Bad cylinder 3 misfire.
by Hemispheres. 12/14/18 02:49 PM
Small leak at toilet base - bad wax ring?
by Oro_O. 12/14/18 02:38 PM
Ok I take it back about Keurig
by StevieC. 12/14/18 02:29 PM
Edge 5W-30 7.9k miles '13 F150 5.0
by dustyroads. 12/14/18 02:11 PM
Stick with WSS-M2C946-A?
by BlueFog. 12/14/18 01:42 PM
How engine capacity affects fuel consumption?
by NICAT. 12/14/18 01:12 PM
Pep Boys
by Zee09. 12/14/18 12:41 PM
How early in engines life can I start to extend OCI
by Doublehaul. 12/14/18 12:33 PM
EFB and AGM batteries charge faster?
by slybunda. 12/14/18 11:20 AM
97.5 Regal GS climate control illumination
by 71Chevyguy. 12/14/18 11:04 AM
Cool train site for Canadians
by Papa Bear. 12/14/18 10:09 AM
Putting together a groups 3/4/5 synthetic list
by MrWideTires. 12/14/18 10:02 AM
VW Atlas V6 Oil
by motech. 12/14/18 09:32 AM
Great shakes, it's Yahtzee... or a Taurus
by redhat. 12/14/18 09:03 AM
MWI Micro Wave Ignition
by Danno. 12/14/18 08:52 AM
8k Miles on M1 EP 2017 Subaru 3.6
by BISCUT. 12/14/18 08:47 AM
Wrong ATF Fluid in my 07 Chevy Impala
by CM613. 12/14/18 08:39 AM
Hyundai motor oil
by pbm. 12/14/18 08:16 AM
Which Exhaust Manifold Should I Buy
by Miller88. 12/14/18 08:10 AM
wsalopek, jcr1293, maxwellk, BlueFog, Frank_G35
66682 Registered Users
108 registered members (barryh, Big Dave, 03s, bdcardinal, ARB1977, 94astro, 13 invisible), 2,013 guests, and 54 spiders.
Topics295,068
Posts4,927,195
Members66,682
Most Online2,553
Oct 27th, 2018
Coolant on serpentine belt #4559268
10/30/17 11:52 AM
10/30/17 11:52 AM
Northern Kentucky
901Memphis Offline OP
Northern Kentucky
I spilled a fair amount of G05 on my serpentine belt while I filling my radiator, and I think the belt is slipping on my PS pump now. Any quick fixes until I can replace the belt? I heard simple green from one source? Brake cleaner?
2012 Chevy Cruze LT 1.4T - 50k
2002 Buick Century 130k - Built 4T65e(Maxlife) - Edge 0w40 + Fram XG3980
Re: Coolant on serpentine belt [Re: 901Memphis] #4559271
10/30/17 11:55 AM
10/30/17 11:55 AM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
Just pour some water on it and then go for a drive. It should works itself off unless the belt is really old. I've spilled coolant on belts many times with no issue.
yup
Re: Coolant on serpentine belt [Re: 901Memphis] #4559283
10/30/17 12:20 PM
10/30/17 12:20 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
Brake cleaner will work fine.
Re: Coolant on serpentine belt [Re: 901Memphis] #4559299
10/30/17 12:38 PM
10/30/17 12:38 PM
NE,Ohio
Rand Offline
Rand  Offline
NE,Ohio
I would spray it down carefully with a normal cleaner such as simple green or 409, then pour some hot water on it from a bucket.. carefully.. and let dry.
Whatever you do.. dont use belt dressing on it.
Re: Coolant on serpentine belt [Re: 901Memphis] #4559303
10/30/17 12:42 PM
10/30/17 12:42 PM
MN
Tman220 Offline
Tman220  Offline
MN
Don't over think in, plain old water is fine. There is nothing in coolant water cant take care of.
2012 Regal GS Turbo PP 5w30
1994 Camaro Z28 LT1 355 CI, 430 RWHP PP 5W30
Re: Coolant on serpentine belt [Re: Tman220] #4559312
10/30/17 01:01 PM
10/30/17 01:01 PM
On the road Midwest
Ihatetochangeoil Offline
On the road Midwest
^^^ This. No sarcasm or belittlement (is that a word?) intended...Common sense...What happens under your hood when it rains and you hit shallow standing water? I've gone to a car wash (with the motor running) sprayed under the hood with a plastic garden sprayer and simple green, rinse off with the (spot free low pressure) rinse.
Isn't coolant designed to be mixed with water?
2003 Lesabre Celebration Edition
2004 Lesabre
2004 Lesabre Celebration Edition
Re: Coolant on serpentine belt [Re: Merkava_4] #4559361
10/30/17 02:05 PM
10/30/17 02:05 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
Maybe too well. I would be worried about long term belt damage.
2015 Ford F250 w/Powerstroke
Re: Coolant on serpentine belt [Re: 901Memphis] #4559434
10/30/17 03:56 PM
10/30/17 03:56 PM
Anaheim, CA
zorobabel Offline
zorobabel  Offline
Anaheim, CA
Water, not brake cleaner!
1997 Maxima 190k, QSGB 5w30+QSUD 5w30 (2:1), PL14477
2004 Corolla 193k, VWB 5w20 + SSS 10w40, MGL4967
Re: Coolant on serpentine belt [Re: 901Memphis] #4559545
10/30/17 05:51 PM
10/30/17 05:51 PM
Michigan
researcher Offline
researcher  Offline
Michigan
definitely water.. I've had this happen before, just poured some distilled water over it and it washed off. I used distilled so no minerals/deposits would get on the belt. Serpentine belts today are made of EPDM from what I remember. It's not the neoprene of the past where it would soak up stuff. That's the nice thing about EPDM much stronger/resistant.
Re: Coolant on serpentine belt [Re: 901Memphis] #4559756
10/30/17 10:20 PM
10/30/17 10:20 PM
Northern Kentucky
Northern Kentucky
Yeah I already poured some water on it I was just concerned it wasn't aggressive enough which is why I was asking. I was thinking of using some of my Mpro7 gun cleaner which is similar to simple green iirc.
