M1 is changing their oils, site and adding a new oil
by Flashlightboy. 01/18/19 10:01 AM
Boiler/baseboard valve corrosion
by wormwood1978. 01/18/19 09:24 AM
Battery mfg date
by Donald. 01/18/19 08:14 AM
dexos1 Gen 2 License D10386HG025
by Virtus_Probi. 01/18/19 07:43 AM
KARMA
by Sayjac. 01/18/19 07:42 AM
Using a school bus as a camper?
by Kurtatron. 01/18/19 07:04 AM
Formula Shell Synthetic
by mmmmoil. 01/18/19 07:03 AM
free credit report
by bradepb. 01/18/19 06:25 AM
Elon Musk is running out of rich people...
by philipp10. 01/18/19 05:56 AM
Best/Cheapest UOA?
by Hemispheres. 01/18/19 05:02 AM
Hyundai/KIA Theta II multiple call campaigns
by wemay. 01/18/19 04:58 AM
How we do it in wichita! Go Shockers
by Marco620. 01/18/19 02:14 AM
Can 0w20 handle high RPMs
by Doublehaul. 01/18/19 01:16 AM
Dodge Grand Caravan OEM Floor Mats
by raburn2906. 01/17/19 11:52 PM
Mobil 1 0w30
by Doublehaul. 01/17/19 11:11 PM
(NEW) STP S3675 Cut Open
by rooflessVW. 01/17/19 10:00 PM
Anti-Counterfeiting packaging
by sloinker. 01/17/19 09:13 PM
Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Buddyp, RyanWu, Batteryspecialis, BamaDawg, JRBilt
66969 Registered Users
95 registered members (Anduril, 14Accent, 97f150, 240_Ed, Al, 69GTX, 4 invisible), 2,009 guests, and 51 spiders.
Topics296,776
Posts4,958,690
Members66,969
Most Online2,577
Jan 14th, 2019
New Honda EU2000i -Ruff Idle on Eco Mode #4558505
10/29/17 02:56 PM
10/29/17 02:56 PM
Tampa, FL
rummy Offline OP
rummy  Offline OP
Tampa, FL
I've been breaking-in my brand new EU2000i for a few days now. Since the first time I've run the generator I have noticed a ruff idle on Eco-Mode without any load on the unit. On the contrary if I run off of Eco it doesn't act up. When I load the gen up it's nice and smooth.
History/Background on unit:
Rotella T4 15W-40 for break-in
Two oil changes at 1st hour then at 5th hour mark
Shell 93 octane gas with Sta-bil. Unable to find E0 gas where I live.
Inspected Air Cleaner before firing up
Magnetic Dipstick for shavings
Is the vibration and ruff idle normal on these units while on Eco w/o any load?
Can it be a weak ignition coil?
Any other thoughts?
Re: New Honda EU2000i -Ruff Idle on Eco Mode [Re: rummy] #4558597
10/29/17 04:43 PM
10/29/17 04:43 PM
New Jersey
Ursatdx Offline
Ursatdx  Offline
New Jersey
Don't run in Eco-Mode if it bothers you.
5 hours and three changes of oil?
It's a Honda... put it away til you need it or once a year maintenance.
Re: New Honda EU2000i -Ruff Idle on Eco Mode [Re: rummy] #4558601
10/29/17 04:50 PM
10/29/17 04:50 PM
Canada
boraticus Offline
boraticus  Offline
Canada
I don't have an EU2000i but I do know people who own them and I've seen them run. In low rpm eco mode they're fairly smooth. I own a Yamaha EF2000i and it also runs smoothly at low speed.
My first suspicion would be that the low speed jet may have an obstruction. That's the first place I'd look. Another thing to check is to make sure the spark plug cap is on tight. I'd also look at trying a new plug to see if the problem goes away. If not, focus on fuel delivery and in particular the carb.
Pull the float bowl to see if there's fabrication debris in it. I've bought new equipment that wouldn't run properly right out of the box. Dropped the float bowl and found small plastic particles in it. Cleaned it out and it's run fine ever since.
Please do keep us apprised of your progress.
Re: New Honda EU2000i -Ruff Idle on Eco Mode [Re: Ursatdx] #4558606
10/29/17 04:55 PM
10/29/17 04:55 PM
Canada
boraticus Offline
boraticus  Offline
Canada
"Don't run in Eco-Mode if it bothers you."
Ummmm, that's the reason people buy expensive inverter generators.
The machine isn't running right. It needs attention. If it's still under warranty, the owner should bring it in to the dealership.
Re: New Honda EU2000i -Ruff Idle on Eco Mode [Re: rummy] #4558666
10/29/17 05:57 PM
10/29/17 05:57 PM
Jupiter, Florida
Cujet Offline
Cujet  Offline
Jupiter, Florida
Send it back or have it repaired. Mine is butter smooth at low rpm.
Re: New Honda EU2000i -Ruff Idle on Eco Mode [Re: rummy] #4558676
10/29/17 06:07 PM
10/29/17 06:07 PM
Houston, Texas
motor_oil_madman Online content
motor_oil_madman  Online Content
Houston, Texas
Give it some choke and see if it smoothes out. If so then its a plugged jet.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: New Honda EU2000i -Ruff Idle on Eco Mode [Re: rummy] #4558719
10/29/17 06:57 PM
10/29/17 06:57 PM
Elizabethtown, Pa
Al Online content
Al  Online Content
Elizabethtown, Pa
Small engines are not set up to run smoothly at idle. They are not that sophisticated. They are set up to run at load and operating rpm. How does it run at load. And why did you use a heavier oil to break in. If there is such a thing at break-in you want a lighter oil.
Re: New Honda EU2000i -Ruff Idle on Eco Mode [Re: rummy] #4558766
10/29/17 07:40 PM
10/29/17 07:40 PM
Richmond, BC, Canada
mechjames Offline
mechjames  Offline
Is it possible the OPE dealer did a PDI on it a few months before you bought it with ethanol gas? Anything over 30 days will start clogging carburetors.
86 Mustang 5.0L 170km - Amsoil XL 5w30 / Baldwin B2-HPG
14 Ram 1500 5.7 - Amsoil XL 5w20 / Baldwin B7443
98 Jeep ZJ 5.9 - Amsoil OE 10w30 / Baldwin B34
Re: New Honda EU2000i -Ruff Idle on Eco Mode [Re: rummy] #4558791
10/29/17 08:01 PM
10/29/17 08:01 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
How old is your Shell 93 with StaBil added? Did you try other fuel and get the same results?
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: New Honda EU2000i -Ruff Idle on Eco Mode [Re: rummy] #4558876
10/29/17 10:11 PM
10/29/17 10:11 PM
KansasCity
twoheeldrive Offline
KansasCity
You might have one with a bad spark plug cap. There is a service bulletin on it.
Here's a link to a discussion about it: Service Bulletin
... using Mobil 1 since 1976.
Re: New Honda EU2000i -Ruff Idle on Eco Mode [Re: rummy] #4558955
10/30/17 05:14 AM
10/30/17 05:14 AM
ON, Canada eh?
StevieC Online content
StevieC  Online Content
ON, Canada eh?
I would try fresh 87 octane without Stabil in it. Just as a temporary measure. This is what most generators would see because most people wouldn't go through the trouble of using Stabil or higher octane gas.
I have had a whole host of problems with small engines and Stabil and it's why I refuse to use it.
Then if it's still a problem I would investigate the idle jet and/or take it in under warranty for repair.
'18 Dodge Grand Caravan GT - 17k KM - AMSOIL SS 0w30
'06 Hyundai Santa Fe - 535k KM (Dead) - AMSOIL SS 0w30
Re: New Honda EU2000i -Ruff Idle on Eco Mode [Re: twoheeldrive] #4558960
10/30/17 05:23 AM
10/30/17 05:23 AM
Tampa, FL
rummy Offline OP
rummy  Offline OP
Tampa, FL
Thank you so much... I saw the bulletin and "YES" my unit came with the green dot sticker on the outside. The serial number is also one that is affected.
Thank you again!!! I will be taking it in for service, with the bulletin in hand.
'08 Highlander Sport 3.5L V6
PP 5W-30 & Fram Ultra
'15 Corolla LE
PP 0W-20 & Fram Ultra
Honda EU2000i
Delo 400 SAE 30
Re: New Honda EU2000i -Ruff Idle on Eco Mode [Re: mechjames] #4559188
10/30/17 09:50 AM
10/30/17 09:50 AM
Somewhere
itguy08 Offline
itguy08  Offline
Somewhere
All depends on storage and if a stabilizer was used. Our stuff is stored in a shed so it's out of the elements.
I think our generator has year old Ethanol gas in it. Just ran it for 3 hours today as the power was out. Smooth as silk and while a little cranky starting, ran fine. It's going on year 6 now always stored full, always with a dose of StaBil and MMO and the gas gets changed yearly. I try to run it monthly or at least a couple times a year.
Same with our riding lawn mower, mower, and pressure washer. All get filled at the end of the season with gas + StaBil + MMO. All have had no carb issues.
The only thing that gets special attention is the snowblower and it gets drained and the carb sprayed with a liberal dose of WD-40 and then put back together.
Re: New Honda EU2000i -Ruff Idle on Eco Mode [Re: rummy] #4559190
10/30/17 09:51 AM
10/30/17 09:51 AM
Somewhere
itguy08 Offline
itguy08  Offline
Somewhere
Reading that bulletin, the dot means it was fixed. Especially if you have the white mark on the boot.... But service may be in order as something doesn't sound right.
Re: New Honda EU2000i -Ruff Idle on Eco Mode [Re: rummy] #4568174
11/08/17 06:43 PM
11/08/17 06:43 PM
Tampa, FL
rummy Offline OP
rummy  Offline OP
Tampa, FL
Did not take in for warranty. Dished out $50 bucks and did this myself.
Changed out the ignition coil and replaced the OEM plug with a new Iridium plug by NGK CR5HIX (7120). Note* you will have to buy terminal nut for this plug separately.
Now this gen, runs amazing while in Ecomode with/without a load. No more ruff idle, no more hard starts, no more wanting to stall. Thanks for everyones input. Learned a lot.
'15 Corolla LE
Honda EU2000i
Delo 400 SAE 30
