When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
Purolator 12 Pack L25608 $21
by hatt. 03/20/19 12:04 PM
Dealer service and franchise laws.
by BMWTurboDzl. 03/20/19 11:46 AM
Tie rod tapers
by LeakySeals. 03/20/19 11:26 AM
Quality Lug Nuts
by jcartwright99. 03/20/19 10:56 AM
More than one Reality
by beanoil. 03/20/19 10:50 AM
Reusable Oil Storage Container
by BamaE92. 03/20/19 10:37 AM
Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
GG16v, fleetwood62, varalakshmi, AllyMac, Saxman657
67569 Registered Users
101 registered members (2015_PSD, 2009Edge, 2whlgeezer, Anduril, 53' Stude, 11 invisible), 2,111 guests, and 57 spiders.
Topics286,160
Posts4,903,317
Members67,569
Most Online2,967
Mar 10th, 2019
Is the 1.4 ecotec turbo a reliable engine? #4560754
10/31/17 11:33 PM
10/31/17 11:33 PM
Atlantic, Canada
wolf_06 Offline OP
wolf_06  Offline OP
Atlantic, Canada
Im still debating if I should get a 2017 sonic RS with the 1.4 turbo. My cruze has the 1.8 naturally aspirated engine and I'm close to 100k miles on it and it's been good so far. Should I be aware of any querks and defects from the 1.4 turbo? Also, the 2017 sonics have the 1st generation 1.4 ecotec 138 HP, not the same as the new cruze with stop start technology. Do you think GM fixed the defects on the 2017 sonic 1.4 engine since they introduced it in 2011? Like the pcv valve in the valve cover and the thermostat that are not durable.
Thanks!
Re: Is the 1.4 ecotec turbo a reliable engine? [Re: wolf_06] #4560768
10/31/17 11:50 PM
10/31/17 11:50 PM
Michigan
daves87rs Offline
daves87rs  Offline
Michigan
Co worker has a 16 Cruze limited with the 1.4....flawless so far....
2019 Chevrolet Equinox LS
2006 Chevrolet Cobalt LS
Re: Is the 1.4 ecotec turbo a reliable engine? [Re: wolf_06] #4560770
10/31/17 11:52 PM
10/31/17 11:52 PM
Down Under
SR5 Offline
SR5  Offline
Down Under
try this thread for talk of the 2012 version, not sure how close it is to the newer one.
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4560504/
Castrol GTX Ultraclean 15W40 A3/B3 + Wesfil-Cooper Z154
Re: Is the 1.4 ecotec turbo a reliable engine? [Re: wolf_06] #4560793
11/01/17 12:33 AM
11/01/17 12:33 AM
Virginia
mattwithcats Offline
Virginia
The 1.4 is tough on the oil, dont run the OLM past 25%...
Use a full synthetic Dexos 1 rated 5w-30, I thin it out with a quart of Mobil 1 AFE 0W-30...
Sing Happy Birthday, or wait 30 seconds before shutting car off, cool the turbo down...
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Is the 1.4 ecotec turbo a reliable engine? [Re: wolf_06] #4560806
11/01/17 01:02 AM
11/01/17 01:02 AM
NJ
DevilsRule Offline
DevilsRule  Offline
NJ
I have a 2012 Cruze with 1.4 Turbo. I have used only Mobil 1 5w-30 and change by olm or one year. No issues so far. I believe 2017 cars use direct injection version as opposed to port injection. As long as it is maintained properly it should be ok. Don't let anyone scare you away. Also, with these engines, you DONT have to wait to shut the car off or sing happy birthday. That is out dated thinking for older turbo vehicles. Modern engineering has fixed this.....at least at GM.
Re: Is the 1.4 ecotec turbo a reliable engine? [Re: mattwithcats] #4560819
11/01/17 02:49 AM
11/01/17 02:49 AM
Slovenia EU
Kamele0N Offline
Kamele0N  Offline
Slovenia EU
Here over the pond we prefer 5w40 or even a 5w50 (for diulite monsters) oils to battle fuel diulition and to get extra protection of the engine....and we also prefer to do OCI under extreme usage schedule (OCI at 5-7kkmiles)
Can you please explain why do you want a thinner oils in DI Turbo engine?
2008 Toyota Yaris 1ND-TV 1.4 D4-D Elf FullTech FE 5w30
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10w40
Re: Is the 1.4 ecotec turbo a reliable engine? [Re: Kamele0N] #4560838
11/01/17 04:23 AM
11/01/17 04:23 AM
Texas
4WD Offline
4WD  Offline
Texas
My Cruze is not DI ... but just filled with M1 0w40 and that will be in the 1.4T when it hits 100k
Re: Is the 1.4 ecotec turbo a reliable engine? [Re: 4WD] #4560845
11/01/17 04:50 AM
11/01/17 04:50 AM
MICHIGAN USA
LEADED Offline
LEADED  Offline
MICHIGAN USA
My Son in law drives a 2012 Cruze with 287000 KM ,1.4 Turbo bullet proof replaced waterpump warr . PCMO used EDGE EXTENDED 5W 30 .
Re: Is the 1.4 ecotec turbo a reliable engine? [Re: wolf_06] #4560856
11/01/17 05:15 AM
11/01/17 05:15 AM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Sonic = Pregnant Roller Skate
Re: Is the 1.4 ecotec turbo a reliable engine? [Re: mattwithcats] #4560869
11/01/17 05:45 AM
11/01/17 05:45 AM
Minnesota
leje0306 Offline
leje0306  Offline
Minnesota
This day in age, arent these turbos water cooled?
Re: Is the 1.4 ecotec turbo a reliable engine? [Re: leje0306] #4560896
11/01/17 06:28 AM
11/01/17 06:28 AM
Canada
camrydriver111 Offline
Canada
It is and even if it wasn't I don't think it's necessary to cool them unless you were doing high performance driving.
BITOG or: How I Learned to Stop Worrying and Love the Extended OCI
Re: Is the 1.4 ecotec turbo a reliable engine? [Re: wolf_06] #4560918
11/01/17 06:59 AM
11/01/17 06:59 AM
Central Virginia
Silverado12 Offline
Silverado12  Offline
Central Virginia
I had one but not for long. I have family members with a 2012 and 2014 Cruise. They use full synthetic 5W-30 Mobil 1 and change the oil @ 5,000 miles. No issues and the highest mileage one is at 80K miles.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Is the 1.4 ecotec turbo a reliable engine? [Re: wolf_06] #4560923
11/01/17 07:18 AM
11/01/17 07:18 AM
Campbellsville, KY
Alex_V Offline
Alex_V  Offline
Campbellsville, KY
Port injected 1.4T: Need good oil changed regularly, the main things that were bad the first couple years and were fixed are the OLM calibration (10K on syn blend!), turbo oil feed line, bad batch of pistons. Things that, AFAIK, didn't get corrected and are still things to keep an eye out for on the newer ones: PCV valve, water outlet, water pump (there's an extended recall to 10 yr./150K?).
My '13 has 105K on it, Synpower @ 5K OCI most of the time, and the only one of those things it's needed is the water outlet which was 1/2 hour and like 1/2 gallon of Dexcool 50/50. Original battery, turbo, water pump, yada yada. The only thing I'm really just waiting to give up is the water pump.
I haven't paid a lot of attention to the 2nd Gen Cruze but from what I've picked up they don't have any big, chronic problems. I'm not itching to trade mine in because I'm not crazy about the potential long term maint. needs of a DI engine and IMHO the 1st Gens look way better.
To quote a friend, "Synthetics, man."
'85 GMC C3500, 454, 132K
'82 Mercedes 300CD, OM617 turbo, 173K (totaled 2018, in rehab)
'85 Mercedes 300TD, OM617 turbo, 217K (wife's)
'67 Suburban, 350, 331K
Re: Is the 1.4 ecotec turbo a reliable engine? [Re: wolf_06] #4560989
11/01/17 08:36 AM
11/01/17 08:36 AM
Fairfax, VA
TinyVoices Offline
TinyVoices  Offline
Fairfax, VA
A friend of mine has the 1.4t sonic in 2014 flavor. His is pretty modded and runs 14 flat in the 1/4. He runs Pennzoil platinum 5w30 and it seems to be fine. No excessive consumption to report. He did have the water pump replaced under warranty but otherwise, even cranked way up, it's been reliable for him.
2010 Mazda RX8 Sport - 37k miles - ????
2006 Toyota Matrix XR AWD (Wife) - 130k miles - Valvoline Max Life 5w30
Re: Is the 1.4 ecotec turbo a reliable engine? [Re: wolf_06] #4561034
11/01/17 09:25 AM
11/01/17 09:25 AM
Washington
Dylan1303 Offline
Dylan1303  Offline
Washington
The gen 2 had most of the bugs removed from the gen 1. Trifecta or bad news racing can delete the start stop with there tunes. Alot of people over at cruze talk use amsoil in the gen 2 to combat lspi. These cars make crazy good power for a 1.4l. I have a 2012 1.4 and im happy with it.
12 cruze rs 1.4t 6spd pp 5w30 tuned on 22psi
13 equinox 2.4 awd pp 5w30
