Breaking in new short block
by Bub
06/22/18 07:00 PM
Should I buy a mill or a drill press?
by Vern_in_IL
06/22/18 06:32 PM
Weber Q300 Grill Parts Help
by gathermewool
06/22/18 05:24 PM
I Had To Tell Somebody- Banquet
by Zee09
06/22/18 05:13 PM
Xfinity mobile cell service
by jay929
06/22/18 04:37 PM
Fuse "failure"
by dlundblad
06/22/18 04:32 PM
Do you Bluetooth your phone and car?
by ZZman
06/22/18 04:20 PM
Hastings air filters
by Spitter
06/22/18 04:18 PM
2011 Town and Country remote started itself.
by mrsilv04
06/22/18 04:06 PM
Vaughan Hammer and Superbar $10 Sam's
by hatt
06/22/18 04:03 PM
Denso Oil filter - outsourced / quality changed
by 92saturnsl2
06/22/18 02:37 PM
Bench Drill Press
by Propflux01
06/22/18 02:30 PM
IAT Sensor
by artbuc
06/22/18 02:26 PM
2013 Nissan Rogue, 5,100 miles, Supertech Conv
by TheOilWizard
06/22/18 01:46 PM
NC License Plates
by Zee09
06/22/18 01:31 PM
BITOG Hotline!
by Duffyjr
06/22/18 01:30 PM
Switching Additives: Flush/Rinse?
by Phishin
06/22/18 12:46 PM
increasing viscosity
by VQLT
06/22/18 12:31 PM
Who's up on their metallurgy?
by earlyre
06/22/18 11:56 AM
Replaced halogen headlight with LED
by gman2304
06/22/18 11:18 AM
Fatbrowndog0822, DRNJR, ZEK, Dudewayne, kmdz
65294 Registered Users
76 registered (77GrandPrix, 2009Edge, AandPDan, alphadog, 2004tdigls, 12 invisible), 1417 Guests and 63 Spiders online.
65294 Members
67 Forums
285792 Topics
Page 1 of 2 1 2 >
#4560929 - 11/01/17 07:26 AM Seizing Lug Nuts = Worn Wheel Bearings?
Globalksp Offline
Loc: Virginia
My 2007 Honda Fit has needed to have 3 wheel studs replaced; two on the passenger front axle and one on the driverside front.
I found the lug nuts on these ďbadĒ studs to act as if they were crossthreaded (they would break loose, unscrew a few turns, then lock) when attempting to rotate the tires during oil changes. Therefore, the passenger side issues were found 7,000 miles before the driverís side. Iíve had the studs replaced and all is well, but Iím curious why this is occurring as Iíve never experienced this issue before with other vehicles (Honda and otherwise).
The guy who drives the airport shuttle where I park my car is also a mechanic (certified Ferrari to boot!) and when talking to him about this, he mentioned that heat could be the issue and that my wheel bearings could be heating up, causing the studs to heat up, expand (and contract), thus warping them.
Curious if anyone else has experienced this or has thoughts on the theory.
Cheers,
K
2007 Honda Fit Sport Manual
#4560932 - 11/01/17 07:31 AM Re: Seizing Lug Nuts = Worn Wheel Bearings? [Re: Globalksp]
StevieC Offline
Loc: Ontario, Canada
The bearings would have to be getting red hot to cause that even if it were possible. Never seen that personally and I have seen smoking bearings when the vehicle arrived at my dads shop for repair. The bearings were also making horrendous noise at anything about 60km/hr
It is weird though. shrug
Edited by StevieC (11/01/17 07:33 AM)
'15 Dodge Journey - 90,000 KM's - SSO 5w20
'06 Hyundai Santa Fe - 535,000km - SSO 0w30 (R.I.P)
#4560934 - 11/01/17 07:32 AM Re: Seizing Lug Nuts = Worn Wheel Bearings? [Re: Globalksp]
mightymousetech Offline
Just sounds like the wheel nuts are being overtightened.
Mighty Mouse Tech
Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
#4560938 - 11/01/17 07:36 AM Re: Seizing Lug Nuts = Worn Wheel Bearings? [Re: mightymousetech]
Globalksp Offline
Loc: Virginia
Iím a fan of simple answers and this is interesting. I donít use a torque wrench when tightening my lug nuts, but never tighten them down too hard since I hate when a shop uses an air wrench to do the job and over tightens them.
I guess it will be a game of wait and see as I donít foresee myself dropping the cash to have the bearings checked.
-K
#4560941 - 11/01/17 07:39 AM Re: Seizing Lug Nuts = Worn Wheel Bearings? [Re: Globalksp]
Kira Online   content
Loc: Champlain/Hudson Valley
His warping scenario doesn't jibe with the condition you experienced.
I can tell you I've changed two bearing units (which had discolored) and their lug hardware wasn't effected.
Sounds more like a zone of threads got fatigued with time (and corrosion) and finally gave up the ghost.
While we all know "If it ain't broke, don't fix it" maybe replacing them all would've been a smart thing to do.
#4560942 - 11/01/17 07:39 AM Re: Seizing Lug Nuts = Worn Wheel Bearings? [Re: Globalksp]
Itís time to start using one.
Mighty Mouse Tech
Acura Tech
#4560945 - 11/01/17 07:42 AM Re: Seizing Lug Nuts = Worn Wheel Bearings? [Re: mightymousetech]
Globalksp Offline
Loc: Virginia
Duly noted.
#4560947 - 11/01/17 07:44 AM Re: Seizing Lug Nuts = Worn Wheel Bearings? [Re: Kira]
Globalksp Offline
Loc: Virginia
Thatís a good point and one that was overlooked by both the shop and myself. It makes me miss my previous mechanic in NJ who, I feel, would have suggested the same. He had a way of pointing out and suggesting the obvious to me. Thanks for taking up that role today.
#4560951 - 11/01/17 07:48 AM Re: Seizing Lug Nuts = Worn Wheel Bearings? [Re: Globalksp]
Danno Online   content
Loc: Northern Ontario, Canada
Had that exact same thing happen to a Chev van a few years ago. And I use a torque wrench. Had to replace the stud on a fairly new vehicle at about 30,000 kms. OE sourcing of cheap parts is my theory.
2016 Sorento SX V6 AWD
2015 KIA RIO SX
2010 Mazda 3 2.0L
2009 Venza V6 AWD
2013 Sonata 2.4L RIP in write-off crash
#4560952 - 11/01/17 07:49 AM Re: Seizing Lug Nuts = Worn Wheel Bearings? [Re: Globalksp]
IndyIan Offline
-K
It just sounds like your studs have been abused, if you can deal with them in the short term, get the worst ones replaced next time you have brakes done.
To check your bearings, go for a drive and try to stop without using your brakes hard and just feel what temp the centre of the wheels are. Slightly warm from braking is normal I think.
Also for lugs you can get a $20 torsion beam torque wrench, spec'd torque seems to be frighteningly low to me, so I add 10ftlbs and call it good.
07 Focus ZXW, 5spd manual, 206km M1 5W30
18 Outback 2.5 CVT 5km FF
#4560953 - 11/01/17 07:49 AM Re: Seizing Lug Nuts = Worn Wheel Bearings? [Re: Globalksp]
Chris142 Online   content
Loc: Deplorable in apple valley, ca
If your bearings were getting that hot your bearings would have disintegrated by now. You are describing an overtorqued situation.
02 Wrangler durablend 10w40
87 F250 traveler 15w40
04 Tahoe super-s 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
#4560956 - 11/01/17 07:51 AM Re: Seizing Lug Nuts = Worn Wheel Bearings? [Re: Globalksp]
Just want to make sure, are you still using the OE Honda wheel nuts with OE wheels?
Mighty Mouse Tech
Acura Tech
#4560968 - 11/01/17 08:12 AM Re: Seizing Lug Nuts = Worn Wheel Bearings? [Re: Globalksp]
Astro14 Online   content
Loc: Virginia Beach
I wouldn't worry about your bearings.
I also wouldn't believe a van driver who claimed to be a certified Ferrari technician, but that's just me...
Most likely, as others have said, was threads being stretched/worn by too much torque and those distorted threads just don't provide the proper engagement of the nuts leading to loosening.
I would just replace all of the studs and nuts. Seriously. A lot of work, but a loose wheel can ruin your whole day...
32 Packard 15W40
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
16 Tundra 1794 5W30 Valvoline
#4560975 - 11/01/17 08:22 AM Re: Seizing Lug Nuts = Worn Wheel Bearings? [Re: Globalksp]
Rolla07 Offline
Loc: MTL, CANADA
I hand torque my bolts and im sure they are overtorqued alot but never an issue. I have had lugs ridiculously overtorqued by shops though. So much so that i need to literally jump on the wrench to get the lugs undone.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
#4560980 - 11/01/17 08:28 AM Re: Seizing Lug Nuts = Worn Wheel Bearings? [Re: mightymousetech]
Bgallagher Offline
Loc: Boston, MA
+1 I would lean that it was over torqued and causing extra stress. That being said I would properly torque before going after wheel bearings. Wheel bearings typically have a different list of symptoms than hard lugs.
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
Page 1 of 2 1 2 >
