Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
2019 GM 6.2 AFM
by XL1200RFan. 12/12/18 07:32 AM
Dodge Challenger R/T Tips and Tricks?
by LoneRanger. 12/12/18 06:02 AM
MIL vehicle suggestion $8000
by madRiver. 12/12/18 06:00 AM
Toyota 2TR-FE 2.7 questions
by Doublehaul. 12/12/18 12:32 AM
Anybody used Eurolub?
by FordCapriDriver. 12/12/18 12:18 AM
Micro-Green Cut Open
by David1. 12/11/18 11:45 PM
Witch way does this valve work?
by Dylan1303. 12/11/18 11:42 PM
Santa came early..
by leoblack9. 12/11/18 11:22 PM
dropped a zip tie in my prius trans
by eljefino. 12/11/18 09:54 PM
2 Cello's - Some talented fellows right here.
by StevieC. 12/11/18 09:49 PM
Something different for sure - Punjabi Celtic
by StevieC. 12/11/18 09:40 PM
Honda eu200i hiccuping @ low idle - fixed
by Jmoney7269. 12/11/18 09:34 PM
Your dealer is here - Humor
by StevieC. 12/11/18 08:46 PM
1994 Honda Civic LX Main Relay-solder
by Gito. 12/11/18 08:43 PM
Winter/Summer Fuel Economy
by RayCJ. 12/11/18 08:33 PM
tedonom, 01ws666, ariefnrst, tcoffin014, Schm1d
66657 Registered Users
105 registered members (2018matto, 28oz, 1foxracing, 64bawagon, 01ws666, 2009Edge, 10 invisible), 1,826 guests, and 42 spiders.
Topics294,973
Posts4,925,157
Members66,657
Most Online2,553
Oct 27th, 2018
2014 Silverado differential and transfer-case oil #4559065
10/30/17 07:39 AM
10/30/17 07:39 AM
Charleston,SC
GMcDougal Offline OP
Charleston,SC
What are some good fluids for both my differentials and front transfer case? I plan on going 75w90 in both Transfer cases unless everyone insist I stick with 75w85. I also don’t really want to spend $20 a quart. Thanks
Re: 2014 Silverado differential and transfer-case oil [Re: GMcDougal] #4559073
10/30/17 07:47 AM
10/30/17 07:47 AM
Malaysia
zeng Offline
zeng  Offline
Malaysia
Yep, go a grade or two thicker than OEM recommendation, and the diff/Xcase bearings and gears would love it.
Other than price and availability,for stronger components protection pick one with a higher [email protected]*C first and foremost and, if it's possible, a higher [email protected]*C within similar grades .
Re: 2014 Silverado differential and transfer-case oil [Re: GMcDougal] #4559086
10/30/17 08:00 AM
10/30/17 08:00 AM
Florida
bbartow Offline
bbartow  Offline
Florida
xcase is dexron vi
Re: 2014 Silverado differential and transfer-case oil [Re: GMcDougal] #4559098
10/30/17 08:20 AM
10/30/17 08:20 AM
Charleston,SC
Charleston,SC
What about this stuff in both differentials? My rear end is a G80 locker. I want to make sure i avoid chatter.
https://www.amazon.com/gp/aw/d/B000CPCBF...&ref=plSrch
https://www.amazon.com/gp/aw/d/B000ONZXP...&ref=plSrch
Will either of these work? Is one better than the other?
Re: 2014 Silverado differential and transfer-case oil [Re: GMcDougal] #4559119
10/30/17 08:43 AM
10/30/17 08:43 AM
Guilford, CT
exranger06 Online confused
exranger06  Online Confused
Guilford, CT
"Front transfer case?" "Both transfer cases?" Your truck has only one transfer case, and it's not a "front" transfer case. You need to get your terminology right so we can be sure we're talking about the same components. Otherwise you're going to put the wrong fluid in and screw something up.
2006 Ford Ranger Sport
1992 Honda Accord EX
2004 Honda CR-V LX
1994 Ford Bronco XLT (project)
2011 Cadillac Escalade ESV (wife's)
Re: 2014 Silverado differential and transfer-case oil [Re: exranger06] #4559166
10/30/17 09:19 AM
10/30/17 09:19 AM
Charleston,SC
Charleston,SC
Yes, my apologies. Front transfer case (4x4), front differential and rear differential. I realize the front and rear differentials get 75w90 gear oil and the transfer case gets dexron vi. I am trying to figure out which is best for the money. Thanks!”
Re: 2014 Silverado differential and transfer-case oil [Re: GMcDougal] #4559308
10/30/17 12:47 PM
10/30/17 12:47 PM
North Carolina
Rat407 Online content
Rat407  Online Content
North Carolina
I would say the best bet would be to go get Mobil 1 75w-90 gear oil at one of the auto parts store near you and pick up any dexron vi fluid and you would be good to go.
I use AMSOIL's Severe gear and keep it in 100k. Pulled a sample and it came back fine. I could have left it in longer and I do some mile hauling and towing with my 2002 Silverado. Just an FYI.
2002 Silverado 5.3 0w-20 AMSOIL®
Re: 2014 Silverado differential and transfer-case oil [Re: GMcDougal] #4559313
10/30/17 01:05 PM
10/30/17 01:05 PM
socal
barkingspider Offline
socal
For the front & rear differential, use the brand u like best in 75w90. I have experience w valvoline, Mobil 1, supertech, Delo, RP, autozone / oreillys and although I don’t know if one is better than the others, they all worked good in my past and present GM trucks. Xcase use only Dex VI, again chose the brand you like best
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: 2014 Silverado differential and transfer-case oil [Re: barkingspider] #4559343
10/30/17 01:45 PM
10/30/17 01:45 PM
Texas & Global
4WD Offline
4WD  Offline
Texas & Global
Ran Mobil 1 gear oil in GM’s for 20 years … walk in and grab at Autozone … always came back out clean after 30k~50k … Dex VI take your pick … pretty tightly controlled products …
2018 Chevy 1500 Z71 4WD
2017 Chevy Tahoe LT 4WD
2014 Fusion Hybrid Titanium
2013 Cruze LTZ - RS Turbo
Re: 2014 Silverado differential and transfer-case oil [Re: zeng] #4559362
10/30/17 02:05 PM
10/30/17 02:05 PM
Utah
CKN Offline
CKN  Offline
Utah
So spec the non-recommended fluid in a truck that MAY BE under warranty?
Re: 2014 Silverado differential and transfer-case oil [Re: CKN] #4559367
10/30/17 02:09 PM
10/30/17 02:09 PM
Texas & Global
4WD Offline
4WD  Offline
Texas & Global
Reckon the spec comes from AAM … core business/focus …
Re: 2014 Silverado differential and transfer-case oil [Re: GMcDougal] #4561310
11/01/17 01:46 PM
11/01/17 01:46 PM
Fly-over country
zuluplus30 Offline
zuluplus30  Offline
Fly-over country
Any J2360 75w-90 will do the trick. I used 75W90 in my wife's 2014. Didn't think twice. It also makes it easier. 5 quarts will get you front and rear filled. Only Dex VI for the transfer case. GM went to a larger ring gear in the 2014 1500s so they could drop the viscosity. They were trying to eek out any MPG they could find. Diffs don't care about thicker oil within reason.
