WPA 3 Wireless Security Coming
by StevieC. 09/22/18 01:16 AM
Robo Calls/Telemarketers
by Nick1994. 09/22/18 12:47 AM
What oil should be used!
by BigShug681. 09/22/18 12:28 AM
VW Electronic Parking Brake
by StevieC. 09/21/18 11:48 PM
Leak Sealing and Mould Treatments?
by Ducked. 09/21/18 11:44 PM
UPS / FedEx / USPS
by StevieC. 09/21/18 11:21 PM
puncture repair question
by neo3. 09/21/18 10:55 PM
Can I use a 10 amp extension cord for...
by gregk24. 09/21/18 10:48 PM
In the unlikely event of a crash
by StevieC. 09/21/18 10:09 PM
Craigslist time wasters
by Anduril. 09/21/18 09:41 PM
Who runs a 20wt here?
by StevieC. 09/21/18 07:31 PM
Need help on edit profile
by jetmech1. 09/21/18 06:34 PM
Oil thickness on the dipstick
by Idlewild294. 09/21/18 05:40 PM
Chinese WIX Trans filter bad, let me down..
by jetmech1. 09/21/18 04:47 PM
Gen 8 Accord rear brakes-What tool?
by fdcg27. 09/21/18 04:30 PM
Ammeters?
by buck91. 09/21/18 03:55 PM
Need Help with Double D Knock Out Punch
by user52165. 09/21/18 03:41 PM
JRMFt11, Navyretired, aikwae, ScottRousell, Direct_Rejection
66036 Registered Users
50 registered members (atikovi, 02z, ARB1977, 2009Edge, Astro14, 4 invisible), 1,009 guests, and 36 spiders.
Topics290,810
Posts4,850,790
Members66,036
Most Online3,590
Jan 24th, 2017
Burning oil for more horsepower! #4561588
11/01/17 08:51 PM
11/01/17 08:51 PM
Ontario, Canada
StevieC Offline OP
StevieC  Offline OP
Ontario, Canada
'18 Highlander - AMSOIL SS 0w20 / ATF / Severe Gear
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF (R.I.P)
Re: Burning oil for more horsepower! [Re: StevieC] #4561720
11/01/17 11:52 PM
11/01/17 11:52 PM
Waco, TX
Linctex Online content
Linctex  Online Content
Waco, TX
They WERE - past tense.
The techies caught on - - - new rules forbid it.
Re: Burning oil for more horsepower! [Re: Linctex] #4561794
11/02/17 04:50 AM
11/02/17 04:50 AM
Perth, Western Australia
Brad_C Offline
Brad_C  Offline
I thought that'd be obvious. You'll never get a YouTube video on what they *are* doing.
Re: Burning oil for more horsepower! [Re: StevieC] #4561843
11/02/17 07:30 AM
11/02/17 07:30 AM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
For the rest of this year they are just burning less oil. And i think from now on they will burn as much as the rules allow.
07 Focus ZXW, 5spd manual, 210km M1 5W30
18 Outback 2.5 CVT 10km 0W20 "bulk subaru" whatever that is
Re: Burning oil for more horsepower! [Re: StevieC] #4561878
11/02/17 08:18 AM
11/02/17 08:18 AM
PA
d00df00d Offline
d00df00d  Offline
PA
This made me wonder if something like it was responsible for Royal Purple's horsepower increase claims...
2011 Mazda RX-8 R3
Mobil Super 5w-20
Re: Burning oil for more horsepower! [Re: StevieC] #4562791
11/03/17 08:29 AM
11/03/17 08:29 AM
Indiana
Indydriver Offline
Indydriver  Offline
Indiana
Interesting. The “Catch Can” which filters out crankcase blow-by on the fresh air side of the engine, was developed by drag race engine builders specifically to keep oil out of the combustion chamber because it “reduces octane of the mix”. This video states explicitly that allowing oil in “reduces knock” which would indicate an increase in octane. I’m having a hard time buying that. Pull the throttle body on a modern V8 road car w/o catch can at 50,000 miles and you’re likely to find an oily mess laying in the bottom of the intake manifold. This cannot be good for an engine. This is also why dealers routine recommend “fuel system” cleaning.
2014 Camaro 2SS/RS LS3 Vert 14,000 M1
2012 Sienna 79,000 M1
2007 Tahoe 140,000 PP
Re: Burning oil for more horsepower! [Re: Indydriver] #4562793
11/03/17 08:34 AM
11/03/17 08:34 AM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
This is very different. They were running separate "oil" systems that would inject oil at a tuned rate. Was also very different "oil" than was being used to lubricate the engine.
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Burning oil for more horsepower! [Re: mightymousetech] #4562805
11/03/17 08:49 AM
11/03/17 08:49 AM
Indiana
Indydriver Offline
Indydriver  Offline
Indiana
OK. That makes me feel better.
Re: Burning oil for more horsepower! [Re: StevieC] #4564829
11/05/17 01:18 PM
11/05/17 01:18 PM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
That guy is so full of it! Talking about how oil is going to improve knock resistance. No way. Not even a pure synthetic oil with very uniform base stock composition would improve knock resistance. Long-chain alkanes that make up motor oil will break apart sooner due to high combustion chamber temperatures than will short-chain fuel molecules.
I think trying to explain how current F1 engine builders are improving power output by running motor oil through the combustion chambers is the wrong approach. Cylinder conditions are just too severe to control the combustion. Maybe they have a trick method of metering oil into the exhaust ports via the valve guides. This bypasses the combustion chambers, and allows the heat to be released into the turbocharger/MGU-H where it can be harvested for more power. I have read that the 1.6L V6 turbos run at a lambda number of 1.2, which means that they have excess oxygen in the exhaust that will support combustion.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
Re: Burning oil for more horsepower! [Re: StevieC] #4565667
11/06/17 09:40 AM
11/06/17 09:40 AM
Cedar Park, TX
sunruh Offline
sunruh  Offline
Cedar Park, TX
its ALL about ring seal
until you understand that, you wont
motorcycle oil myth buster
Re: Burning oil for more horsepower! [Re: A_Harman] #4565710
11/06/17 10:38 AM
11/06/17 10:38 AM
Ontario, Canada
IndyIan Offline
IndyIan  Offline
Ontario, Canada
Since fuel composition is strictly controlled, I read that they are using the oil to carry the combustion control additives into the cylinder. Using the turbo as a jet engine is an interesting idea too, as its used directly to charge the batteries.
Re: Burning oil for more horsepower! [Re: A_Harman] #4566437
11/07/17 05:51 AM
11/07/17 05:51 AM
'Stralia
Shannow Online content
Shannow  Online Content
'Stralia
LOL, have made that (the first) statement a couple of times, and been "lambasted" for it.
I agree with your post, we discussed it back a few months ago the ways in which they could conceivably have achieved use of the energy content of burned oil...in cylinder, in the end gas region is the least likely...worst case for knock, and worst to control.
