LUBRICATION ENGINEERS LE1605 NO LONGER GL5!?
by dedonderosa. 09/19/18 09:28 AM
by dedonderosa. 09/19/18 09:26 AM
When you're too old to drive
by Speak2Mountain. 09/19/18 09:22 AM
Another VW Thread
by Zee09. 09/19/18 09:21 AM
Tremec HP MTF - No more ATF?
by ABomb369. 09/19/18 09:02 AM
Is 0W weight oil the perfect oil?
by Baas95. 09/19/18 08:01 AM
2014 Durango ZF8 transmission fluid recommendation
by MoparMan12. 09/19/18 06:45 AM
Does Rear Heater Need to be On?
by Gebo. 09/19/18 05:04 AM
125 years.
by Silk. 09/19/18 12:38 AM
How a VW DSG Transmission works
by StevieC. 09/18/18 10:42 PM
Full Synthetic vs HM Full Synthetic
by SierraMan. 09/18/18 10:06 PM
Champion AGM batteries
by bbhero. 09/18/18 08:53 PM
General opinion about Cooper CS5 Ultra?
by dan_erickson. 09/18/18 08:37 PM
Rotella Online Rebate
by PumpPusher. 09/18/18 08:13 PM
Audi A4 vs Volkswagen CC...or good old Passat?
by KCJeep. 09/18/18 07:19 PM
GM 454 engine
by dirtymudder. 09/18/18 07:13 PM
High Performance Motorcycle oil...which one?
by Neiz15. 09/18/18 06:50 PM
Need help High Performance Motorcycle oil?
by Neiz15. 09/18/18 06:38 PM
vortex64, 19074, Redright9, Clif67, scotstr
66011 Registered Users
99 registered members (64bawagon, 28oz, ABomb369, Aero540T, AandPDan, advocate, 9 invisible), 1,326 guests, and 49 spiders.
Topics290,632
Posts4,847,745
Members66,011
Most Online3,590
Jan 24th, 2017
Oil for 06 Impala that burns oil? #4562130
11/02/17 02:13 PM
11/02/17 02:13 PM
Wisconsin
Srt20 Offline OP
Srt20  Offline OP
Wisconsin
Have you found an oil that works better in engines that burn oil?
06 Impala 3.5L 50K miles. PCV is not replaceable and has been cleaned. No external oil leaks.
It doesnt use alot of oil, but its wifes work car, she travels alot, and doesnt/wont/cannot be trusted to check oil level on regular basis.
Current oil is Farm and Fleet 5w-30 (made by Citgo) has the dexos cert. No clue what oil was previously used, but it burned at the same rate on the OCI that I got the car. Probably a dino, OCI was done at an independant shop before I got the car.
What do ya think? Thanks
Re: Oil for 06 Impala that burns oil? [Re: Srt20] #4562137
11/02/17 02:18 PM
11/02/17 02:18 PM
Illinois
mrsilv04 Offline
mrsilv04  Offline
Illinois
I'd try some Valvoline Maxlife next. It worked well in a car in an older, high mileage car that I used to change the oil on.
2004 Silverado - on its 3rd Jasper engine in less than one year.
Re: Oil for 06 Impala that burns oil? [Re: Srt20] #4562151
11/02/17 02:42 PM
11/02/17 02:42 PM
TX-Texas
mctmatt Offline
mctmatt  Offline
TX-Texas
2006 Impala with just 50,000 miles on the odometer with no external leaks. I have a 2007 3.5 Flex Fuel that I inherited and now has 63,700 on the odometer with no external leaks but have noticed that it will burn half a quart of oil or less when I do extended oil changes past 8000 miles. I am currently running 5W-30 Castrol Magnatec and my jump up to 10W-30 on next oil change. Since there are no leaks not really sure what to tell you as there are others here with much more knowledge than I.
Re: Oil for 06 Impala that burns oil? [Re: Srt20] #4562162
11/02/17 02:53 PM
11/02/17 02:53 PM
Buffalo, NY
Nickdfresh Offline
Nickdfresh  Offline
Buffalo, NY
I'd second the MaxLife 5W-30. Maybe up to a 10W-30 in summer...
Re: Oil for 06 Impala that burns oil? [Re: Srt20] #4562187
11/02/17 03:29 PM
11/02/17 03:29 PM
MN
TmanP Offline
TmanP  Offline
MN
How much oil are you talking?
A quart in 1000? A quart in 3000?
As far as her checking the level, I believe the Impalas have an oil level sensor that lets you know in the DIC when you're a quart down. Just a thought... (I mean, I'd still check it but if you have that as a backup, it helps.)
2012 Toyota Camry 2.5 30,000 mi
2015 Chevy Silverado LT Z71 5.3 V8 30,000 mi
2010 Toyota Sienna 3.5 V6 150,000 mi
Re: Oil for 06 Impala that burns oil? [Re: TmanP] #4562205
11/02/17 03:59 PM
11/02/17 03:59 PM
Wisconsin
Srt20 Offline OP
Srt20  Offline OP
Wisconsin
Its about 2200-2400 miles a quart.
This car does not have any oil level sensor on the DIC. First time I drained the oil it only had 2.5 qts in it. But I went through DIC and found nothing for oil or tire psi.
Ideally I'd like to do 8k-10k oil changes with a max of 1 qt make up in the middle.
IDK anything about MaxLife. Is it an oil I can run 8k OCI?
Thanks!
Re: Oil for 06 Impala that burns oil? [Re: Srt20] #4562215
11/02/17 04:13 PM
11/02/17 04:13 PM
Buffalo, NY
Nickdfresh Offline
Nickdfresh  Offline
Buffalo, NY
Thanks!
With make-up oil, yes...
Re: Oil for 06 Impala that burns oil? [Re: Srt20] #4562235
11/02/17 04:33 PM
11/02/17 04:33 PM
Chicago Suburbs
Nitronoise Offline
Nitronoise  Offline
Chicago Suburbs
citgo is a good oil I have been traveling up to Blaine's in Sturtavant Nowack volatility was good it has a good add pack for 1.79 a qt we have been running it in a hyundai with 281 k on it and in my daughters 3.0L vulcan motor in her Taurus with great results
I would run a 5 k oci and add a quart half way through.
8-10 k with something going on inside that motor might be a stretch IMHO
07 Ford Freestyle 135K
04 Hyundai Sonata 280K
03 Hyundai Santa Fe 165K
02 Ford Tarus 98K
00 Buick Regal SC 135K
95 Goldwing 28K
Re: Oil for 06 Impala that burns oil? [Re: Srt20] #4562245
11/02/17 04:48 PM
11/02/17 04:48 PM
Ontario, Canada
StevieC Online content
StevieC  Online Content
Ontario, Canada
75w90. LOL
'18 Highlander - AMSOIL SS 0w20 / ATF / Severe Gear
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF (R.I.P)
Re: Oil for 06 Impala that burns oil? [Re: Srt20] #4562256
11/02/17 04:54 PM
11/02/17 04:54 PM
Texas
Tdog02 Offline
Tdog02  Offline
Texas
I'd use maxlife and go 10w-30 since you are up north.
09 Venza 2.7 100k 5w-30 Magnatec
16 F150 2.7TT 40k 5w-30 Magnatec
Re: Oil for 06 Impala that burns oil? [Re: Srt20] #4562294
11/02/17 05:45 PM
11/02/17 05:45 PM
Wisconsin
Srt20 Offline OP
Srt20  Offline OP
Wisconsin
I will give Maxlife a try. But I will stick with 5w-30 in winter. I will probably give 10w-30 or even a 40 a shot in summer.
Re: Oil for 06 Impala that burns oil? [Re: Srt20] #4562387
11/02/17 07:09 PM
11/02/17 07:09 PM
Georgia
Charlie2015 Offline
Charlie2015  Offline
Georgia
10w30 Valvoline Full Synthetic with Maxlife Technology
1998 Honda Accord EX 2.3L Auto
2009 Scion TC Manual
Re: Oil for 06 Impala that burns oil? [Re: Srt20] #4562395
11/02/17 07:17 PM
11/02/17 07:17 PM
Virginia
bbhero Offline
bbhero  Offline
Virginia
Yeah I agree with 5w in the Wisconsin winter. People may not realize this but it can get to -20 to -30F in the northern and northwestern parts of Wisconsin. That is not all that uncommon in those areas north and west of Wausau. Lots of snow on the ground, very little wind, plus high pressure overhead, and a clear sky and there you go.
Nissan Altima 3.5 Coupe
Quaker State High Mileage 5w30 Purolator Boss 14610
"Treat your family like your friends and treat your friends like your family."
Re: Oil for 06 Impala that burns oil? [Re: bbhero] #4562492
11/02/17 08:47 PM
11/02/17 08:47 PM
Wisconsin
Srt20 Offline OP
Srt20  Offline OP
Wisconsin
Heck it can get -20* in southern WI.
Re: Oil for 06 Impala that burns oil? [Re: Srt20] #4562499
11/02/17 08:50 PM
11/02/17 08:50 PM
Canada
i_hate_autofraud Offline
Canada
All the 3.5 V6 Impalas I run use oil, but they don't burn and leave oily sotty plugs
or oily exhaust pipes or blue smoke! Go figure!
I suspect that the small PCV lines off each bank of the engine aggressively suck
lots of oil as vapour into the intake based on the dirty throttle body, etc
Until it puffs blue smoke, this may be the way they come from GM. At one point I may
jump up one grade of oil thicker, but effective lube of the pistons could be an issue!
