Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
Witty comment regarding a lame car
by Number_35. 12/17/18 03:43 PM
'80s oil literature
by Number_35. 12/17/18 03:26 PM
Recommend on oil for 2017 Kia Sportage 2.4
by SlavaB. 12/17/18 02:57 PM
No more Delo at my Costco. T4 now
by BeerCan. 12/17/18 02:16 PM
Found this
by davedude. 12/17/18 02:15 PM
hopsofir, genera2800, oghl, hdlss, dsmdylan
66711 Registered Users
72 registered members (4WD, ABomb369, 94astro, alarmguy, Astro_Guy, atikovi, 5 invisible), 1,150 guests, and 35 spiders.
Topics295,207
Posts4,929,935
Members66,711
Most Online2,553
Oct 27th, 2018
F150 AC question #4558571
10/29/17 04:16 PM
10/29/17 04:16 PM
Lakeside CA
another Todd Offline OP
Lakeside CA
I think I have a plugging up orifice tube on my friends 03 F150 truck, what do you think? Symptoms: clutch cycles about every 1.5 seconds, pressure on low side 25 at kick out 40-45 at kick in, high side kick in about 125-140 kick out at 175 (75-80 ambient). High pressure line from the orifice tube to firewall covered in ice, low pressure line out of evap. is warm, slightly cooler than ambient. With heater hose clamped off I get 60 degrees at low fan speed, center vent, recirc. Un-clamp heater hose and temp slowly rises to 70 degrees (about 10 minutes). During the short time compressor is on the low side drops and the high side rises much quicker than I would expect, hence I suspect the orifice tube is mostly plugged. What do you think?
2015 Ford F250 Diesel Crew Cab FX4
2017 Ford Escape 2.0
2002 GMC Yukon
2015 Hyundai Accent
2008 Yamaha Rhino 700 FI
Re: F150 AC question [Re: another Todd] #4558604
10/29/17 04:51 PM
10/29/17 04:51 PM
midwest
JamesBond Offline
JamesBond  Offline
midwest
I'm no expert but the pressures seem low according to the charts I saw. Are you checking these pressures at idle? I'd recheck at 2000 rpm and see what you get, then I'd probably add some refrigerant.
Re: F150 AC question [Re: another Todd] #4558626
10/29/17 05:11 PM
10/29/17 05:11 PM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
Agree, it seems like its low to me.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 75k
Castrol EDGE HM 5W30, Fram XG2
Re: F150 AC question [Re: another Todd] #4558659
10/29/17 05:53 PM
10/29/17 05:53 PM
Lakeside CA
Lakeside CA
I assume your are referring to the high side? The pressure is climbing fast when it cuts out, I suspect it would go a fair amount above that if the compressor did not cycle off every 1.5 seconds.
2002 GMC Yukon
2015 Hyundai Accent
Re: F150 AC question [Re: another Todd] #4558670
10/29/17 06:02 PM
10/29/17 06:02 PM
midwest
JamesBond Offline
JamesBond  Offline
midwest
I was referring to the low side pressure. The compressor might be shutting off because the low side is getting too low tripping the low pressure safety switch. I think it's supposed to go up quickly but that doesn't mean that if the compressor stayed on that it would keep going up.
Re: F150 AC question [Re: another Todd] #4558678
10/29/17 06:10 PM
10/29/17 06:10 PM
Lakeside CA
Lakeside CA
I will certainly try adding some refrigerant before I replace the o-tube, and I am pretty certain it was hitting the low pressure cut out, but the high side rose so fast during the 1.5 seconds I assumed there was a blockage.
2002 GMC Yukon
2015 Hyundai Accent
Re: F150 AC question [Re: another Todd] #4558739
10/29/17 07:13 PM
10/29/17 07:13 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Has the system recently been open & exposed to air ? Has it recently had a compressor replaced ? Perhaps for a catastrophic failure ?
The 2 things that come to my mind , to stop up an O-Tube would be ice or debris from a compressor coming apart internally .
Are you getting proper air flow through the condenser coil ? Are the radiator cooling fan / fans working OK ?
I too would like to know if it is cycling on low pressure or high pressure ? I am guessing low pressure .
I think , were it mine , I also would try , very careful , adding a little refrigerant in the low side . I would probably charge with vapor , not liquid refrigerant .
Best of luck to you , :-)
Wyr
God bless
Wyr
God bless
Re: F150 AC question [Re: another Todd] #4558743
10/29/17 07:17 PM
10/29/17 07:17 PM
USA
mk378 Offline
mk378  Offline
USA
Charge by weight then evaluate performance. When properly charged you may find the high side is way up due to condenser issues (fan clutch, dirt, missing shrouds).
A clog would cause the low side to go down until the switch trips, then stay there for a long time. Orifice tubes rarely clog. If you do have the opportunity with the system empty, definitely pull it and check for debris on the screens.
This system is showing the usual signs of low charge. If it was low, look for the leak.
Re: F150 AC question [Re: another Todd] #4558753
10/29/17 07:33 PM
10/29/17 07:33 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
R134a is weird stuff. You can be pounds low and still have somewhat normal pressures.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: F150 AC question [Re: another Todd] #4559072
10/30/17 07:45 AM
10/30/17 07:45 AM
Lakeside CA
Lakeside CA
WYR, no the system has not been opened.
2002 GMC Yukon
2015 Hyundai Accent
Re: F150 AC question [Re: another Todd] #4578108
11/18/17 03:12 PM
11/18/17 03:12 PM
Lakeside CA
Lakeside CA
Turns out, as some have suggested, it was just super low on refrigerant. Had enough to kick on the compressor, but not enough to cool. I added the necessary amount and all is well. Thanks for the help.
2002 GMC Yukon
2015 Hyundai Accent
Re: F150 AC question [Re: another Todd] #4578223
11/18/17 06:20 PM
11/18/17 06:20 PM
Michigan
researcher Offline
researcher  Offline
Michigan
good deal! Always like to hear a good ending to the story! thumbsup
