WPA 3 Wireless Security Coming
by StevieC. 09/22/18 01:16 AM
Robo Calls/Telemarketers
by Nick1994. 09/22/18 12:47 AM
What oil should be used!
by BigShug681. 09/22/18 12:28 AM
VW Electronic Parking Brake
by StevieC. 09/21/18 11:48 PM
Leak Sealing and Mould Treatments?
by Ducked. 09/21/18 11:44 PM
UPS / FedEx / USPS
by StevieC. 09/21/18 11:21 PM
puncture repair question
by neo3. 09/21/18 10:55 PM
Can I use a 10 amp extension cord for...
by gregk24. 09/21/18 10:48 PM
In the unlikely event of a crash
by StevieC. 09/21/18 10:09 PM
Craigslist time wasters
by Anduril. 09/21/18 09:41 PM
Who runs a 20wt here?
by StevieC. 09/21/18 07:31 PM
Need help on edit profile
by jetmech1. 09/21/18 06:34 PM
Oil thickness on the dipstick
by Idlewild294. 09/21/18 05:40 PM
Chinese WIX Trans filter bad, let me down..
by jetmech1. 09/21/18 04:47 PM
Gen 8 Accord rear brakes-What tool?
by fdcg27. 09/21/18 04:30 PM
Ammeters?
by buck91. 09/21/18 03:55 PM
Need Help with Double D Knock Out Punch
by user52165. 09/21/18 03:41 PM
JRMFt11, Navyretired, aikwae, ScottRousell, Direct_Rejection
66036 Registered Users
21 registered members (Bjornviken, Buzzsaw, arthuro, BoiseBound, Bailes1992, Bman90, 2 invisible), 729 guests, and 35 spiders.
Topics290,810
Posts4,850,758
Members66,036
Most Online3,590
Jan 24th, 2017
2011 Prius and 2012 Corolla 15" wheels the same? #4560292
10/31/17 02:46 PM
10/31/17 02:46 PM
Eastern Wa
Corollaman Offline OP
Eastern Wa
I found some 2011 Prius wheels 15" I have a 2012 Corolla that has 16" wheels. Would these wheels work? They are both 5x100 bolt pattern and I know the base corolla uses 15" wheels. This is for snow tires. Thanks
Re: 2011 Prius and 2012 Corolla 15" wheels the same? [Re: Corollaman] #4560329
10/31/17 03:20 PM
10/31/17 03:20 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
They'll probably work, although, the internet says the offsets are slightly different, higher offset on the Prius wheels might push the tire too far inwards on the Corolla and rub.
https://www.wheel-size.com/size/toyota/corolla/2012/
https://www.wheel-size.com/size/toyota/prius/2011/
Re: 2011 Prius and 2012 Corolla 15" wheels the same? [Re: EdwardC] #4560332
10/31/17 03:27 PM
10/31/17 03:27 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
That may be the case if the wheels were larger. But on smaller wheels the effect would be negligible with such a slight difference in offset is my guess.
Re: 2011 Prius and 2012 Corolla 15" wheels the same? [Re: Corollaman] #4560334
10/31/17 03:38 PM
10/31/17 03:38 PM
Chicago, IL
EdwardC Offline
EdwardC  Offline
Chicago, IL
I don't think the offset measurement changes with regards to wheel diameter, but either way I agree with you that it's a pretty tiny difference. I also wasn't paying attention to the wheel widths when I was looking at the site.
The 15x6 Prius wheel with 45mm of positive offset puts the inner wheel lip at pretty much the exact same place as a 16x6.5 wheel with 39mm positive offset. So yes, I'd say those Prius wheels are perfect for a winter tire set!
Re: 2011 Prius and 2012 Corolla 15" wheels the same? [Re: Corollaman] #4560357
10/31/17 04:08 PM
10/31/17 04:08 PM
CA
The Critic Offline
The Critic  Offline
CA
Slightly off topic -
I have a set of these wheels (2011 Prius, 15") that you can have for free (just pay shipping), and I'll even include the wheel covers. Let me know.
2011 Toyota Prius - 173k - Various 0W-20 (Brew)
2007 Honda Accord 2.4 - 131K - Mobil 1 EP HM 5W-30
Re: 2011 Prius and 2012 Corolla 15" wheels the same? [Re: Corollaman] #4561179
11/01/17 12:18 PM
11/01/17 12:18 PM
California
nthach Offline
nthach  Offline
California
The bolt patterns should be the same, the 3rd gen Prii use discs on all 4 wheels, so it does need a bit more offset to clear them. I think you should be fine.
Re: 2011 Prius and 2012 Corolla 15" wheels the same? [Re: Corollaman] #4561201
11/01/17 12:34 PM
11/01/17 12:34 PM
Alberta, Canada
Smokescreen Offline
Smokescreen  Offline
Alberta, Canada
I have Prius wheels on my Corolla. The lighter weight Prius wheels means less unsprung weight translates to better city fuel economy. There are a couple of lighter choices out there but at much more cost and I liked to keep the OEM quality. They fit with no issues, but this was in 2010.
13 Civic Si 2.4L- 69Kkms(43Kmi)-PP,Wix
09 Corolla 1.8L-380Kkms(237Kmi)-PP,Denso
05 LeSabre 3.8L-210Kkms(134Kmi)-PP,Wix
03 Sierra 2500 6.0L-204Kkms(127Kmi)-PP,Wix
All with mpg > EPA
Re: 2011 Prius and 2012 Corolla 15" wheels the same? [Re: Corollaman] #4561216
11/01/17 12:44 PM
11/01/17 12:44 PM
Alberta, Canada
Smokescreen Offline
Smokescreen  Offline
Alberta, Canada
I have also added a front pan that goes from the chin of the bumper to the radiator:
Also, I have the entire upper grill blocked from behind as well as in the winter I have 66% of the lower grill blocked when the extreme cold hits:
All with mpg > EPA
Re: 2011 Prius and 2012 Corolla 15" wheels the same? [Re: Smokescreen] #4561220
11/01/17 12:48 PM
11/01/17 12:48 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Grills are what you cook on. The grille in front of your car has an "E" at the end of it. smile
Re: 2011 Prius and 2012 Corolla 15" wheels the same? [Re: Corollaman] #4561238
11/01/17 01:05 PM
11/01/17 01:05 PM
Eastern Wa
Eastern Wa
Thanks for the information and help. I got a set of Prius wheels with snow tires mounted on them for $100, the tires have a season or two left so I think its a good deal.
Re: 2011 Prius and 2012 Corolla 15" wheels the same? [Re: Corollaman] #4561362
11/01/17 04:08 PM
11/01/17 04:08 PM
Alberta, Canada
Smokescreen Offline
Smokescreen  Offline
Alberta, Canada
nice find.
All with mpg > EPA
