Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
One license plate in a Two-Plate State
by bunnspecial. 03/21/19 02:07 PM
TPMS Units Honda
by Chester11. 03/21/19 01:58 PM
Another brake question
by supton. 03/21/19 01:54 PM
BOUGHT WRONG OIL FILTER
by IBelieveinlube. 03/21/19 01:47 PM
miscible ester, using is as oil additive ?
by pep808. 03/21/19 01:23 PM
LT Oil Temps
by StillLearning. 03/21/19 12:44 PM
What kind of lug nut is this?
by LeakySeals. 03/21/19 12:38 PM
Need help finding a riding mower with $1,500 budget
by MetalSlug. 03/21/19 11:55 AM
Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
SAE 20 non-detergent oil
by fleetwood62. 03/21/19 10:39 AM
PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Honda st1300 LED light
by Zuraxus. 03/21/19 08:26 AM
Paperboy, Flinch, AlanGonzales, Jrealstreeter, DarkFrontier
67576 Registered Users
107 registered members (1WildPig, 2012AccentSE, ABerns, 2K2AcuraTL, 69Torino, 1leater, 8 invisible), 2,163 guests, and 152 spiders.
Topics286,196
Posts4,904,009
Members67,576
Most Online2,967
Mar 10th, 2019
How long can an oil filter last? 10k? 20k? 100k? #4559107
10/30/17 09:30 AM
10/30/17 09:30 AM
USA
wowthisexists Offline OP
USA
In theory, anyone ever run across anecdotes where filters last way longer than the replacement interval?
A fuel filter lasts 100k miles. Does an oil filter REALLY only last 3k? I'd think it would last longer than a fuel filter.
Do you change oil filter more frequently than the new 10k Synth oil interval?
Re: How long can an oil filter last? 10k? 20k? 100k? [Re: wowthisexists] #4559109
10/30/17 09:34 AM
10/30/17 09:34 AM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
It depends on the application, contamination load, filter build etc.
That said I have run an Amsoil EAO filter 20,000 miles (32,000km) before just to test it. No issues but they are rated for 25,000 miles.
'18 Dodge Grand Caravan GT - 25k KM - AMSOIL SS 0w20
Fear 20wt oils if you want your engine to last. smirk2
Re: How long can an oil filter last? 10k? 20k? 100k? [Re: wowthisexists] #4559136
10/30/17 10:01 AM
10/30/17 10:01 AM
Michigan
A_Harman Offline
A_Harman  Offline
Michigan
I have run Fleetguard Stratapore filters 30k miles many times on my Dodge diesel.
Also Fram Ultra and Purolator Boss 18k miles.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
Re: How long can an oil filter last? 10k? 20k? 100k? [Re: wowthisexists] #4559141
10/30/17 10:05 AM
10/30/17 10:05 AM
SW Ontario Canada
KGMtech Offline
KGMtech  Offline
SW Ontario Canada
The comparison to the fuel filter is not really valid. The oil filter is designed to collect dirt and other debris that are generated by engine operation, leakage of the air filter, or mechanical wear of parts either in their normal state of wear or from catastrophic failure mode. That last mode is the "Hail Mary" aka "I hope this failure doesn't go too far downstream".
A fuel filter, despite having regular additions of fluid of un-known cleanliness, doesn't have to worry about catching "failure mode" debris from the engine or even the fuel pump itself. Plus the viscosity of gasoline with temperature changes is no where near what engine oil can experience in like conditions.
Honda, Nissan, maybe others often suggest in their owners manual that oil filter changes can be done every other oil change. To go much more than this recommendation is to risk that the increasingly dirty (plugged) oil filter might go into routine bypass mode = no filtration at all. You decide it the cost savings warrants this risk?
If you install a oil filter that is specifically rated for a long-duration, and you trust the maker, go ahead and change at their suggested interval.
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: How long can an oil filter last? 10k? 20k? 100k? [Re: wowthisexists] #4559145
10/30/17 10:07 AM
10/30/17 10:07 AM
Kalifornia Kollective
BrocLuno Offline
BrocLuno  Offline
It's about what kind of engine you have (gas, ethanol, LPG or diesel) and how dirty it is. What kind of media in the filter, media area and porosity.
5.7L V8 with a little filter running on gas with carb, maybe 12K ... 1.8L with port injection and big filter, 12K or more easily. Pre-ECM diesel with 1M miles, maybe 15~20K (2 gal sock filter). Propane hauler running on LPG, any engine, filter prolly good for 25K at least smile
Re: How long can an oil filter last? 10k? 20k? 100k? [Re: wowthisexists] #4559193
10/30/17 10:59 AM
10/30/17 10:59 AM
Connecticut
69GTX Offline
69GTX  Offline
Connecticut
How about a top quality, synthetic filter (1000-1500 miles per year) in a warm weather, low dust, low humidity climate? The cannister won't rust very fast. The filter media won't get filled very quickly. Couldn't the filter easily go 3-7 yrs in such an environment?
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: How long can an oil filter last? 10k? 20k? 100k? [Re: wowthisexists] #4559214
10/30/17 11:30 AM
10/30/17 11:30 AM
Pocatello, Idaho
compratio10_5 Offline
Pocatello, Idaho
How do you define filter life? I know of at least three ways: 1- When the filter media deteriorates to the point that it rips, tears or disintegrates. 2- When the filter is loaded to the extent that increasing pressure drop allows the pressure relief valve to open, thus bypassing unfiltered oil around the filter media. Since this happens routinely during below freezing start-ups, it is a matter of degree. 3- When the accumulation of solids in the filter begin to desorb or flush through the filter on pressure or flow surges at such a rate that engine wear increases. (Refer to SAE papers #650866 and #680258 by Fram Employees). My rule of thumb is that cellulose media oil filters are good for 6 months or 5000 miles, composite cellulose and synthetic media oil filters are good for 1 year or 10,000 miles and completely synthetic media oil filters with wire mesh backing are good for several years or 20,000 miles. However there are too many variables and not enough accurate information published by filter manufacturers to know with any degree of certainty. Are there any filter manufacturers willing to step up to this challenge?
It's not what you don't know that hurts, it's what you think you know that ain't so. Will Rogers
Re: How long can an oil filter last? 10k? 20k? 100k? [Re: wowthisexists] #4559721
10/30/17 09:50 PM
10/30/17 09:50 PM
Illinois
tig1 Online content
tig1  Online Content
Illinois
For me oil filters say on my engines 10K which is one OCI.
2007 Ford Fusion 239,000 miles
M1 0-20 EP
2017 Ford Fusion 67K
M1 0-20 EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: How long can an oil filter last? 10k? 20k? 100k? [Re: tig1] #4559734
10/30/17 10:09 PM
10/30/17 10:09 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Same here for one OCI just like my TP.
2004 Corolla 129987
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: How long can an oil filter last? 10k? 20k? 100k? [Re: wowthisexists] #4559736
10/30/17 10:18 PM
10/30/17 10:18 PM
WI.
dblshock Offline
dblshock  Offline
WI.
I'm hoping x2 or 20k on Ultras
16 Civic Coupe Touring 38k
640:1 TCW-3 E091
Edge 0/40 XG7317
Firehawk Indy 500
06 4Runner SR5 146k
640:1 TCW-3
PP 5/30 XG3614
Falken Wildpeak AT3W
Re: How long can an oil filter last? 10k? 20k? 100k? [Re: wowthisexists] #4559799
10/31/17 03:50 AM
10/31/17 03:50 AM
N.Ohio
Lubener Offline
Lubener  Offline
N.Ohio
That's like asking how long a pair of shoes would last. Answer= it depends
The "thinking" man's friend.
Re: How long can an oil filter last? 10k? 20k? 100k? [Re: Lubener] #4559864
10/31/17 06:42 AM
10/31/17 06:42 AM
Indianapolis, IN
dnewton3 Offline
Global Moderator
dnewton3  Offline
Global Moderator
Indianapolis, IN
We so have a winner here!
It truly depends on a whole host of inputs in this "what if ...." question.
I will state with certainty that oil filters can typically last a lot longer than most BITOGers would fear to tread.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: How long can an oil filter last? 10k? 20k? 100k? [Re: wowthisexists] #4559883
10/31/17 07:03 AM
10/31/17 07:03 AM
North Carolina
rooflessVW Online content
rooflessVW  Online Content
North Carolina
Oil filter on my car is only needed (per the owner's manual) every 30k miles.
"Zed's dead baby, Zed's dead."
Re: How long can an oil filter last? 10k? 20k? 100k? [Re: wowthisexists] #4560335
10/31/17 03:41 PM
10/31/17 03:41 PM
California
DGXR Offline
DGXR  Offline
California
If my driving was all 65 MPH highway, in moderate temperatures and light traffic, I'd have the most efficient and lightest-wear scenario possible and I would happily go 10,000 miles on a premium (not EP) filter. Under ideal conditions, most decent oil filters are able to go much longer than indicated by the manufacturer. It's the adverse conditions that many drive under that require the filter be changed more often.
The longest I have left an oil filter on any of my engines was a Toyota/Denso OEM filter on my 2006 Tacoma, I thought I had changed it at the previous service but apparently I was in a hurry and left it on, changing only the oil. So that Denso filter went over 11,000 miles and I could not tell any difference. The truck ran great the whole time and I am not worried about any wear or additional failure due to running the oil filter beyond it's "service life" (which will vary depending on conditions).
My commute is 14 miles each way with some stop-and-go city traffic, and weekend trips can be much shorter or longer. So currently I am running synthetic oil at 7,500-mile intervals (Toyota specifies conventional oil at 5,000-mile intervals for this vehicle). I don't drive it hard or in dusty conditions so this interval works great for my situation. I use premium filters such as Bosch, Purolator, Denso, etc. No need for EP filters at these intervals.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
Re: How long can an oil filter last? 10k? 20k? 100k? [Re: wowthisexists] #4560343
10/31/17 03:52 PM
10/31/17 03:52 PM
Houston, TX
2015_PSD Offline
2015_PSD  Offline
Houston, TX
Unless the operating conditions require it or the engine is in a poor state of repair, I tend to think 10K is the new 3K for most engines these days. With the exception of inferior construction, **most** oil filters should be able to go 10K with ease. The extended filters can go 20-30K with little issue as well. But as someone else said--it all depends.
2018 Mercedes Benz AMG GLC43 3.0L Bi-Turbo [Castrol Edge 0W-40 & Pur filter]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum 0W-40 & Mann filter]
