It's AMSOIL®, not Amsoil
by Rat407
06/25/18 06:39 AM
VW Passat 2007
by madRiver
06/25/18 06:18 AM
Review: CVJ Remanufactured CV Axles
by The Critic
06/25/18 03:40 AM
Towing without 85w140?
by OilFilters
06/25/18 03:07 AM
2015 VW GTI autobahn oil questions
by Skyalbo
06/24/18 11:28 PM
Corrosion in the garage - salt or humidity?
by Kurtatron
06/24/18 11:13 PM
Darn dogs
by AZjeff
06/24/18 10:21 PM
New GC?
by Bullwinkle007
06/24/18 10:04 PM
The guy with the plexiglass head on you tube
by andyd
06/24/18 09:21 PM
'07 Pacifica Timing Belt Replacement success
by 92saturnsl2
06/24/18 09:10 PM
SAE 90 v 85/140
by Knuckle078
06/24/18 09:10 PM
Mobil 1 5W30-HM 5,011 mi, 1999 Ford Escort
by WA1DH
06/24/18 08:45 PM
Schaeffer's oil reviews on Amazon
by zfasts03
06/24/18 07:41 PM
Decent MP3 player
by Ed_T
06/24/18 07:08 PM
Letgo
by Donald
06/24/18 06:52 PM
Tire buying advice
by supton
06/24/18 06:23 PM
Two versions of M1 5w30 ESP now?
by Patman
06/24/18 06:21 PM
No older cars in New York State?
by Oldtom
06/24/18 06:19 PM
2009 Taurus strut mount noise
by terry274
06/24/18 04:38 PM
A3/B3 vs A3/B4, big difference or irrelevant?
by FordCapriDriver
06/24/18 03:36 PM
dhy808, ROD_Z, lozpxs, danthemanx07, FunktasticLucky
65319 Registered Users
95 registered (alcyon, andyd, 1foxracing, Bandito440, 2015_PSD, 15 invisible), 1308 Guests and 66 Spiders online.
65319 Members
67 Forums
285959 Topics
Page 1 of 3 1 2 3 >
#4560447 - 10/31/17 05:54 PM 17’ Powerstroke oil
Redland1 Offline
Loc: San Antonio Texas
Recently traded in my 13’ Duramax with 307,000 trouble free heavy hauling miles for a 17’ Powerstroke.From what I am reading in the owners manual I fall in Severe duty maintenance and am wondering what oil grade I should use that meets the ford WSS-M2C171-F1 oil spec? I use my truck strictly for hauling loads up to 28,000LBS plus pickup and cargo securement weight and 99.9 % highway miles.On my old DMAX I was using 15W40 at 8-9k intervals.
#4560473 - 10/31/17 06:13 PM Re: 17’ Powerstroke oil [Re: Redland1]
mattwithcats Offline
Loc: Virginia
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
#4560496 - 10/31/17 06:33 PM Re: 17’ Powerstroke oil [Re: Redland1]
RedOakRanch Offline
Loc: Central Coast California
I'd be tempted to run a 10w30 after Blackstone's article on thinner oils but if you pull that much weight and don't short trip it stick with any quality 5w40 or 15w40.
1994 Ford Crown Vic 206k-Frankenbrew 0w20,30,40!
2005 Chevy 1500 Crewcab 4X4 178k-BC 0w30 $2/qt
2016 Outback 2.5 Limited 56k-M1 EP 0w20 $2/qt
#4560572 - 10/31/17 07:25 PM Re: 17’ Powerstroke oil [Re: Redland1]
Balrog006 Offline
Loc: West Michigan
Deere Plus II 0w40 or Mobil 1 Delvac 5w40
Deere oil
06 MDX 211K+ P Plat 0w20, A01
08 CRV 271K+ VSyn w/ML, A01
04 JD L130 720H, Mobil S 5w30
13 JD 2032r 300H, JD Plus 50 ii 15w40
M1Delvac 5w40 in OPE
#4560592 - 10/31/17 07:37 PM Re: 17’ Powerstroke oil [Re: Redland1]
CT8 Offline
Loc: Idaho
You had excellent service from the GMC keep us well informed on the Ford.
"Don't let your preconceived notions get in the way of facts."
Geoff Metcalf
#4560625 - 10/31/17 08:11 PM Re: 17’ Powerstroke oil [Re: Redland1]
Donald Offline
Loc: Upstate NY
The issue also is if you look for a 5W40 synthetic you should look for a CJ-4 rather than a CK-4.
I have been running Rotella T6 that is CJ-4 in my Powerstroke.
2015 Ford F250 w/Powerstroke
#4560634 - 10/31/17 08:22 PM Re: 17’ Powerstroke oil [Re: Redland1]
Langanobob Offline
Loc: Reno, Nevada
There are a lot of oils on that Ford spec approved list! If I had invested in a new Powerstroke that I was going tomuse for heavy hauling I'd go with the Lubrication Engineers Monolec Super Syn Heavy Duty Engine Oil 5w40. Probably the best, and most expensive, oil on the list.
I'm a Powerstoke driver myself (1996 7.3l) and I can't help but ask what it was that made you switch to Ford after the Duramax gwve you such good service? I like that Ford is making their own Diesel engines right here in the USA.
#4560639 - 10/31/17 08:29 PM Re: 17’ Powerstroke oil [Re: Redland1]
2015_PSD Online   content
Loc: SE Texas
Pick up some Chevron Delo 400 LE 5W-40 CJ-4 at your local Wal-Mart. It is $19.97 a gallon. Unless you can find one of the approved CK-4 oils, Delo is good to go.
2018 MB AMG GLC43 3.0L Coupe - M1 0W-40/OEM
2018 MB C300 2.0L - M1 0W-40/OEM
2015 F-250 6.7L PS Diesel - Delo 5W-40/CQ Blue
2014 Explorer 3.5L Limited - M1 AFE 0W-20/FU
#4560735 - 10/31/17 10:42 PM Re: 17’ Powerstroke oil [Re: Langanobob]
beanoil Offline
Loc: Midwest, Illinois
Originally Posted By: Langanobob
I'm a Powerstroke driver myself (1996 7.3l) and I can't help but ask what it was that made you switch to Ford after the Duramax gave you such good service?
popcorn popcorn
Another long time PSD owner here wondering the same thing.
I'll add that Valvoline Premium Blue will give excellent results as well.
Just make sure for warranty that you use an oil from Ford's blessed list, and keep the receipts.
Don't give them any chances to deny anything.
Edited by beanoil (10/31/17 10:43 PM)
beanoil: Tough under heat, real dirty afterwards.
#4560832 - 11/01/17 03:29 AM Re: 17’ Powerstroke oil [Re: beanoil]
Redland1 Offline
Originally Posted By: beanoil
[quote=Langanobob]
popcorn popcorn
The Duramax exceeded my expectations as far as Durability,breakdowns, maintenance cost,and fuel mileage .Outside of regular maintenance the intake heater fried at 80,000 miles which I had replaced at the stealership and if I would have known at the time I would have just deleted it,and also at 146,000 miles the DEF tank heater took a [censored] and I just deleted it for a couple hundred more than the cost of tank replacement.The truck had a 40hp tow tune from 146k to 250k and then I dropped it to stock power.
Oil changes were done at 8k-9k with Rotella,Delo,Delvac,and later Phillips 66 fleet supreme.Fuel filters at 25-35,000 miles with ACDELCO fuel filters and a couple of times I used the Baldwin equivalent which I did not like because they plugged up much faster and one even left me on the side of the road, and also because the center gasket would stay attached to the filter head assembly on removal,made in China go figure.As far as the Allison I would change fluid and filter at 46k with Dexron VI.
As why I went to Ford it all came down to price.My first choice was the L5P Duramax but the lowest priced work truck with an enclosed bed not a flat bed was $55k.The XLT Super Duty with SXT package was $48900 with all the rebates Ford was having, and my very last option,like way down at the very bottom of the list was the RAM which was the same price as the SD so it was a no brainer.
Edited by Redland1 (11/01/17 03:34 AM)
#4560865 - 11/01/17 05:41 AM Re: 17’ Powerstroke oil [Re: Redland1]
leje0306 Offline
Loc: Minnesota
[quote=Langanobob]
popcorn popcorn
Huh. http://www.laurabuickgmc.com/VehicleDeta...e-IL/3054276043
#4560895 - 11/01/17 06:26 AM Re: 17’ Powerstroke oil [Re: leje0306]
Redland1 Offline
[quote=Langanobob]
popcorn popcorn
I should have been more specific.Crew cab,long bed,DRW not SRW for hauling the weight I haul.
#4560930 - 11/01/17 07:28 AM Re: 17’ Powerstroke oil [Re: Redland1]
claluja Offline
Loc: MD
OP - I'd change fuel fulters on this one sooner than 25K. Powerstrokes are very sensitive to water in fuel. Probably their achilles heel. I do mine at 10-15K now.
2014 F250 6.7L PSD
2006 Sequoia 4.7L
2005 E500 5.0L
1997 4Runner 3.4L
#4560979 - 11/01/17 08:27 AM Re: 17’ Powerstroke oil [Re: claluja]
Loc: SE Texas
+1 - stay on top of draining the fuel filter bowl (not sure what the configuration is on the 2017+ models as there has been a "quiet" design change) and I recommend the use of Stanadyne, Diesel Kleen, Howe's or the like to help with water in the fuel. Ford will not honor your warranty if they discover water in the fuel system during a repair.
#4560988 - 11/01/17 08:34 AM Re: 17’ Powerstroke oil [Re: Langanobob]
turbowhistle Offline
Loc: Maryland
I am now a Cummins guy, 2011 Ram 3500 4x4 Laramie, no issues, great rig. I used to own a 2002 F350 4x4 with the 7.3, made for Ford by International. Great truck,great motor, ran like a top and easy to work on. I know the engines in the New Ford Trucks are made by Ford and are much different in many ways compared to my old 7.3. I mostly used the MC 15w40 oil, 5 quart jugs from WM with no issues. The MC oil was made for Ford by Conoco Phillips, I am guessing that is still true. There are many good oils available, I would say as long as it is Ford Approved and the correct oil is being used for climate temps, OCI's and the correct oil filter is used, you should be good. In my 2011 Ram, I run the Shell Rotella T6 5W40, another great oil.
Edited by turbowhistle (11/01/17 08:36 AM)
Page 1 of 3 1 2 3 >
