Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
Witty comment regarding a lame car
by Number_35. 12/17/18 03:43 PM
'80s oil literature
by Number_35. 12/17/18 03:26 PM
Recommend on oil for 2017 Kia Sportage 2.4
by SlavaB. 12/17/18 02:57 PM
No more Delo at my Costco. T4 now
by BeerCan. 12/17/18 02:16 PM
Found this
by davedude. 12/17/18 02:15 PM
Practice CLS material
by RDY4WAR. 12/17/18 01:52 PM
2005 Chevy Silverado 5.3 vortex
by MSpeer. 12/17/18 12:01 PM
hopsofir, genera2800, oghl, hdlss, dsmdylan
66711 Registered Users
28 registered members (citationxeleven, Char Baby, bluesubie, Brandon9797, 53' Stude, ARB1977, 1 invisible), 822 guests, and 31 spiders.
Topics295,205
Posts4,929,884
Members66,711
Most Online2,553
Oct 27th, 2018
2007 front diff and rear diff drain fill torque sp #4558844
10/29/17 08:58 PM
10/29/17 08:58 PM
canada
apollo18 Offline OP
apollo18  Offline OP
canada
Did my fluids last night in a 2007 escalade ext, and on a YouTube video I saw the guy with the same truck and he did:
Front diff fill plug 13 lb foot
Front diff drain plug 13 lb foot
Rear fill plug 13 lb foot
Rear diff cover case 13 lb ft
i used the same torque specs that he did but when i read online it seems like its 24lb ft for the drain and fill plug, and then 29lb ft for the rear cover bolts.
ive been driving around for a day or two and no leaks. i should probably torque it up to 24 and 29 if its supposed to be that high
Re: 2007 front diff and rear diff drain fill torque sp [Re: apollo18] #4558852
10/29/17 09:16 PM
10/29/17 09:16 PM
socal
barkingspider Offline
socal
30 ft lbs for the rear diff cover bolts, thatís what I did on my ext
06 Cadillac Escalade Ext
17 Cadillac ATS (wife)
05 Toyota Camry (daughter)
11 GMC Canyon off-road (daily)
Re: 2007 front diff and rear diff drain fill torque sp [Re: apollo18] #4558861
10/29/17 09:49 PM
10/29/17 09:49 PM
canada
apollo18 Offline OP
apollo18  Offline OP
canada
how about fills? and drains
Re: 2007 front diff and rear diff drain fill torque sp [Re: apollo18] #4558869
10/29/17 09:58 PM
10/29/17 09:58 PM
Georgia
AVB Offline
AVB  Offline
Georgia
who torques that stuff?
Re: 2007 front diff and rear diff drain fill torque sp [Re: AVB] #4558870
10/29/17 09:59 PM
10/29/17 09:59 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
grin2
Re: 2007 front diff and rear diff drain fill torque sp [Re: apollo18] #4558883
10/29/17 10:28 PM
10/29/17 10:28 PM
Georgia
AVB Offline
AVB  Offline
Georgia
If you used good RTV on a clean surface it won't leak, but that is a little low. You could possibly get a little seepage on the drain plug.
Re: 2007 front diff and rear diff drain fill torque sp [Re: apollo18] #4559015
10/30/17 06:35 AM
10/30/17 06:35 AM
Upstate NY
Wheel Offline
Wheel  Offline
Upstate NY
Subaru spec's 2 different torque values depending on what the crush washer is made of (44 for the aluminum one, 70 for the copper)
2009 Subaru Legacy (N/A)
Castrol Edge and Subie (Fram) filter
Re: 2007 front diff and rear diff drain fill torque sp [Re: barkingspider] #4559137
10/30/17 09:02 AM
10/30/17 09:02 AM
Idaho
CT8 Offline
CT8  Offline
Idaho
For the little bolts that hold on the covers 30 ft lbs? Grade 29 bolts
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: 2007 front diff and rear diff drain fill torque sp [Re: AVB] #4559160
10/30/17 09:16 AM
10/30/17 09:16 AM
Texas
GMBoy Offline
GMBoy  Offline
Texas
Lol, I thought the same. Just get it good and tight by feel.
Re: 2007 front diff and rear diff drain fill torque sp [Re: apollo18] #4559184
10/30/17 09:41 AM
10/30/17 09:41 AM
canada
apollo18 Offline OP
apollo18  Offline OP
canada
Hahaha Kk thansk guys!! Is 13 ft lbs enough then?
Re: 2007 front diff and rear diff drain fill torque sp [Re: apollo18] #4559246
10/30/17 11:06 AM
10/30/17 11:06 AM
Hawaii, USA
anndel Offline
anndel  Offline
Hawaii, USA
Snug
1993 Toyota 4x4 p/u, 2.4L 22RE 4 cyl - Amsoil SS 10W-30, Yota OEM Filter
2005 Toyota Avalon XL, 3.5L V6, Amsoil SS 5W-30, Yota OEM Filter
2014 Toyota Tacoma 4.0L V6, Amsoil SS5W-30, Yota OEM Filter
Re: 2007 front diff and rear diff drain fill torque sp [Re: apollo18] #4559558
10/30/17 06:02 PM
10/30/17 06:02 PM
canada
apollo18 Offline OP
apollo18  Offline OP
canada
well i tightened up to 24 ft lbs for the plugs and the difference was minimal.
i barely applied any muscle and it clicked for 24. it was at 13 ft lbs before
is the difference between 13ft lbs and 24 ft lbs barely anything?
Re: 2007 front diff and rear diff drain fill torque sp [Re: apollo18] #4559579
10/30/17 06:18 PM
10/30/17 06:18 PM
Lakeside CA
another Todd Offline
Lakeside CA
If it's not leaking you are good.
2015 Ford F250 Diesel Crew Cab FX4
2017 Ford Escape 2.0
2002 GMC Yukon
2015 Hyundai Accent
2008 Yamaha Rhino 700 FI
Re: 2007 front diff and rear diff drain fill torque sp [Re: apollo18] #4559599
10/30/17 06:33 PM
10/30/17 06:33 PM
Georgia
AVB Offline
AVB  Offline
Georgia
The plugs are a tapered pipe thread as far as I know so the torque ramps up quick.
Re: 2007 front diff and rear diff drain fill torque sp [Re: CT8] #4559625
10/30/17 06:49 PM
10/30/17 06:49 PM
socal
socal
The rear diff cover bolts, yes 30 lbs ft. The plug I just snug it but 24 lbs ft is the correct torque. Never had them leak using this
