Pulled a sample just to check. Lead is a little concerning. Car isn't tracked. I did put a bottle of Techron in it for a tank...can't imagine that would cause lead to increase.
That's a good and stout M1 0w-40 sample. Some of the recent UOA's I've seen have had the detergents and Zn/Mo/B quite a bit lower.
From previous Bitog MOU:
Lead is a soft, sacrificial wear metal used on surfaces such as bearings. Lead based Babbitt alloys. Commonly found in main crankshaft journal bearings and contaminated fuels. Other sources include leaded fuels and gasoline octane improvers.
