Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
Micro-Green Cut Open
by David1. 12/11/18 11:45 PM
Witch way does this valve work?
by Dylan1303. 12/11/18 11:42 PM
Santa came early..
by leoblack9. 12/11/18 11:22 PM
dropped a zip tie in my prius trans
by eljefino. 12/11/18 09:54 PM
2 Cello's - Some talented fellows right here.
by StevieC. 12/11/18 09:49 PM
Something different for sure - Punjabi Celtic
by StevieC. 12/11/18 09:40 PM
Honda eu200i hiccuping @ low idle - fixed
by Jmoney7269. 12/11/18 09:34 PM
Your dealer is here - Humor
by StevieC. 12/11/18 08:46 PM
1994 Honda Civic LX Main Relay-solder
by Gito. 12/11/18 08:43 PM
Winter/Summer Fuel Economy
by RayCJ. 12/11/18 08:33 PM
0w20 oils - NOACK
by superangrypenguin. 12/11/18 08:19 PM
Liqui Moly Special Tec AA 5w20 API SN
by Johnny248. 12/11/18 08:15 PM
Buy a brand new 1966-1977 Ford Bronco
by StevieC. 12/11/18 07:50 PM
2012 Accord,QSUD 5W20,WIX 57356 filter,3K miles
by aquariuscsm. 12/11/18 07:05 PM
Check out this awsome work!
by Chris142. 12/11/18 06:47 PM
200,000 miles
by Marco620. 12/11/18 06:29 PM
tcoffin014, Schm1d, EagleC, Dinka, MechanicGuy
66654 Registered Users
45 registered members (alarmguy, benhen77, BadMonkey, 97K15004WD, 69Torino, 8 invisible), 965 guests, and 32 spiders.
Topics294,964
Posts4,924,981
Members66,654
Most Online2,553
Oct 27th, 2018
Open Governor Arm when I start up #4560659
10/31/17 08:01 PM
10/31/17 08:01 PM
NY
snorman Offline OP
snorman  Offline OP
NY
My Briggs and Stratton 126M02-1525-F1 has a auto choke that the second it starts opens the governor arm all the way and the engine dies. So is it the spring or thermostat opening it? I am guessing spring since the thermostat is still cold.
Thoughts?
Re: Open Governor Arm when I start up [Re: snorman] #4560966
11/01/17 07:09 AM
11/01/17 07:09 AM
Virginia
GravelRoad Offline
GravelRoad  Offline
Virginia
You have an air vane governor autochoke system. On cold start-up, the spring keeps the choke closed. When the engine starts, the flywheel fan opens the choke fully via the air vane governor. When the engine is fully warmed-up, the thermostat keeps the choke off so when stopping/starting the engine when hot it does not flood.
If the engine starts then quickly dies, there are two main things to check/do.
1) make sure spring is not missing or disconnected.
2) The main jet is clogged (bowl nut is also the main jet) needs to be cleaned. Check for water/debris in bowl if jet is removed.
2016 Subaru Outback Premium 2.5. PP 5w30 oem filter
2018 Hyundai Kona 1.6T. Lifetime dealer free oil/filter change
Re: Open Governor Arm when I start up [Re: snorman] #4561012
11/01/17 07:58 AM
11/01/17 07:58 AM
Houston, Texas
motor_oil_madman Offline
Houston, Texas
I know on my honda gx pressure washer it frequently will be set at idle or just a little higher when trying to start, when I know I shut it off at full throttle. Usually has trouble starting if it's not At least 3/4 throttle.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Open Governor Arm when I start up [Re: GravelRoad] #4561052
11/01/17 08:42 AM
11/01/17 08:42 AM
Virginia
GravelRoad Offline
GravelRoad  Offline
Virginia
Originally Posted By: GravelRoad
You have an air vane autochoke system. On cold start-up, the spring keeps the choke closed. When the engine starts, the flywheel fan opens the choke fully via the air vane. When the engine is fully warmed-up, the thermostat keeps the choke off so when stopping/starting the engine when hot it does not flood.
Edit: Removed the word governor. (Brain [censored]) blush
You have a mechanical governor that is at full throttle until engine starts.
Re: Open Governor Arm when I start up [Re: snorman] #4561198
11/01/17 11:32 AM
11/01/17 11:32 AM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
It sounds like the governor is working as it should. Like said, the governor opens the throttle plate based on engine RPM. No RPM means wide open throttle. If it won't stay running, it sounds like you have a another issue going on such as fuel quality, a carb or spark issue.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: Open Governor Arm when I start up [Re: JTK] #4561545
11/01/17 06:53 PM
11/01/17 06:53 PM
NY
snorman Offline OP
snorman  Offline OP
NY
All changed and new
Re: Open Governor Arm when I start up [Re: GravelRoad] #4561547
11/01/17 06:53 PM
11/01/17 06:53 PM
NY
snorman Offline OP
snorman  Offline OP
NY
Thanks,I will check and put a new spring in
