OCI. With short trips. Nissan 4 liter
by Gawardawg
06/19/18 06:52 AM
Approach Watching on the Beach @ St Maarten ...
by LoneRanger
06/19/18 06:41 AM
Honda Accord Needs Shocks; Front, Back, or Both?
by tc1446
06/19/18 05:50 AM
How much oil does your oil filter hold?
by Snagglefoot
06/19/18 05:44 AM
better day
by mx5miata
06/19/18 05:26 AM
BRAVO to Officer Wheeles......
by Sayjac
06/19/18 05:17 AM
People Watching ....Airport style.
by ZZman
06/19/18 04:24 AM
Subaru's at play...
by OneEyeJack
06/19/18 03:50 AM
Treating a 2003 Jetta
by llmercll
06/19/18 01:41 AM
Brakes not working - brake pedal sinks
by tookien
06/19/18 12:42 AM
Dave thinks I can make it 12--15k
by Marco620
06/19/18 12:26 AM
'05 Impala front wheel "squeal". Cost !
by Lee4212
06/19/18 12:16 AM
One Dollar Per Gallon?
by Y_K
06/18/18 11:53 PM
Walmart Tightening up Returns
by John_K
06/18/18 10:21 PM
flare nut wrench set
by spasm3
06/18/18 09:46 PM
Auto trans temperature scanner - help!
by JeffKeryk
06/18/18 09:45 PM
How much is too much?
by Sealbilly
06/18/18 09:34 PM
Correct oil filter for a Vovlo S60, 2003
by earthworm
06/18/18 09:17 PM
Prestone coolant $3.50 Target YMMV
by pda1122
06/18/18 09:13 PM
Need Windows 7 Pro ISO
by MONKEYMAN
06/18/18 08:33 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
75 registered (adamrc, 69Torino, advocate, 91camarosRS, 1foxracing, 08z06, 6 invisible), 1180 Guests and 39 Spiders online.
65265 Members
67 Forums
285582 Topics
#4560525 - 10/31/17 06:53 PM 2015 Porsche Boxster S 3.4L | M1 0W40 FS |3,196 Mi
madibob Offline
Loc: Minnesota
Pulled a sample just to check. Lead is a little concerning. Car isn't tracked. I did put a bottle of Techron in it for a tank...can't imagine that would cause lead to increase.
2002 Toyota Tacoma 3.4L 4X4
2000 Ford F350 7.3L 4X4
#4560542 - 10/31/17 07:00 PM Re: 2015 Porsche Boxster S 3.4L | M1 0W40 FS |3,196 Mi [Re: madibob]
Jeffs2006EvoIX Offline
Loc: Imperial Valley, California
Use this UOA as a baseline, re check after 5k miles with your new oil. If the number is the same or worse, HOUSTON WE "MAY" HAVE A PROBLEM.
Dont panic at this point.
Did you buy the car new? or used?
Jeff
"You don't have to be crazy to do this... But it helps." Bob Ross.
#4560633 - 10/31/17 08:21 PM Re: 2015 Porsche Boxster S 3.4L | M1 0W40 FS |3,196 Mi [Re: madibob]
rooflessVW Online   content
Loc: North Carolina
A little lead never hurt anybody. The engine is still new.
Stick with 5k for now and keep an eye on it.
"Zed's dead baby, Zed's dead."
#4560665 - 10/31/17 09:06 PM Re: 2015 Porsche Boxster S 3.4L | M1 0W40 FS |3,196 Mi [Re: madibob]
69GTX Offline
Loc: Connecticut
That's a good and stout M1 0w-40 sample. Some of the recent UOA's I've seen have had the detergents and Zn/Mo/B quite a bit lower.
From previous Bitog MOU:
Lead is a soft, sacrificial wear metal used on surfaces such as bearings. Lead based Babbitt alloys. Commonly found in main crankshaft journal bearings and contaminated fuels. Other sources include leaded fuels and gasoline octane improvers.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
