OIL ANALYSIS REPORT
WEAR ABNORMAL
CONTAMINATION SEVERE
FLUID CONDITION ABNORMAL
Machine Id
FST 2 (S/N )
Component
WESTECH 105 Gearbox
Fluid
ROYAL PURPLE THERMYL-GLYDE 150 (10 GAL)
Report Id: [WUSCAR] 04310091
Test UOM Method Limit/Abn Current History1 History2
Sample Number RP181674 --- ---
Sample Date 06 Sep 2017 --- ---
Machine Age hrs 8800 --- ---
Oil Age hrs 8800 --- ---
Filter Age hrs 0 --- ---
Oil Changed Not Changd --- ---
Filter Changed N/A --- ---
Sample Status SEVERE --- ---
Iron ppm ASTM D5185 >200 252 --- ---
Chromium ppm ASTM D5185 >15 2.0 --- ---
Manganese ppm ASTM D5185 1.5 --- ---
Nickel ppm ASTM D5185 >15 0.5 --- ---
Titanium ppm ASTM D5185 0.0 --- ---
Silver ppm ASTM D5185 0.3 --- ---
Aluminum ppm ASTM D5185 >25 2.9 --- ---
Lead ppm ASTM D5185 >100 0.0 --- ---
Copper ppm ASTM D5185 >200 4.1 --- ---
Tin ppm ASTM D5185 >25 0.0 --- ---
Vanadium ppm ASTM D5185 0.0 --- ---
White Metal scalar Visual NONE LIGHT --- ---
Babbitt scalar Visual NONE NONE --- ---
Silicon ppm ASTM D5185 >50 7.8 --- ---
Potassium ppm ASTM D5185 >20 6.0 --- ---
Water % ASTM D6304 >0.2 1.37 --- ---
ppm Water ppm ASTM D6304 >2000 13700 --- ---
Silt scalar Visual NONE NONE --- ---
Debris scalar Visual NONE NONE --- ---
Sand/Dirt scalar Visual NONE NONE --- ---
Appearance scalar Visual NORML MILKY --- ---
Odor scalar Visual NORML NORML --- ---
Emulsified Water scalar Visual >0.2 1.0% --- ---
Sodium ppm ASTM D5185 2.9 --- ---
Boron ppm ASTM D5185 9.0 --- ---
Barium ppm ASTM D5185 2.5 --- ---
Molybdenum ppm ASTM D5185 0.0 --- ---
Magnesium ppm ASTM D5185 0.8 --- ---
Calcium ppm ASTM D5185 12 --- ---
Phosphorus ppm ASTM D5185 108 --- ---
Zinc ppm ASTM D5185 1034 --- ---
Sulfur ppm ASTM D5185 9303 --- ---
Acid Number (AN) mg KOH/g ASTM D974 1.5 0.545 --- ---
Visc @ 40°C cSt ASTM D445 150 646.0 --- ---
RECOMMENDATION
We advise that you check for the source of water entry. We
recommend that you drain the oil from the component if this has not
already been done. We recommend an early resample to monitor this
condition. Please note that there was too much water present in the oil
to perform an accurate viscosity test.
WEAR
Gear wear is indicated.
CONTAMINATION
There is a high concentration of water present in the oil.
FLUID CONDITION
The oil is no longer serviceable due to the presence of contaminants.
Page 1 of 2
WEAR ABNORMAL
Machine Id
FST 2 (S/N )
Component
WESTECH 105 Gearbox
Fluid
RECOMMENDATION
WEAR
CONTAMINATION
FLUID CONDITION
Page 1 of 2
