Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
Micro-Green Cut Open
by David1. 12/11/18 11:45 PM
Witch way does this valve work?
by Dylan1303. 12/11/18 11:42 PM
Santa came early..
by leoblack9. 12/11/18 11:22 PM
dropped a zip tie in my prius trans
by eljefino. 12/11/18 09:54 PM
2 Cello's - Some talented fellows right here.
by StevieC. 12/11/18 09:49 PM
Something different for sure - Punjabi Celtic
by StevieC. 12/11/18 09:40 PM
Honda eu200i hiccuping @ low idle - fixed
by Jmoney7269. 12/11/18 09:34 PM
Your dealer is here - Humor
by StevieC. 12/11/18 08:46 PM
1994 Honda Civic LX Main Relay-solder
by Gito. 12/11/18 08:43 PM
Winter/Summer Fuel Economy
by RayCJ. 12/11/18 08:33 PM
0w20 oils - NOACK
by superangrypenguin. 12/11/18 08:19 PM
Liqui Moly Special Tec AA 5w20 API SN
by Johnny248. 12/11/18 08:15 PM
Buy a brand new 1966-1977 Ford Bronco
by StevieC. 12/11/18 07:50 PM
2012 Accord,QSUD 5W20,WIX 57356 filter,3K miles
by aquariuscsm. 12/11/18 07:05 PM
Check out this awsome work!
by Chris142. 12/11/18 06:47 PM
200,000 miles
by Marco620. 12/11/18 06:29 PM
tcoffin014, Schm1d, EagleC, Dinka, MechanicGuy
66654 Registered Users
48 registered members (alarmguy, benhen77, BadMonkey, 97K15004WD, 69Torino, 8 invisible), 986 guests, and 35 spiders.
Topics294,964
Posts4,924,981
Members66,654
Most Online2,553
Oct 27th, 2018
Fram XG and K&N filters cut open - no pics #4559222
10/30/17 10:36 AM
10/30/17 10:36 AM
Wa
Skanky Offline OP
Skanky  Offline OP
Wa
Fram was from 2003 deville, 9800 miles and as expected perfect in every way. Mobile 1 5-30 for high mileage. About half way through added Liqui Moly MSO2
K&N was from 2015 Durango 3.6 8700 miles and perfect except very slight wavy pleats in a few places. New K&N went back in and like the last new one, pleats go in straight. Castrol Titanium 5-20 and liquid moly MSO2, next time Fram XG going in.
One thing to note the Durango has had a slight lifter tick for the first 1 second at start up since new. Once the Liqui moly went in and after the third start up/drive that noise is almost not noticeable, way less that before but still there just barely audible.
When doing the OC on the Durango I followed instructions and loosened the oil filter cap before draining (actually removed it), after pan was drained I replaced the oil filter and once it was screwed all the way in more oil began draining out the pan, about another pint. As it was screwing down the last few turns I cold feel it pushing down a spring. Anyone else experience this? Seems odd to me. Last oil change I already had the plug back in before installing the new oil filter so don't know if it happened before?
Also when I put the first K&N in I measured it against the old Mopar filter and was same length including the bottom Oring section.
Re: Fram XG and K&N filters cut open - no pics [Re: Skanky] #4563978
11/04/17 01:15 PM
11/04/17 01:15 PM
Wa
Skanky Offline OP
Skanky  Offline OP
Wa
Guess no one had this happen on a pentastar V6 oil drain, next time after I pull the filter I will look in the canister to see if it has oil trapped in it. Also for those who really wanted pics just look at this post, looked same LOL
Fram Ultra XG7317 - 12,049 miles - Cut Open
Re: Fram XG and K&N filters cut open - no pics [Re: Skanky] #4567530
11/08/17 08:52 AM
11/08/17 08:52 AM
MN
RD_3 Offline
RD_3  Offline
MN
I just changed the oil on both of my vans a couple weeks back and everything went normal as it always does. I do not "feel" a spring when turning the oil cap on the '14.
The FU I took out was pretty wavy, it only had about 7500 miles on it. I bought a couple new FU's and was not impressed with the plastic cage at the bottom (with the o ring). They both had excess plastic bits on the corners of the legs of the cage. I returned them for MO-349's.
I installed the new filter while the oil was still draining and did not notice more oil drain.
2015 Malibu LTZ 2.5L - 30K
2013 DGC SXT 3.6L - 55K
2014 DGC SXT 3.6L - 70K (traded in)
2007 DGC SXT 3.8L - 127K (traded in)
Re: Fram XG and K&N filters cut open - no pics [Re: RD_3] #4567641
11/08/17 10:32 AM
11/08/17 10:32 AM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
I have been buying Wix ones for my FIL's PentaStar because of this very issue with other manufacturers.
'18 Dodge Grand Caravan GT - AMSOIL SS 5w20
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF
Re: Fram XG and K&N filters cut open - no pics [Re: Skanky] #4568201
11/08/17 07:16 PM
11/08/17 07:16 PM
Wa
Skanky Offline OP
Skanky  Offline OP
Wa
The oil had all but stopped draining when I screwed the filter down and another 1/2-1 pint came out. Had it been still in the normal drain I would have never noticed it. I will be inspecting the FU I have on hand, I did not notice anything like that on the K&Ns. There is a spring in the cap I wonder if the bottom -O-ring did not slip in at first causing the spring to compress some? I hope the end did slip into the hole otherwise I would bet filter is bypassing? It did seem like towards the end I didn't feel the spring anymore like maybe the bottom slipped into place.
Re: Fram XG and K&N filters cut open - no pics [Re: Skanky] #4568215
11/08/17 07:28 PM
11/08/17 07:28 PM
Wa
Skanky Offline OP
Skanky  Offline OP
Wa
First OC I just loosened the oil filter cap until draining was done and I put drain plug in before I replaced the filter. Next time I will be looking in the canister to see if there is still oil in it after the filter is removed. I'm sure the filter bottom oring was oiled but it is an oring so I assume there is some tension on it as it goes in the housing.
Re: Fram XG and K&N filters cut open - no pics [Re: Skanky] #4568247
11/08/17 07:55 PM
11/08/17 07:55 PM
NY
demarpaint Offline
demarpaint  Offline
NY
I'll have to take note. I remove the cap and filter, then drain the oil. I let it drain at least an hour. When I collect the oil for recycling, I have [censored] near 6 quarts of oil to recycle, so I doubt there's a 1/2-1 pint hung up in there that would drop when installing the new filter. shrug
God Bless Our Troops
Re: Fram XG and K&N filters cut open - no pics [Re: Skanky] #4571396
11/11/17 11:38 PM
11/11/17 11:38 PM
Wa
Skanky Offline OP
Skanky  Offline OP
Wa
just cut another fram ultra, 2007 wrx 9800 miles no issues once again.
