Purolator P1 14476 CUT OPEN
by 53' Stude. 12/12/18 06:00 PM
Which car to buy?
by jrcowboys. 12/12/18 04:55 PM
New Tire Cracking
by robd. 12/12/18 04:43 PM
SAR B6P - Thoughts?
by 28oz. 12/12/18 03:59 PM
Time to sell the 1-ton Dually
by 02SE. 12/12/18 03:55 PM
Shell Rotella Grease
by WMW0505. 12/12/18 02:27 PM
Need to add attic ladder in stairwell
by Klutch9. 12/12/18 12:51 PM
Mystik JT-8 15w40, 2015 RAM EcoDiesel, 4,995 mi
by SavagePatch. 12/12/18 12:45 PM
Fram Tough Guard Air Filters at Rock Auto
by Snagglefoot. 12/12/18 12:42 PM
Electrical contact cleaner
by CELICA_XX. 12/12/18 12:32 PM
5w-30 in 277k mile chevy 350 tbi
by dogememe. 12/12/18 12:22 PM
voltage test for coolant condition
by NissanMaxima. 12/12/18 12:17 PM
paying Premiun for the name(infiniti/nissan
by 2008wrx. 12/12/18 11:25 AM
POE oil (R-410a)
by WyrTwister. 12/12/18 09:44 AM
Any Volvo Owners, need some help!
by LazyDog. 12/12/18 09:34 AM
NOACK & Sheer
by WyrTwister. 12/12/18 09:34 AM
Rotary help. 2010 series 2 RX8
by TinyVoices. 12/12/18 08:32 AM
Can you mathematically estimate top speed?
by KCJeep. 12/12/18 08:06 AM
jefe_de_estado, CM613, Geardaddies, 01ws666, ariefnrst
66660 Registered Users
102 registered members (Aero540T, 53' Stude, ammolab, 69Torino, ad244, 240_Ed, 7 invisible), 1,883 guests, and 37 spiders.
Topics294,991
Posts4,925,574
Members66,660
Most Online2,553
Oct 27th, 2018
DOT 3 & 4 brake fluid #4558714
10/29/17 06:52 PM
10/29/17 06:52 PM
Texas
WyrTwister Offline OP
Texas
Is it OK to use DOT 3 & 4 fluid in the master cylinder reservoir of a 1991 Chevy Caprice ? Will it " mix " OK with the " older " specifications of brake fluid ?
Thanks ,
Wyr
God bless
Wyr
God bless
Re: DOT 3 & 4 brake fluid [Re: WyrTwister] #4558730
10/29/17 07:06 PM
10/29/17 07:06 PM
NY
demarpaint Offline
demarpaint  Offline
NY
If DOT 3, DOT 4, or DOT 5.1 was in there before it will mix.
God Bless Our Troops
Re: DOT 3 & 4 brake fluid [Re: WyrTwister] #4558762
10/29/17 07:39 PM
10/29/17 07:39 PM
Texas
Texas
What DOT spec brake fluid did Chevy use in 1991 ?
Thanks , :-)
Wyr
God bless
Re: DOT 3 & 4 brake fluid [Re: WyrTwister] #4558786
10/29/17 07:55 PM
10/29/17 07:55 PM
Richmond, BC, Canada
mechjames Offline
mechjames  Offline
dot 3 was what was used
86 Mustang 5.0L 170km - Amsoil XL 5w30 / Baldwin B2-HPG
14 Ram 1500 5.7 - Amsoil XL 5w20 / Baldwin B7443
98 Jeep ZJ 5.9 - Amsoil OE 10w30 / Baldwin B34
Re: DOT 3 & 4 brake fluid [Re: WyrTwister] #4558841
10/29/17 08:54 PM
10/29/17 08:54 PM
UT
BHopkins Offline
BHopkins  Offline
UT
DOT 3 and DOT 4 are 100% compatible. You can use DOT 3 or DOT 4 anywhere DOT 3 is specified. However, DOT 3 should not be used where DOT 4 is called for.
DOT 4 meets higher dry and wet boiling points than DOT 3. Although your '91 Caprice may never benefit from the benefits, you may feel totally safe in using DOT 4 in it.
2013 Subaru Outback 2.5i - Idemitsu 0W-20 & Mobil 1 filter
2007 Mercedes SL550 - M1M 5W-40 & MB OEM filter
Re: DOT 3 & 4 brake fluid [Re: WyrTwister] #4558843
10/29/17 08:57 PM
10/29/17 08:57 PM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Thanks , :-)
Sounds like you're saying its on the original fill. If thats the case, you shouldnt be wondering whether it'll mix with new stuff, you should be flushing and changing it completely.
In fact you should probably just change it anyway.
Personally I'd use DOT3 cos here its about 2/3 the price and you'll use quite a bit to flush and change the whole system.
Re: DOT 3 & 4 brake fluid [Re: BHopkins] #4558871
10/29/17 10:02 PM
10/29/17 10:02 PM
MA
Wolf359 Offline
Wolf359  Offline
MA
The only issue with Dot 4 is that it tends to be more hydroscopic than Dot 3 so you need to flush the fluid more often. Mine uses dot 4 and the manufacturer recommends fluid flushes every 2 years. Lots of cars from the 90's never recommended an interval although it was always a good idea as water will eventually rust out the the lines and other parts inside your braking system.
Re: DOT 3 & 4 brake fluid [Re: WyrTwister] #4558896
10/29/17 11:41 PM
10/29/17 11:41 PM
Texas
Texas
Well , after reading on this forum , I have been using the turkey baster , from time to time . Bit there is probably some of the original fill .
Just got back from giving our Daughter a lift home , from work . ABS lite did not come on this time ! :-)
Praise the Lord ! :-)
Wifey is out of town visiting oldest Grand Daughter . Will try to flush the system when She gets back , & can help . Hope the little Bleed nipples are not rusted solid ...........
Thanks , all , :-)
Wyr
God bless
Wyr
God bless
Re: DOT 3 & 4 brake fluid [Re: Wolf359] #4559020
10/30/17 06:38 AM
10/30/17 06:38 AM
NJ
JLawrence08648 Offline
NJ
Hygroscopic, not hydroscopic.
Originally Posted By: Wolf359
[quote=BHopkins]
The only issue with Dot 4 is that it tends to be more hydroscopic than Dot 3 so you need to flush the fluid more often. Lots of cars from the 90's never recommended an interval although it was always a good idea as water will eventually rust out the the lines and other parts inside your braking system.
Re: DOT 3 & 4 brake fluid [Re: WyrTwister] #4559052
10/30/17 07:18 AM
10/30/17 07:18 AM
Taiwan
Ducked Offline
Ducked  Offline
Taiwan
Presumably not reading (or at least not believing) the bit where it says the "turkey baster method" is pretty useless. I doubt its completely useless, since it may protect your master cylinder a bit, but its likely to leave some wet fluid in the extremities where it can cause corrosion and interfere with braking.
You don't need help (unless your wife is good at freeing up rusted bleed nipples, which is a pain).
Wives may be different (no experience) but having tried girlfriends in the brake bleeding role I'd say it isn't worth the collateral hassle.
There are several ways you can bleed brakes solo. Easiest is probably a simple gravity bleed, though I personally favor using an enema syringe for more pressure and control.
Re: DOT 3 & 4 brake fluid [Re: Ducked] #4559075
10/30/17 07:51 AM
10/30/17 07:51 AM
Texas
Texas
Seems to be doing a little good , since the ABS lite is coming on less often .
I have done brake work many times ( starting back in the late 1960's ) & Wifey has helped bleed the brakes many times ( since the 1980's ) . Think we will be good in that area .
Have heard of gravity bleeding of the brakes . Was / am some what cautious about that .
Have this cheap plastic transfer pump . Wonder how it would work ?
https://www.harborfreight.com/multi-use-transfer-pump-63144.html
Thanks , :-)
Wyr
God bless
Re: DOT 3 & 4 brake fluid [Re: WyrTwister] #4559095
10/30/17 08:12 AM
10/30/17 08:12 AM
Texas
Texas
https://shop.advanceautoparts.com/p/valvoline-dot-3-and-4-synthetic-brake-fluid-32-oz.-601458/7080002-P?navigationPath=L1*14924%7CL2*15037%7CL3*16113
I used some of this , this weekend . Could someone please explain DOT 3 & 4 . I would think it would be either / or ?
Someone said DOT 4 was more hygroscopic . Not sure if I want that . Would that apply to this Valvoline product ?
Thanks , :-)
Wyr
God bless
Re: DOT 3 & 4 brake fluid [Re: WyrTwister] #4559133
10/30/17 08:59 AM
10/30/17 08:59 AM
Idaho
CT8 Offline
CT8  Offline
Idaho
Thanks , all , :-)
Wyr
God bless
The
turkey baser is a 100% waste of time.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: DOT 3 & 4 brake fluid [Re: WyrTwister] #4559148
10/30/17 09:09 AM
10/30/17 09:09 AM
The Midwest
skyactiv Online content
skyactiv  Online Content
The Midwest
DOT 4 is cross compatible with DOT 3 brake fluid. Some brake fluids might be labeled saying both DOT 3 and DOT 4 just like some oils have been labeled API SM, API SN. I'd have no problem using
a store brand brake fluid such as Supertech DOT 3 in that vehicle. Cheap at Wal-Mart at $4.XX a quart. That is what I used when I maintained my elderly neighbors Chevy Colorado before I moved.
I use a turkey baster and a home made one man brake bleeder. You don't need to gravity bleed and get all crazy.
Me: 13' VW GTI 3 door 6 speed manual
Wanted: 2019 Ford Ranger
Re: DOT 3 & 4 brake fluid [Re: WyrTwister] #4559153
10/30/17 09:11 AM
10/30/17 09:11 AM
The Midwest
The Midwest
Suck out the old fluid in the master cylinder resivour with the turkey baster and add fresh fluid before flushing.
