Follow up on wheel for Chevy Sonic
by WyrTwister. 12/19/18 09:41 AM
Borescope who has one and what is a good one
by Rat407. 12/19/18 09:13 AM
Lubsoil Universal Synthetic Trans Fluid
by GMBoy. 12/19/18 09:00 AM
1994 Civic LX, 1.5L hard to start
by Gito. 12/19/18 08:01 AM
Observation of Mechanics and their tools...
by ToadU. 12/19/18 07:56 AM
Toshiba Laptop HDD Replacement
by Ifixyawata. 12/19/18 07:49 AM
Aisin Warner TF-71SC
by Bailes1992. 12/19/18 06:37 AM
on the Fence about giving up Facebook
by Donald. 12/19/18 06:20 AM
Motorcraft Mercon LV, 15k, 15' Ford Fusion 6F35
by ssamaroo01. 12/19/18 06:14 AM
RockAuto AC compressors
by chrismo. 12/19/18 05:38 AM
Fullers Vintage Ale anyone?
by Lolvoguy. 12/18/18 11:23 PM
Got an alignment
by michaelluscher. 12/18/18 11:18 PM
Castrol Edge 0W-40; 9,762 mi; 2016 Ford Fiesta ST
by asiancivicmaniac. 12/18/18 10:50 PM
Windows Defender Error Code
by ZeeOSix. 12/18/18 10:20 PM
UOA Motul 300V, 5w40, 2013 BMW S1000RR
by Sportbiker. 12/18/18 09:53 PM
Under valve cover pics
by barkingspider. 12/18/18 09:47 PM
Kubota Super UDT2? Anything better?
by Jmoney7269. 12/18/18 09:23 PM
Car Door Fabric Glue
by cb450sc. 12/18/18 08:57 PM
blkvzgo, AdamJames, Firefighter3244, Sportbiker, trollhattan
66721 Registered Users
89 registered members (beanoil, andyd, aquariuscsm, Alfred_B, 66Monza, 7 invisible), 1,767 guests, and 37 spiders.
Topics295,260
Posts4,931,096
Members66,721
Most Online2,553
Oct 27th, 2018
OK to use up loose quarts of Schaeffer? #4561024
11/01/17 08:15 AM
11/01/17 08:15 AM
North Carolina, USA
sohccammer427 Offline OP
North Carolina, USA
I've a 2016 Colorado Duramax diesel with a 2.8l I4. Walmart has 5 quart jugs of Pennzoil Platinum Euro L 5w-30 C3/dexos2 for a very reasonable price of around $23.00. The quarts not so much $7.00
I have a two leftover quarts of Schaeffers 8008 ADVANCED EUROPEAN PERFORMANCE MID SAPS SAE 5W-30 ACEA C3 which is dexos2 and VW 507 suitable that I want to use up. Additionally both are API SN.
What are the BITOG gurus consensus on using 5qts of the Penn and a quart of the Schaeffers as the sump on the Colorado is 6 qts capacity. Seeing how they are both C3, dexos2 and the same weight would this be advisable?
2015 VW Passat TDi 6 Speed Manual
2017 Colorado Duramax
Re: OK to use up loose quarts of Schaeffer? [Re: sohccammer427] #4561044
11/01/17 08:36 AM
11/01/17 08:36 AM
Colorado
Kuato Offline
Kuato  Offline
Colorado
Should be fine, unless you are planning an extended OCI.
If you're still worried you can send them to me I'll be restocking my Schaeffer shortly. grin
Thick vs Thin test: 15k / 43k miles complete
Re: OK to use up loose quarts of Schaeffer? [Re: Kuato] #4561084
11/01/17 09:15 AM
11/01/17 09:15 AM
VA
Gebo Offline
Gebo  Offline
VA
Why would you want to degrade the Schaeffer oil? grin
I just met my Rep in Lynchburg yesterday for a case of ATF. He treats me right...
Depending on where you live in NC, I could come by and get them.
'98 LEX LS400 280K
'00 LEX GS300 195K
'02 4Runner 225K
'05 Lex LS430 85K
'06 Toyota Highlander 145K
'09 Lex IS350 85K
'07 Lex GX470 60K
Amsoil in all engines, transmissions and differentials
Re: OK to use up loose quarts of Schaeffer? [Re: sohccammer427] #4561136
11/01/17 10:30 AM
11/01/17 10:30 AM
Michigan
ZZman Offline
ZZman  Offline
Michigan
Yep, why waste good oil. Use it.
2003 Mercury Grand Marquis. PP HM 5w-30 and Fram Ultra
2008 Sebring Hardtop convertible. PP HM 5w-30 and Fram Ultra
2006 Kawasaki Vulcan 900 LT. Motul 7100 10w-40 and K&N
Re: OK to use up loose quarts of Schaeffer? [Re: Kuato] #4561171
11/01/17 11:08 AM
11/01/17 11:08 AM
DFW
JustN89 Offline
JustN89  Offline
DFW
You moving away from Amsoil and using Schaeffers now? Or is the restocking a part of your Thick/Thin test?
Re: OK to use up loose quarts of Schaeffer? [Re: sohccammer427] #4561197
11/01/17 11:32 AM
11/01/17 11:32 AM
North Carolina, USA
North Carolina, USA
Thanks for the replies. I was really torn between using a CJ/CK or ACEA E9 in this vehicle but decided for the warranty period to stay with a C3. Having said that either M1 ESP, PP Euro L or Valvoline MST will end up being its diet.
I had a couple of qts of Schaeffer left over from a case I had ordered for use in the Tdi. It's great stuff, just a tad pricey, especially when compared to the PP at WalMart.
So for the next two oc's I'll go with 5 qts PP Euro L and a qt of the good stuff (Schaeffer). After that who knows. I really want to run a 5w40 and Valvoline MST 5w-40 is available locally an NAPA. If you can wait until it goes on sale (and it does) it's not too expensive.
Still think E9 is a much more robust OIL, but not sure if the DPF will suffer. Oh the humanity...
Re: OK to use up loose quarts of Schaeffer? [Re: JustN89] #4561302
11/01/17 01:36 PM
11/01/17 01:36 PM
Colorado
Kuato Offline
Kuato  Offline
Colorado
The jury is still out on the Amsoil vs Schaeffer; the Schaeffer UOA was that good...I am waiting for the Amsoil 5w30 run to be completed before making the decision....and with Amsoil's new formulation I feel I will need to get a UOA from that also, before the final final decision LOL. In the thick vs thin test I am comparing Amsoil vs Amsoil only, all SS, which will give me enough data for my decision.
Re: OK to use up loose quarts of Schaeffer? [Re: Kuato] #4561344
11/01/17 02:42 PM
11/01/17 02:42 PM
North Carolina, USA
North Carolina, USA
Amsoil is a true PAO synthetic. Really good stuff. I don't know about Schaeffers but I suspect it is also. The Pennzoil Plat Euro L is a highly hydrocracked made from natural gas.
I'd run the Schaeffers but really my truck is really just a daily driver, not so much a work truck per se, so the group III stuff will be fine for me. Good luck with your research!
Re: OK to use up loose quarts of Schaeffer? [Re: sohccammer427] #4561395
11/01/17 04:01 PM
11/01/17 04:01 PM
Colorado
Kuato Offline
Kuato  Offline
Colorado
Thanks; I've got the considerations of least wear as well as reducing how much oil I actually use; so an extended drain >OLM / 10000 miles is of interest.
Re: OK to use up loose quarts of Schaeffer? [Re: Kuato] #4561689
11/01/17 09:59 PM
11/01/17 09:59 PM
DFW
JustN89 Offline
JustN89  Offline
DFW
Gotcha, sounds good to me. I do remember seeing your UOA and it was a really good showing for Schaeffer. Looking forward to your Amsoil UOA!
Re: OK to use up loose quarts of Schaeffer? [Re: sohccammer427] #4563852
11/04/17 10:43 AM
11/04/17 10:43 AM
Jacksonville, FL
FlyNavyP3 Offline
FlyNavyP3  Offline
Jacksonville, FL
I wouldn't have any concerns at all with using 5 quarts of the PP and one quart of the Schaefer, both meet the spec requirements of your application. Both are good oils, likely better than what the majority of these trucks will be serviced with out in the wild and outside the BITOG members. I wouldn't have any concerns with running that out to the extent of the OLM.
Luke
