WPA 3 Wireless Security Coming
by StevieC. 09/22/18 01:16 AM
Robo Calls/Telemarketers
by Nick1994. 09/22/18 12:47 AM
What oil should be used!
by BigShug681. 09/22/18 12:28 AM
VW Electronic Parking Brake
by StevieC. 09/21/18 11:48 PM
Leak Sealing and Mould Treatments?
by Ducked. 09/21/18 11:44 PM
UPS / FedEx / USPS
by StevieC. 09/21/18 11:21 PM
puncture repair question
by neo3. 09/21/18 10:55 PM
Can I use a 10 amp extension cord for...
by gregk24. 09/21/18 10:48 PM
In the unlikely event of a crash
by StevieC. 09/21/18 10:09 PM
Craigslist time wasters
by Anduril. 09/21/18 09:41 PM
Who runs a 20wt here?
by StevieC. 09/21/18 07:31 PM
Need help on edit profile
by jetmech1. 09/21/18 06:34 PM
Oil thickness on the dipstick
by Idlewild294. 09/21/18 05:40 PM
Chinese WIX Trans filter bad, let me down..
by jetmech1. 09/21/18 04:47 PM
Gen 8 Accord rear brakes-What tool?
by fdcg27. 09/21/18 04:30 PM
Ammeters?
by buck91. 09/21/18 03:55 PM
Need Help with Double D Knock Out Punch
by user52165. 09/21/18 03:41 PM
JRMFt11, Navyretired, aikwae, ScottRousell, Direct_Rejection
66036 Registered Users
24 registered members (Bjornviken, arthuro, Brian123, chance, BoiseBound, Buzzsaw, 2 invisible), 728 guests, and 31 spiders.
Topics290,810
Posts4,850,759
Members66,036
Most Online3,590
Jan 24th, 2017
Supertech Power Steering Fluid #4560369
10/31/17 04:25 PM
10/31/17 04:25 PM
Va
FFeng7 Offline OP
FFeng7  Offline OP
Va
I recently purchased a quart of Supertech power steering fluid to do a few drain and fills of the power steering system on my Dakota. Reading the back of the bottle while refilling the system I noticed that it said to only use for topping off the reservoir and not for complete system refill. I never noticed this before on power steering fluid. I only did one exchange of the fluid using the turkey baster method. I'll probably just go buy a different brand of fluid to do the rest. Does anyone know why it would have such a warning on the bottle? Could it be a poor quality fluid? Thank you in advance!
2002 Dakota Quad Cab 4x4-Delo XLE 10w30-Fram PH16 Filter
2007 Cobalt LT-Supertech High Mileage Synthetic 5w30-Parts Plus Filter
Re: Supertech Power Steering Fluid [Re: FFeng7] #4560378
10/31/17 04:34 PM
10/31/17 04:34 PM
Indiana
dlundblad Online happy
dlundblad  Online Happy
Indiana
You either want something with the MS-5931 spec or just ATF+4. (not sure on your truck)
Not sure how picky the non ATF+4 systems are, but Valvone PSF is cheap. As is Oreilly house brand. Both meet the spec.
03 Jeep WJ 4.0 200k Castrol Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 177k M1 0w40 Mahle OX149D
97 Chevy Blazer 4.3 149k Rotella T5 10w30 Supertech ST3980
Re: Supertech Power Steering Fluid [Re: FFeng7] #4560455
10/31/17 05:58 PM
10/31/17 05:58 PM
USA
slacktide_bitog Offline
USA
I've never needed to flush or change power steering fluid, so I have no idea hide
The only time you'd be doing a complete system refill is when you're replacing something in the PS system.
What spec does your PS call for?
Re: Supertech Power Steering Fluid [Re: FFeng7] #4560505
10/31/17 06:43 PM
10/31/17 06:43 PM
The Midwest
skyactiv Offline
skyactiv  Offline
The Midwest
Maybe they are afraid you'll do a flush on a Honda/Acura?
Me: 13' VW GTI 3 door 6 speed manual
Re: Supertech Power Steering Fluid [Re: FFeng7] #4560513
10/31/17 06:47 PM
10/31/17 06:47 PM
MI
HorseThief Offline
HorseThief  Offline
MI
The Supertech power steering fluid contains a stop leak additive. Because of which, it's designed for topping off until the leak stops. You probably don't want super concentrated stop leak floating around in your system for long. Get some Prestone or Valvoline PSF and exchange as much as you can, or do a full flush and fill with ATF+4, if you want to switch.
Generally, I like most Supertech products, but you really have to read carefully on a few of them.
I saw a brown dog
Re: Supertech Power Steering Fluid [Re: FFeng7] #4560537
10/31/17 06:59 PM
10/31/17 06:59 PM
WI
HoosierJeeper Offline
WI
02 Libertys spec'd the Mopar PS and then got switched to ATF+4, if you flush it out good I would just use ATF+4. Easy to get.
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Supertech Power Steering Fluid [Re: HorseThief] #4560983
11/01/17 08:31 AM
11/01/17 08:31 AM
Boston, MA
Bgallagher Offline
Bgallagher  Offline
Boston, MA
Never knew that. With that knowledge I wouldn't flush the system with it. if you do one turkey baster refill you should be OK but if you're looking for a complete change I would stick with another fluid. Supertech fluids are generally very good but as mentioned, it is def. worth reading the label fully to make sure the product works for your application.
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
