How to fix swollen deckwood
by RazorsEdge. 03/18/19 01:52 PM
Which is more important: Oil or Filter?
by RDY4WAR. 03/18/19 01:45 PM
Dishonest car dealership?
by aquariuscsm. 03/18/19 01:21 PM
Phillips 66 Shield Choice $1.99 @ Orscheln
by Pat in Speedway. 03/18/19 12:41 PM
Barely there back seats
by y_p_w. 03/18/19 11:47 AM
should i be afraid of the DCT ?
by WhyMe. 03/18/19 11:28 AM
Friction modifiers
by Truckedup. 03/18/19 10:57 AM
Sometimes, choices are made for you!
by addyguy. 03/18/19 10:30 AM
I Hope This Amuses You Guys Like It Did Me
by NYEngineer. 03/18/19 10:27 AM
New Exmark Lazer Z / Oil ?
by johnD2. 03/18/19 10:13 AM
First welder recommendation
by Astro14. 03/18/19 09:55 AM
Amsoil Burning
by ridgerunner. 03/18/19 09:38 AM
2007 Sonata Pinging + DTCs
by F24Sonata. 03/18/19 09:31 AM
Nissan Maxima 2009 synthetic oil choices
by mahanddeem. 03/18/19 09:23 AM
Best coated rotors
by JMHC. 03/18/19 09:11 AM
Brake Bleeder Question
by maverickfhs. 03/18/19 08:57 AM
Ring alarm system, any good?
by Redright9. 03/18/19 08:18 AM
4 oil changes Saturday.
by ls1mike. 03/18/19 08:08 AM
Indyfordfan, toplscuda, swrve, TomRx, Ozdave
67548 Registered Users
96 registered members (aquariuscsm, 1978elcamino, 69Torino, 4WD, 94astro, 9 invisible), 2,283 guests, and 59 spiders.
Topics286,018
Posts4,900,861
Members67,548
Most Online2,967
Mar 10th, 2019
Hitch Rattle?? #4559004
10/30/17 07:26 AM
10/30/17 07:26 AM
Southern Indiana
Mantooth Offline OP
Mantooth  Offline OP
Southern Indiana
So here is my dilemma - I'm getting ready to buy a side-x-side (not sure what brand yet) and will hauling it occasionally with my Durango. The trailer I have is a new Gatormade 10,400lb equipment trailer. I will not be exceeding the load tow capacity of my tow vehicle - just wanted to clear that up.
The Gatormade hooked up to my Durango has an awful amount of rattle. My hitch is a Draw-Tite 6k hollow tube that my Dad had laying around. Planning on getting a 10k rated solid hitch when I can find one on sale. I use to have one but got talked into including it during the sale of my last camper. Using the hitch I have now results in a ridiculous amount of movement in the receiver.
Should I just get a new solid tube hitch and start from there? I've looked at some products on Amazon but I'm not sure what works best for eliminating the issue. I've mostly towed campers (conventional and 5th wheel) and loaded farm trailers with my F250 or Dad's dually. Never really had any issues with rattle before.
Thanks.
'14 Durango AWD 3.6,(mine) Hav ProDS 5w30/Napa Gold
'15 Journey AWD 3.6, (wife's) Napa Syn 5w20/Napa Gold
'01 F250 4x4 7.3PSD, 126k, M1 TDT 5w40/MC
Re: Hitch Rattle?? [Re: Mantooth] #4559009
10/30/17 07:29 AM
10/30/17 07:29 AM
Parts Unknown
UG_Passat Online content
UG_Passat  Online Content
Parts Unknown
That's why I have a hidden hitch brand, which can use their J-pin to help reduce the movement inside the reciever
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Hitch Rattle?? [Re: Mantooth] #4559018
10/30/17 07:38 AM
10/30/17 07:38 AM
Southern Indiana
Mantooth Offline OP
Mantooth  Offline OP
Southern Indiana
Forgot to mention, my receiver is factory equipment since I have the tow package.
Hitch has a 2 inch drop to it. In all honesty, having a 3 inch would probably be best since the trailer has a slight upward pitch to it when connected.
Re: Hitch Rattle?? [Re: Mantooth] #4559079
10/30/17 08:56 AM
10/30/17 08:56 AM
WI
HoosierJeeper Offline
WI
15 Jeep KL Limited V6: Formula Shell 5W20
07 LR3 SE V8: Maxlife 5W30
05 Jeep KJ Limited: PHM 5W30
96 Jeep XJ Country: STP HM 5W30 (winter)
Re: Hitch Rattle?? [Re: Mantooth] #4559087
10/30/17 09:00 AM
10/30/17 09:00 AM
Houston, Texas
motor_oil_madman Offline
Houston, Texas
I don't understand the problem. If the trailer is empty it's typically normal to hear and feel some noise and rattling back their. There should be minimal movement in the ball hitch. Like 1/8" so check and make sure the hole that the pin goes through isn't wollowed out.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Hitch Rattle?? [Re: Mantooth] #4559114
10/30/17 09:40 AM
10/30/17 09:40 AM
MD
onemig Offline
onemig  Offline
MD
Try this: Blue Ox BX88224 Immobilizer II for 2" Receiver Hitch
It stops both vertical and lateral movements of the hitch.
2014 Subaru Forester XT Touring w/ Eyesight, 80K miles - Wife's
2017 GTI S DSG 4 Dr. HB, 5K miles - Mine
Re: Hitch Rattle?? [Re: Mantooth] #4559127
10/30/17 09:49 AM
10/30/17 09:49 AM
WV
loneryder Offline
loneryder  Offline
WV
A package of wood shims. Worked for me.
Re: Hitch Rattle?? [Re: Mantooth] #4559155
10/30/17 10:14 AM
10/30/17 10:14 AM
Texas
GMBoy Offline
GMBoy  Offline
Texas
I pull an RV, car hauler and misc utility trailers with my truck and it has a factory hitch. I also have a loose fitting hitch. Just over time I guess the hitch movement widens the square hole. It's not unsafe, just an annoyance so I've never done anything about it. You could buy that item posted above to tighten things up but I would not like another step to perform in the hitching up process.
Re: Hitch Rattle?? [Re: Mantooth] #4559320
10/30/17 02:14 PM
10/30/17 02:14 PM
Southeast
meep Offline
meep  Offline
Southeast
For a standard receiver hitch I used to just cut up a cheerios box and slide the cardboard in between gaps that might rattle. worked every time.
For a WD hitch it's not needed because the spring tension keeps the thing tight.
If the ball is loose, tighten the nut under the ball, but not too much.
2018 F150
2015 crv (wifey!)
Re: Hitch Rattle?? [Re: Mantooth] #4559368
10/30/17 03:10 PM
10/30/17 03:10 PM
Virginia
glock19 Offline
glock19  Offline
Virginia
I have a cheap anti-rattle device off of Amazon and it works pretty well.
Link: https://www.amazon.com/gp/product/B01ISA2CUO/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
2017 GMC Sierra SLT Z71 Crew Cab - His
2016 Toyota Highlander Limited - Hers
2002 Honda Odyssey EX - Beater
Re: Hitch Rattle?? [Re: Mantooth] #4559420
10/30/17 04:35 PM
10/30/17 04:35 PM
Utah
CKN Offline
CKN  Offline
Utah
Thanks.
Not what you asked about-but I don't see how you are not over loading your vehicle. You have an approximate (vehicle) payload of 1,200 pounds-and you have a tongue weight of 1,248 pounds.
If your towing this in a business situation your a liability waiting to happen. You need a 3/4 ton truck at a minimum. Use your F250-that's what it is made for.
I'm waiting for someone in this situation to run in to me-I would like a new "King Ranch" or equivalent pickup truck.
Re: Hitch Rattle?? [Re: Mantooth] #4559448
10/30/17 05:24 PM
10/30/17 05:24 PM
In the Garage...
ls1mike Offline
ls1mike  Offline
In the Garage...
How loud is it? My setup would drive you crazy.
It is dual sway control/WD. It is loud when turning. Nothing you can do about it. If you grease it, it defeats the sway control. What is your concern? Noise?
I have never really noticed hitch rattle.
Mike
00 Trans Am WS6 5.7 LS1
02 Silverado 2500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: Hitch Rattle?? [Re: Mantooth] #4559563
10/30/17 07:09 PM
10/30/17 07:09 PM
Phoenix, AZ
Nick1994 Online content
Nick1994  Online Content
Phoenix, AZ
Wrap it in black electrical tape to thicken it up and quiet it down.
2015 Hyundai Sonata 2.4L 92k STP Synthetic HM 10w30 & Wix
2000 Toyota Camry 2.2L 233k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 148k Mobil 1 HM 10w40 & Fram Ultra
Re: Hitch Rattle?? [Re: CKN] #4559577
10/30/17 07:17 PM
10/30/17 07:17 PM
Southern Indiana
Mantooth Offline OP
Mantooth  Offline OP
Southern Indiana
Thanks.
I did my math awhile back and I figured I was well within the payload/towing capabilities of my Durango. Feel free to check it and correct me if I'm wrong.
Also, this is not for a business. My plan is take to the side by side to WV so my son and I can do some 2,3 or 4 day trail rides. Reason for using the Durango for towing is this - my wife and daughter like to trail ride on horse back. She has two horses and a 3-horse slant Featherlite horse trailer with a short wall. There are several weekends where she leaves out with the truck and horse trailer which leaves me with the Durango.
Thanks.
Trailer GVWR: 10,400
Trailer weight empty: 2,010
Weight of side by side: 1,500 +/-
Trailer tongue weight loaded w/ side by side: 526.5 est. ([2,010+1,500]*.15)
Durango weight: 4,987
payload capacity: 1,420
My weight: 180
My son's weight: 50
clothing/supplies: 30
fuel: 154.98 (6.3lbs/gal*24.6)
I will not be using a W/D hitch system.
526.5+154.98+180+50+30 = 941.48 est payload
1,420-941.48 = 478.52 lb to spare.
(all weights in pounds and estimated)
Re: Hitch Rattle?? [Re: ls1mike] #4559586
10/30/17 07:25 PM
10/30/17 07:25 PM
out there
spasm3 Online content
spasm3  Online Content
out there
I run the same hitch , its great! Yes no grease. It really creaks when you turn, but friction is what makes it so stable on the road.
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
