RP synchromax vs Dexron VI transfer case
got a borgwarner 4485 AWD transfer case in my truck. Would you rather run Royal Purple Synchromax or Dexron VI in this? RP suggests synchromax is better then there max atf for this application but maybe amsoil dexron vi/diff brand dexron vi is better then the synchroax in general
thanks
I'm about to put Valvoline Transfer case full synthetic in my step fathers 07 Trailblazer. GM is apparently pretty picky about this fluid but I think it will be more than fine. I don't think an ATF will cover it.
thanks
RP Synchromax for sure.
