puncture repair question
by neo3. 09/21/18 10:55 PM
Can I use a 10 amp extension cord for...
by gregk24. 09/21/18 10:48 PM
In the unlikely event of a crash
by StevieC. 09/21/18 10:09 PM
Craigslist time wasters
by Anduril. 09/21/18 09:41 PM
Who runs a 20wt here?
by StevieC. 09/21/18 07:31 PM
Need help on edit profile
by jetmech1. 09/21/18 06:34 PM
Oil thickness on the dipstick
by Idlewild294. 09/21/18 05:40 PM
Chinese WIX Trans filter bad, let me down..
by jetmech1. 09/21/18 04:47 PM
Gen 8 Accord rear brakes-What tool?
by fdcg27. 09/21/18 04:30 PM
Ammeters?
by buck91. 09/21/18 03:55 PM
Need Help with Double D Knock Out Punch
by user52165. 09/21/18 03:41 PM
Opinion needed....
by Duffyjr. 09/21/18 02:56 PM
2017 nissan sentra
by jahwarrior1423. 09/21/18 02:47 PM
Another dealership service cautionary tale
by Zee09. 09/21/18 02:29 PM
Liqui Moly
by dawgn86. 09/21/18 02:10 PM
Valve issues
by kawie_guy. 09/21/18 01:54 PM
2018 Elantra SE
by wolf_06. 09/21/18 01:36 PM
JRMFt11, Navyretired, aikwae, ScottRousell, Direct_Rejection
66036 Registered Users
79 registered members (4WD, AndyB, Ablebody, 1.8Tango, Anduril, 7 invisible), 1,240 guests, and 36 spiders.
Topics290,802
Posts4,850,633
Members66,036
Most Online3,590
Jan 24th, 2017
Pressure washer storage maintenance #4561652
11/01/17 10:05 PM
11/01/17 10:05 PM
Houston, Texas
motor_oil_madman Offline OP
Houston, Texas
Is there anything that needs to be done to a pressure washer when not in use? I used my pressure washer then a month later I came back to use it and noticed the tip I used was rusted. I've heard guys run antifreeze through the pump and hose etc. Will that eliminate rust problems too?
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Pressure washer storage maintenance [Re: motor_oil_madman] #4561666
11/01/17 10:29 PM
11/01/17 10:29 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
I think the rust is caused from how it was stored. Where do you leave it? Do you run any products through it? I would store it in a dry place is all. Ive never used antifreeze or any such products on it and its been fine the few years ive had mine.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Pressure washer storage maintenance [Re: motor_oil_madman] #4561737
11/02/17 12:09 AM
11/02/17 12:09 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Try storing it with the tip up, or remove the tip.
I don't do anything special with my pressure washer until it's time to put away for the winter.
Re: Pressure washer storage maintenance [Re: motor_oil_madman] #4561800
11/02/17 05:37 AM
11/02/17 05:37 AM
Minnesota
leje0306 Offline
leje0306  Offline
Minnesota
More importantly, you should run antifreeze thru the pump each time you use it. They make foaming antifreeze that expands and forces water out of the pump. I never really worry about the tips and have never had to replace one. If I did, they are only a few bucks on Amazon.
Re: Pressure washer storage maintenance [Re: motor_oil_madman] #4561805
11/02/17 05:49 AM
11/02/17 05:49 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
For storage I've used Briggs and Stratton Pump Saver from Lowes. Combination AF and pump lubricant. Relatively inexpensive and easy to use. Following the instructions, doesn't require much to get the job done.
https://www.lowes.com/pd/Briggs-Stratton-4-fl-oz-Pump-Saver/3241112
Re: Pressure washer storage maintenance [Re: motor_oil_madman] #4561810
11/02/17 06:16 AM
11/02/17 06:16 AM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
^^^I use Pump Saver too. My pressure washer is a B&S powered Craftsman that's close to 10 years old.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Pressure washer storage maintenance [Re: motor_oil_madman] #4561846
11/02/17 07:34 AM
11/02/17 07:34 AM
NJ
JLawrence08648 Offline
NJ
I didn't think or know about pump antifreeze. I will buy some. Before winter I've always blown the water out with air.
Re: Pressure washer storage maintenance [Re: motor_oil_madman] #4561856
11/02/17 07:48 AM
11/02/17 07:48 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Does it freeze where you are? PumpSaver is what many people use.
Obviously normal OPE engine maint.
2015 Ford F250 w/Powerstroke
Re: Pressure washer storage maintenance [Re: motor_oil_madman] #4561893
11/02/17 08:36 AM
11/02/17 08:36 AM
Illinois
tig1 Offline
tig1  Offline
Illinois
I use Sta-Bil in the gas and PW pump saver in the pump. Has worked well for years.
2007 Ford Fusion 232,000 miles
M1 0-20 EP
2017 Ford Fusion 55K
M1 0-20 EP
M1 ATF and MC LV
M1 10-30 in all OPE
MC filters
Re: Pressure washer storage maintenance [Re: Donald] #4561902
11/02/17 08:43 AM
11/02/17 08:43 AM
Houston, Texas
Houston, Texas
Usually only a couple days a year and it normally does it without any warning. Last year it got down to 25 degrees for like 5 nights In a row.
Re: Pressure washer storage maintenance [Re: motor_oil_madman] #4561909
11/02/17 08:52 AM
11/02/17 08:52 AM
Baltimore, Maryland, USA
zzyzzx Offline
zzyzzx  Offline
I store mine in my basement. It doesn't get cold enough there to freeze.
Re: Pressure washer storage maintenance [Re: motor_oil_madman] #4561984
11/02/17 10:48 AM
11/02/17 10:48 AM
Oklahoma
Schmoe Offline
Schmoe  Offline
Oklahoma
I drain the lines, take the tips off, drain the gas tank and empty the carb bowl and then store in the garage....had it since 2001...Honda with 3300 PSI....sucker will cut concrete and take off paint from the front bumper of her car....wife didn't notice!!!!
01 Supercrew Lariat 4X4
06 Accord EX-L V6
14 CRV EX-L (RIP) 2018 CRV EX-L
