Remote Start by Android Auto App ?
by LoneRanger. 04/19/19 04:53 PM
Continental PureContact LS
by The Critic. 04/19/19 03:31 PM
Dark/Black Rear Differential Oil - UOA?
by The Critic. 04/19/19 03:25 PM
Best oil for Honda Rancher?
by jayjr1105. 04/19/19 03:20 PM
Store bought kimchi?
by Quattro Pete. 04/19/19 03:15 PM
2020 KIA Soul Turbo
by Malo83. 04/19/19 03:03 PM
erratic Speedometer
by tookien. 04/19/19 02:59 PM
Another airbag recall
by mclasser. 04/19/19 02:44 PM
Which barb fitting is less likely to leak?
by zorobabel. 04/19/19 02:36 PM
Can these bucket style tappets be reused?
by atikovi. 04/19/19 01:34 PM
Scratched My New Car. Help Me Fix
by GeorgeKaplan. 04/19/19 01:23 PM
Talk about manual labor...
by AZjeff. 04/19/19 12:42 PM
Car didn't burn an ounce of oil... 7K OCI
by jayjr1105. 04/19/19 12:13 PM
Top 6 OEM Passenger Tire Sizes in 2018
by SubLGT. 04/19/19 11:12 AM
CRC intake valve cleaner, safe to use?
by Backstache. 04/19/19 10:06 AM
'94 Grand Am Steering Column Pivot Pins
by benjamming. 04/19/19 10:02 AM
Why the need to replace suspension springs?
by WyrTwister. 04/19/19 09:47 AM
incorrect mileage on reciept
by 1978elcamino. 04/19/19 09:17 AM
Oregon PowerSharp for chainsaw
by Fitter30. 04/19/19 09:16 AM
new tire 4 years old
by 1978elcamino. 04/19/19 08:51 AM
carve200, Harteeco, fatafox, CurtC, LockCracker
67850 Registered Users
98 registered members (bbhero, ArrestMeRedZ, 2015_PSD, Anduril, Astro14, 17 invisible), 2,169 guests, and 32 spiders.
Topics287,749
Posts4,933,796
Members67,850
Most Online2,967
Mar 10th, 2019
Performax/JiffyLube ~6200mi. cut open #4559360
10/30/17 03:03 PM
10/30/17 03:03 PM
The Old North State
Sayjac Offline OP
Sayjac  Offline OP
The Old North State
This is a PO-9A, 3387A equivalent filter run on an 09 Equinox, about 5 months. No tears, tight uniform pleating. And while I've seen wider louver openings there are plenty of them and they open in two directions. Confident plenty of flow, no restriction. So the element itself quite good.
The one negative as you'll see is cuts in the adbv, which was still relatively flexible. The fix for this would be so easy. Just narrow the center tube outlet hole end slightly and decrease/eliminate the taper/bevel on it and the adbv won't touch the inner edge of the inlet holes. The inlet holes are not that sharp, wouldn't cut the 5 mil gloves I had on. It's just the direct pressure on them with the adbv from leaf spring. Even with that, no start up rattle in this GM thread end up application.
Replaced with some Havoline ProDS 5w30 I got for ~$8 jug on O'R closeout and a Napa Gold 1040 I got recently for $3.60 at local Napa 40% off sale. As far as oil and filter combination, likely the best OC the vehicle has seen in it's life.
Re: Performax/JiffyLube ~6200mi. cut open [Re: Sayjac] #4559370
10/30/17 03:15 PM
10/30/17 03:15 PM
Houston, TX
2015_PSD Online content
2015_PSD  Online Content
Houston, TX
Looks really good for a jobber style filter even with the cuts in the ABDV. Thanks for the C&P.
2018 Mercedes Benz AMG GLC43 3.0L Bi-Turbo [Castrol Edge 0W-40 & Purflux filter]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum Euro 0W-40 & Mann filter]
Re: Performax/JiffyLube ~6200mi. cut open [Re: Sayjac] #4559379
10/30/17 03:34 PM
10/30/17 03:34 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
Thanks for c&p Sayjac smile
Looks ok aside from ADBV
Re: Performax/JiffyLube ~6200mi. cut open [Re: 2015_PSD] #4559381
10/30/17 03:42 PM
10/30/17 03:42 PM
The Old North State
Sayjac Offline OP
Sayjac  Offline OP
The Old North State
You're welcome 2015_PSD and car51. Yeah it's one of those looks good, but. Looking at the base plate design and inlet holes shape before cutting, wasn't too surprised to find the cuts. Still was hoping for better. Some solace, I didn't buy/install it.
Re: Performax/JiffyLube ~6200mi. cut open [Re: Sayjac] #4559512
10/30/17 06:34 PM
10/30/17 06:34 PM
Houston, Texas
WellOiled Offline
WellOiled  Offline
Houston, Texas
Sayjac,
Until now, I could not visualize what was being discussed between the designs.
Your well done C&P fixes that.
Thanks for the C&P.
2004 Ford Ranger 4.0L V6
Valvoline Advanced Full Synthetic HM 5W30 + WIX 51372
Re: Performax/JiffyLube ~6200mi. cut open [Re: WellOiled] #4559550
10/30/17 06:54 PM
10/30/17 06:54 PM
The Old North State
Sayjac Offline OP
Sayjac  Offline OP
The Old North State
WellOiled, glad you can see the difference.
Now if the guys at Puro could do the same, and fix it.
Re: Performax/JiffyLube ~6200mi. cut open [Re: Sayjac] #4559556
10/30/17 06:58 PM
10/30/17 06:58 PM
Houston, Texas
WellOiled Offline
WellOiled  Offline
Houston, Texas
+2
