The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Problems After Adding 2 Stroke To Diesel
by InfernoRedBeast. 03/19/19 07:47 PM
Amsoil filter
by Bill_W. 03/19/19 07:01 PM
My $1 ocod 4k
by Pinoak. 03/19/19 06:58 PM
GMC tailgate latch repair question
by aquariuscsm. 03/19/19 06:49 PM
Can I Use Maple Syrup Instead Of Oil ?
by Warstud. 03/19/19 06:09 PM
Should criminals be given a second chance?
by ZZman. 03/19/19 04:28 PM
Oil recommendations for old car
by chromedome. 03/19/19 04:06 PM
Reply Box Window
by das_peikko. 03/19/19 03:45 PM
mm2020, emepher, headoff93, yahtzee, jmd
67560 Registered Users
31 registered members (berniedd, Agnosto, Bailes1992, carlprop, c502cid, 4 invisible), 651 guests, and 60 spiders.
Topics286,097
Posts4,902,472
Members67,560
Most Online2,967
Mar 10th, 2019
Motorcraft battery maintenance #4559974
10/31/17 09:05 AM
10/31/17 09:05 AM
West Michigan
buck91 Offline OP
buck91  Offline OP
West Michigan
SO I believe i have the original motorcraft battery in my 2011 F150 but I'm not sure. Does anybody know if/where the date would be and how to interpret it? It also appears to have a little green "glowing" window which I assume to be a battery indicator of some type? Mine is strongly glowing green which I would think is a good thing...
It does get "topped up" with a digital charger about once a year (before winter).
Edit: Ford also recommends a silver calcium SLA battery to function correctly with that dang smart charging system. Does anybody know who/where carries these?
2011 F150 4x4 5.0L
1996 Mustang GT 5spd/ragtop
Re: Motorcraft battery maintenance [Re: buck91] #4560000
10/31/17 09:33 AM
10/31/17 09:33 AM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
the green window is only one cell. if another cell fails it may still be green.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: Motorcraft battery maintenance [Re: buck91] #4560030
10/31/17 10:04 AM
10/31/17 10:04 AM
TX, USA
JMJNet Offline
JMJNet  Offline
TX, USA
Did you do the load test on the battery?
  • 2017 Toyota Sienna
Re: Motorcraft battery maintenance [Re: JMJNet] #4560110
10/31/17 11:06 AM
10/31/17 11:06 AM
Canada
Lolvoguy Offline
Lolvoguy  Offline
Canada
Exactly.
Without a load test your simply making assumptions as to it's condition.
I'm wishing for one of these from Santa this Christmas
https://www.amazon.ca/Quicklynks-Battery...ct_sims?ie=UTF8
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Motorcraft battery maintenance [Re: buck91] #4560120
10/31/17 11:18 AM
10/31/17 11:18 AM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
If the label is black it is factory. If the label is red it is a replacement. Ford dealers carry Motorcraft batteries for less than almost anyone else. Oreillys tried to charge $190 for a BXT-65-650 that has a list price of $129.95.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Motorcraft battery maintenance [Re: buck91] #4560125
10/31/17 11:26 AM
10/31/17 11:26 AM
MN
tmorris1 Offline
tmorris1  Offline
MN
Just had the battery die on my 2012 F-150 and the eye was still green. I have not sure what happened, but it was working fine and I stopped for gas and it wouldn't start.
Re: Motorcraft battery maintenance [Re: Lolvoguy] #4560139
10/31/17 11:39 AM
10/31/17 11:39 AM
West Michigan
buck91 Offline OP
buck91  Offline OP
West Michigan
Exactly.
Not exactly at all. If you read my post I am asking only two questions. What does the eye mean and where is the mfg date. No assumption about battery condition.
2011 F150 4x4 5.0L
Re: Motorcraft battery maintenance [Re: buck91] #4560233
10/31/17 01:06 PM
10/31/17 01:06 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
If the battery has a red label, the production date is on the top label in the bottom left corner. The serial number is the production date.
Re: Motorcraft battery maintenance [Re: buck91] #4560234
10/31/17 01:08 PM
10/31/17 01:08 PM
USA
mk378 Offline
mk378  Offline
USA
The eye thing is a hydrometer. It shows if the acid is charged vs discharged but not whether the plates are healthy vs worn out. And it only tests one cell.
Re: Motorcraft battery maintenance [Re: Lolvoguy] #4560315
10/31/17 03:07 PM
10/31/17 03:07 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
Exactly.
Not exactly, that is not a load tester
a load tester would be
https://www.harborfreight.com/500-amp-carbon-pile-load-tester-91129.html
Re: Motorcraft battery maintenance [Re: buck91] #4560316
10/31/17 03:08 PM
10/31/17 03:08 PM
MI
HorseThief Offline
HorseThief  Offline
MI
Is there a TSB they can reference that recommends an AGM battery? Otherwise, the best everyday price is $170 (3yr warranty)on the Duracell from Sams Club. Next up, pep boys has the bosch 65-AGM for $140 (4yr warranty) with $60 online coupon code. Next up, Sears has the diehard AGMs on sale for decent prices right now. Otherwise, there's always independant battery shops that are worth checking out.
I assume they would recommend an AGM for faster charging ability - The smart/regenerative charging system is the dumbest thing manufacturers have come out with. I don't understand what was wrong with just regulating to 13.4-14.8V depending on temperature. For that matter, a straight 14.4V would serve just fine. The most a battery is taking in charge is going to be 25-30 amps. At 14V, thats just about 425W or about .5-.6HP - not a significant load. I'd like to see what the actual MPG gain is of the system in comparison to old-style dumb charging.
FWIW, handheld electronic load testers give a pretty decent picture of cranking amps and health - especially when testing in a vehicle and you can do a crank-voltage test (how low the voltage dips while turning over the car). Otherwise, the best test to do is a full true carbon-pile load test at 50% of the battery's rated cranking amps. An 800-1000A load tester serves well for this purpose. I use and recommend Autometer brand. For a handheld tester, I use both mid-tronics and argus brands and both are extremely accurate for cranking amps, but can't put an extended load on the battery to weed out a weak cell.
I saw a brown dog
Re: Motorcraft battery maintenance [Re: buck91] #4560396
10/31/17 04:51 PM
10/31/17 04:51 PM
Santa Barbara, CA
bdcardinal Offline
bdcardinal  Offline
Santa Barbara, CA
Motorcraft does offer an AGM in group 65, p/n BHAGM-65. They are $199.99 and have 750CCA. Never sold them before, most people don't want to spend the money.
Re: Motorcraft battery maintenance [Re: buck91] #4560743
10/31/17 11:17 PM
10/31/17 11:17 PM
upstate NY
dustyroads Offline
dustyroads  Offline
upstate NY
When I bought my F150 earlier this year, the only thing wrong was a bad battery. Not knowing about the "smart charging" system, I just stopped at the local Interstate battery distributor and asked for their recommended replacement. They sold me a MTP65 (Mega Tron Plus with 850 CCA if I recall correctly).
I took a few minutes to switch out the battery and it's been fine for almost 8 months. I don't know if there will be problems or a short lived battery or....but I have had great luck with Interstate for many years in both personal and commercial use. My understanding is that you can disconnect the sensor from the battery cable and have a normal charge like the old days, but I haven't tried it myself.
2013 F150 XLT 5.0 4X4 104k miles
Edge 5W-30 / Fram 10575
