Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
Mobil 1 Cartridge Filters On Clearance at WM
by IndyFan. 03/25/19 06:19 PM
Ford Unibody Pickup
by SubLGT. 03/25/19 05:52 PM
Flow How: PourPoint warmer than CCV "0w" Temperature 0w20
by oil_film_movies. 03/25/19 05:31 PM
Oil filter material list?
by shibby6600. 03/25/19 04:49 PM
Insights on commission paying jobs?
by Pat in Speedway. 03/25/19 04:29 PM
Decode a vehicle VIN for production Month & Year?
by Ed_Flecko. 03/25/19 04:29 PM
Wix 51522 vs Fram XG9837
by RDY4WAR. 03/25/19 04:13 PM
Rural King: 20K Lumen LED Tripod Worklight $34.93
by skyactiv. 03/25/19 03:55 PM
How do I find out which Honda Engine?
by Gebo. 03/25/19 03:08 PM
Moltex increases their footprint, hiring
by OVERKILL. 03/25/19 02:53 PM
Rislone complete fuel system gas treatment
by Fitter30. 03/25/19 02:29 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
122 registered members (77GrandPrix, agpatel, Aero540T, anndel, Andya, ammolab, 11 invisible), 2,070 guests, and 65 spiders.
Topics286,425
Posts4,908,062
Members67,622
Most Online2,967
Mar 10th, 2019
QS Defy vs Pennzoil HM 5w30 #4560387
10/31/17 04:45 PM
10/31/17 04:45 PM
WI
HoosierJeeper Online content OP
HoosierJeeper  Online Content OP
WI
Oil change coming up on my Liberty...the leaking has gotten worse under Maxlife so I'd like to try another oil out. I know it might be hope against hope though lol. Up until this week it's been good enough not to drip, now it's dripping over night (nickel sized spot) so I'm hoping to at least get it back to where it doesn't mark its territory.
I had a leak in my XJ that Maxlife didn't touch but Pennzoil more or less stopped. That's my first go to now, but I'm open to ideas. Figured I would ask about QS Defy, guessing it's similar to Pennzoil HM.
Thanks!
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: QS Defy vs Pennzoil HM 5w30 [Re: HoosierJeeper] #4560553
10/31/17 07:10 PM
10/31/17 07:10 PM
OBX & Central FL
NormanBuntz Offline
NormanBuntz  Offline
OBX & Central FL
You'll have trouble finding Defy now in stores. Replaced by QS High Mileage, which I'd estimate is about the same as Pennzoil HM. Don't know if the new formula has as much zinc as the old stuff.
2017 Honda Odyssey SE, 18K
2013 Honda Accord LX, 59K
2007 Honda Ridgeline RTS, 89K
2007 Infiniti M35, 107K
Re: QS Defy vs Pennzoil HM 5w30 [Re: HoosierJeeper] #4560564
10/31/17 07:20 PM
10/31/17 07:20 PM
WI
WI
That's what I meant, forgot about the name change, don't care about having a lot of zinc! If a mod could switch Defy to HM that'd be great!
Re: QS Defy vs Pennzoil HM 5w30 [Re: HoosierJeeper] #4560691
10/31/17 09:41 PM
10/31/17 09:41 PM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
AAP was clearing out the 2016 QS Defy HM jugs the past month...along with the newer 2016/2017 QS HM jugs. The versions have been watered down a bit since the more potent QS Defy API-SL was readily available up to 1-2 yrs ago. I wouldn't imagine a big difference with QS HM syn blend vs the Pennzoil HM.
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: QS Defy vs Pennzoil HM 5w30 [Re: HoosierJeeper] #4560708
10/31/17 10:03 PM
10/31/17 10:03 PM
WI
WI
OK thanks. Does anyone have any other oil recommendations? I don't have any brand allegiance, would even try synthetic but I'm guessing that would be counter-intuitive for a leaker.
Re: QS Defy vs Pennzoil HM 5w30 [Re: HoosierJeeper] #4560718
10/31/17 10:19 PM
10/31/17 10:19 PM
NC
lawrencerd Offline
lawrencerd  Offline
NC
I'm running the QS HM Synblend in my Jeep and girlfriend's Suzuki...it's running well, not that Pennzoil wouldn't. For the same price roughly, it's marketed as a blend where the PHM is marketed as conventional. Whether it actually has a greater synthetic content, I have no clue.
Re: QS Defy vs Pennzoil HM 5w30 [Re: HoosierJeeper] #4560732
10/31/17 10:40 PM
10/31/17 10:40 PM
South Texas
Insertcoolname Offline
South Texas
QS HI MI oil is ILSAC GF5 rated API SN resource conserving. It seal conditioners and is a synthetic blend. since it is a resource conserving oil, at operating temperature it is on the thinner side of whatever weight you are using.
Pennzoil hi mi is conventional. API SN only. Thats it. It is not a synthetic blend or resource conserving. It runs a little on the thicker side.
Since you claim your jeep is leaking valvoline max life which is also ILSAC GF5 rated.(thin side) It may benefit your jeep to use
Pennzoil Hi mileage since its a little thicker that may benefit your engine and slow a leak.
04 Camry 2az-fe 209k
M1 5w30
PremiumGuard filter
Re: QS Defy vs Pennzoil HM 5w30 [Re: HoosierJeeper] #4560748
10/31/17 11:23 PM
10/31/17 11:23 PM
kendall, wa
yaris0128 Offline
yaris0128  Offline
kendall, wa
From my experience with my brothers 2000 Ford Focus it leaks like a siv with any oil including high mileage oils with the exception of Pennzoil High Mileage where I end up adding no top off oil in its 3,000 OCI's. Now with other HM oils I will end up adding 1-2 quarts of top off. Super Tech, Maxlife and Quaker State Defy have all been failures except Pennzoil.
07 Yaris 76k Chev Sup 5w30
95 Del Sol 140k Chev Sup 5w30
06 Mustang GT 68k SuperTech 5w20
93 Ranger 177k SuperTech HiMi 5w30
94 Ninja ZX600 80k Rotella 15w40
12 KLX250S 13k Rotella 15w40
Re: QS Defy vs Pennzoil HM 5w30 [Re: HoosierJeeper] #4560910
11/01/17 06:52 AM
11/01/17 06:52 AM
WI
WI
Sounds like Pennzoil is the one to try then. Thanks everyone! I'll update this thread periodically.
Re: QS Defy vs Pennzoil HM 5w30 [Re: HoosierJeeper] #4561521
11/01/17 07:20 PM
11/01/17 07:20 PM
Crawfordville FL
SilverFusion2010 Online content
SilverFusion2010  Online Content
Crawfordville FL
Try a thicker 10w-30
I like M1 HM 10w-30. It's almost a 10w-40 and can be had for about $13 a 5qt jug after MIR
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
