stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
Mobil 1 Cartridge Filters On Clearance at WM
by IndyFan. 03/25/19 06:19 PM
Ford Unibody Pickup
by SubLGT. 03/25/19 05:52 PM
Flow How: PourPoint warmer than CCV "0w" Temperature 0w20
by oil_film_movies. 03/25/19 05:31 PM
Oil filter material list?
by shibby6600. 03/25/19 04:49 PM
Insights on commission paying jobs?
by Pat in Speedway. 03/25/19 04:29 PM
Decode a vehicle VIN for production Month & Year?
by Ed_Flecko. 03/25/19 04:29 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
111 registered members (2015_PSD, anndel, ArrestMeRedZ, AndyB, 2010Civic, 17 invisible), 1,897 guests, and 67 spiders.
Topics286,431
Posts4,908,112
Members67,622
Most Online2,967
Mar 10th, 2019
Will the 12k Rhino Ramps work with a Non Eco Cruze #4560433
10/31/17 05:42 PM
10/31/17 05:42 PM
Union County, PA
2James1 Offline OP
2James1  Offline OP
Union County, PA
Wondering if anyone uses Rhino ramps with a non eco chevy cruze with success? Specifically a 2015 Cruze LT.
2005 Chevrolet Malibu V6
Castrol Edge HM 10w-40/ Purolator Pureone
2015 Cruze LT 1.4T
Dealer Oil/Filter
Re: Will the 12k Rhino Ramps work with a Non Eco Cruze [Re: 2James1] #4560446
10/31/17 05:53 PM
10/31/17 05:53 PM
Occupied Virginia
Bottom_Feeder Offline
Occupied Virginia
In what regard? Clearing the front fascia/bumper?
Re: Will the 12k Rhino Ramps work with a Non Eco Cruze [Re: Bottom_Feeder] #4560489
10/31/17 06:25 PM
10/31/17 06:25 PM
Union County, PA
2James1 Offline OP
2James1  Offline OP
Union County, PA
Yes. Wondering if it rubs at all.
2015 Cruze LT 1.4T
Dealer Oil/Filter
Re: Will the 12k Rhino Ramps work with a Non Eco Cruze [Re: 2James1] #4560498
10/31/17 06:35 PM
10/31/17 06:35 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Older pic from another thread. This is what I gotta do and it works.
Me: 13' VW GTI 3 door 6 speed manual
Re: Will the 12k Rhino Ramps work with a Non Eco Cruze [Re: 2James1] #4560731
10/31/17 10:36 PM
10/31/17 10:36 PM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
My 06 xBox is a lot lower than that and it goes up my Rhino Ramps with just a slight touch as it starts.
Just try it. Maybe get someone to watch as you start. Looks like plenty of room. You can hardly hurt anything with even the slightest amount of care.
Re: Will the 12k Rhino Ramps work with a Non Eco Cruze [Re: 2James1] #4561097
11/01/17 10:37 AM
11/01/17 10:37 AM
The Old North State
Sayjac Offline
Sayjac  Offline
The Old North State
Using a measuring tape and yard stick if available you can get good idea if the 12k Rhinos will work before purchase. The topic Rhinos are rated 17 degree incline.
Using the right triangle calculator linked below you'll be looking for angle A. Find the lowest point to the ground on the front valence, measure and record length straight down to ground, make a mark on ground at that point. Then using a yardstick or tape measure, stuff it under the tire tread as far as possible and measure the length to mark you made on ground, record. Then you have two sides of the right triangle, plug the numbers in and angle A will tell you the maximum critical angle the ramps can be found. Some vehicles have a rubber-like extension from valence in front of tires, if it touches 'a bit' doesn't hurt ime.
I would 'speculate' topic vehicle will work.
Right Triangle Calculator.
Re: Will the 12k Rhino Ramps work with a Non Eco Cruze [Re: 2James1] #4561468
11/01/17 06:17 PM
11/01/17 06:17 PM
Oakville, Ontario
Patman Offline
Global Moderator
Patman  Offline
Global Moderator
Oakville, Ontario
I had the grey Rhino ramps for a long time, and my Corvette could fit on them even though it's lowered an inch. But it just barely fit on them and so I got some 56" Race Ramps now which are much easier to use with their gentle incline.
2018 Corvette, 9k, M1 ESP Formula 5w30 & NAPA Gold
2006 Civic EX Coupe, 149k, PUP 5w20 & Fram Ultra
2010 BMW 328i X-Drive,113k, GC 0w40 & Fram Ultra
Re: Will the 12k Rhino Ramps work with a Non Eco Cruze [Re: 2James1] #4561496
11/01/17 06:55 PM
11/01/17 06:55 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
My Sonata clears mine just fine
2015 Hyundai Sonata 2.4L 92k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
