And it simply canít. Usually HPFP have a 30% over volume design, thatís it.
If you place water under a vacuum at room temperature it will boil. The same happens to the fuel when the HPFP starves for fuel because itís putting more out than it can get from the electric pump or the demand is so great itís loosing in the rail or a combination of both. The fuel is under a vacuum and the boiling ďbubble popĒ takes a small micron of metal away from the piston or the cylinder wall and eventually wears the pump enough to get leak by. Either way, that boiling or cavitation, and E85 being very dry and lacking lubricity kills HPFPís and then usually an injector or two.
Re: FlexFuel Ecoboost [Re: SilverFusion2010] #4562654
11/03/17 12:58 AM
11/03/17 12:58 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Just my opinion , but a person should ear corn and burn gasoline . The ethanol fuel idea / industry is just a huge boondoggle & subsidy to the agriculture industry .
If you are going to do ethanol fuel , make sure it will be economically viable w/o subsidies & use something for the raw product that we or our livestock do not eat .
Noe , if a person wishes to go " green " , make bio diesel from waste oil .
Wyr
God bless
Re: FlexFuel Ecoboost [Re: SilverFusion2010] #4562670
11/03/17 03:38 AM
11/03/17 03:38 AM
Indiana
dlundblad Offline
dlundblad  Offline
Indiana
Ethanol use across the nation does not add up so they probably don't want to bother with it? Does Chrysler make anything that is E compatable?
We have either E10 or E85 here.. No in between. Out west where they grow more corn than here, they have E15, E20 etc. that bring the cost down without taking a hit in mileage, and thus making it's use pointless. I would use it in this case.. (Can't remember the BITOG member who talked about this.) I do find it odd that the larger corn producers have the option to use LESS ethanol. Somewhat like a CEO of a tobacco company not using tobacco.
I do know some local farmers that were "upset" when fuel prices were low (that fall after fuel was $4+ a gallon) because that meant they'd get less for their corn. I am just surmising that they disregarded THEIR costs to pick the stuff, but I am not sure..
03 Jeep WJ 4.0 202k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 186k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 153k Synpower 5w30 Supertech ST3980 (Ecore)
Re: FlexFuel Ecoboost [Re: rodinator1234] #4562730
11/03/17 05:48 AM
11/03/17 05:48 AM
IL
04SE Offline
04SE  Offline
IL
You might want to look at GM's L83 (LT1 based) Gen V motor.
Life's little problems can be solved with a shovel and silence.
Re: FlexFuel Ecoboost [Re: rodinator1234] #4562734
11/03/17 05:54 AM
11/03/17 05:54 AM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
Assuming E85 has two thirds the energy of E10, then the HPFP would have to deliver one half more fuel, not two thirds more.
(Two thirds plus one third = one; and one third is half of two thirds, so 50% more not 67% more).
The HPFP has a 30% over volume design (130%) which would be 20% short of being able to run E85. Does not seem that insurmountable to me.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: FlexFuel Ecoboost [Re: dlundblad] #4562757
11/03/17 06:45 AM
11/03/17 06:45 AM
TN USA
Crispysea Offline
Crispysea  Offline
TN USA
Their most common engine, the Pentastar. I think they took the option out last year, but their 4 cylinder engines still have it. There are 5 million of them on the road. Every Dodge Caravan taxi I see has a FlexFuel badge.
Re: FlexFuel Ecoboost [Re: SilverFusion2010] #4562763
11/03/17 06:51 AM
11/03/17 06:51 AM
Frankfort, Kentucky
Shaman Offline
Shaman  Offline
Frankfort, Kentucky
Boost plus corn juice is fun. But also a great way to increase wear on the engine, and the possibility of breaking parts.
Re: FlexFuel Ecoboost [Re: SilverFusion2010] #4562776
11/03/17 07:10 AM
11/03/17 07:10 AM
Sunny Florida
SteveSRT8 Offline
SteveSRT8  Offline
Sunny Florida
Implying that DI engines cannot vary their fuel delivery is a bit disingenuous. As noted above GM has DI engines that are flex fuel. I am sure they can vary their injector pulse width in order to modulate fuel delivery as virtually any fuel injected vehicle does.
Frankly, IMO Ford is a bit more knowledgeable than many here and understands their Ego boosters are tuned a bit closer to the ragged edge than the average engine. Regular E10 varies tremendously from station to station and is probably all they could consider within their factory tune.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: FlexFuel Ecoboost [Re: rodinator1234] #4562832
11/03/17 08:30 AM
11/03/17 08:30 AM
Somewhere
itguy08 Offline
itguy08  Offline
Somewhere
Ford's HPFP can vary both the volume and pressure of the fuel.
Ford HPFP
Quote:
The high-pressure system consists of a high-pressure fuel pump that is mechanical and driven by a special four-point camshaft lobe that is only for pump operation. The plunger action of the high-pressure pump boosts fuel pressure up to 2,150 psi. The high-pressure fuel is in the metal line leaving the pump to the rails as well as the fuel rails. There is also no return line in the high-pressure system. The high-pressure pump mounts on the left valve cover. Pressure in the high-pressure system swings widely with rpm and demand. Pressures here will swing from as low as 1,000 psi to 2,150 psi depending on conditions. Pressure is controlled by balancing the volume through the pump and into the rail versus the volume passing through the injectors. One complete revolution of the camshaft produces four strokes of the high-pressure pump. At maximum, these four strokes equal 1 cc of fuel delivered to the rail. If met with a dead end, that 1 cc of fuel would raise the rail pressure by about 800 psi. The injector cycling will vent that fuel into the cylinders at around 21 cc per second. The PCM raises and lowers the high-side fuel pressure by pulsing the fuel inlet valve (solenoid) on the side of the pump. The inlet valve controls not only the amount of fuel that enters the pump chamber, but also the amount that bleeds back into the low-pressure system when the pumpís plunger pushes the fuel out. The more the pump is filled, and the less that bleeds back into the low side, the higher the pressure will be in the rails. The PCM monitors a fuel rail pressure sensor to determine the needed action at the volume regulator. The pressure sensor is mounted to the top of the left-hand rail.
I've personally witnessed (via Torque and and OBD scanner) the pressure cycles of the HPFP pump.
As to why no Flex Fuel Ecoboosts - no idea. Probably lots of engineering for near 0 benefit. In the right hands the EB's are capable of great power.
Re: FlexFuel Ecoboost [Re: 04SE] #4562893
11/03/17 10:06 AM
11/03/17 10:06 AM
Festus MO
Festus MO
I donít think GenerL Motors advertises this as a flex fuel compatable engine. Check it out.
Re: FlexFuel Ecoboost [Re: Crispysea] #4562897
11/03/17 10:08 AM
11/03/17 10:08 AM
Festus MO
Festus MO
Pentastar engines are not direct injected, neither are Tigershark engines. Do a quick google search if you donít believe me. Prove me wrong, by all means.
Re: FlexFuel Ecoboost [Re: itguy08] #4562903
11/03/17 10:14 AM
11/03/17 10:14 AM
Festus MO
Festus MO
Ford HPFP
What
What you witness is the fuel pressure regulator varying pressure in the rail based on demand. Fixed volume pumps driven by cams vary only in RPM the regulator manages pressure. Injector, pulse width, duty cycle and fuel load demand all calculate into the required fuel demand for performance and emessions compliance which is also a huge consideration.
Page 1 of 3 1 2 3
