Mattress shopping .....
by dblshock. 12/18/18 04:57 AM
AmazonBasics Oil May Drive Prices Down
by knerml. 12/18/18 04:45 AM
Hemi MDS issues are how common?
by Gasbuggy. 12/18/18 03:21 AM
Why use Redline and Redline Clone oils...
by burla. 12/17/18 11:38 PM
Tire choice
by CincyReds. 12/17/18 11:14 PM
Transmission fluid leak
by dawgn86. 12/17/18 07:53 PM
QuickJack BL-5000SLX and my Optima...
by WhizkidTN. 12/17/18 07:23 PM
Champion Air Filter Opinions?
by JerryBob. 12/17/18 06:18 PM
Tundra transfer case plug torque (Borg Warner)
by Idlewild294. 12/17/18 06:03 PM
Winter tire question?
by Muskieteer. 12/17/18 05:31 PM
Who makes good ball joints these days?
by GSCJR. 12/17/18 04:51 PM
Bought a used Ford Fusion
by krismoriah72. 12/17/18 04:14 PM
Valvoline NextGen Tech Oil
by DirtyOilGuy. 12/17/18 04:08 PM
Witty comment regarding a lame car
by Number_35. 12/17/18 03:43 PM
'80s oil literature
by Number_35. 12/17/18 03:26 PM
Recommend on oil for 2017 Kia Sportage 2.4
by SlavaB. 12/17/18 02:57 PM
No more Delo at my Costco. T4 now
by BeerCan. 12/17/18 02:16 PM
hopsofir, genera2800, oghl, hdlss, dsmdylan
66711 Registered Users
86 registered members (ABomb369, Audios, 2009Edge, b1amgm47, Astro14, 8 invisible), 1,482 guests, and 33 spiders.
Topics295,209
Posts4,929,984
Members66,711
Most Online2,553
Oct 27th, 2018
Rotella 10w30 CK-4 in CJ-4/SM bottle? w/pictures!! #4558465
10/29/17 01:51 PM
10/29/17 01:51 PM
Jacksonville, FL
FlyNavyP3 Offline OP
Jacksonville, FL
Good afternoon BITOG,
I took advantage of the mild (but windy) weather here this afternoon to change the oil in my 4Runner. Decided to use some of the Rotella T-4 10w30 CJ-4/SM that I bought at a screaming good deal back in February from Amazon in 3x 1 gallon boxes.
I remember hearing discussions here that CK-4 was already in CJ-4 bottles prior to the official switch over in January. Didn't give it much thought until today when I finally opened up the boxes of oil and pulled out the jugs. The oil was advertised on Amazon as CJ-4/SM and that's what the box said as well. Once I pulled out the jugs and saw the new style T-4 bottle I looked a little closer. According to the box these jugs were packaged after the new year yet still carry the CJ-4/SM rating. I suspect that this is in fact CK-4 in drag. Either way it's currently in my 4Runner replacing the VWB SAE 30 I'd put in back in the early summer. Enjoy the pictures.
Luke
Re: Rotella 10w30 CK-4 in CJ-4/SM bottle? w/pictures!! [Re: FlyNavyP3] #4558466
10/29/17 01:51 PM
10/29/17 01:51 PM
Jacksonville, FL
Jacksonville, FL
No idea why the site decided to turn 2/3 of those images on their side. Sorry about that.
Luke
Re: Rotella 10w30 CK-4 in CJ-4/SM bottle? w/pictures!! [Re: FlyNavyP3] #4558469
10/29/17 01:56 PM
10/29/17 01:56 PM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
Itís ok Luke. That is strange about the box and the jugs of oil in regards to API classification
09' Camry LE, 141,020 miles
PP 5w30 and TG 4967
Re: Rotella 10w30 CK-4 in CJ-4/SM bottle? w/pictures!! [Re: FlyNavyP3] #4558495
10/29/17 02:35 PM
10/29/17 02:35 PM
Jacksonville, FL
Jacksonville, FL
Not sure what the actual spec of the oil I installed, not that it matters either way, I have full faith and confidence that regardless of CJ-4 or CK-4 the oil will perform just fine in my little 4 cylinder.
Luke
Re: Rotella 10w30 CK-4 in CJ-4/SM bottle? w/pictures!! [Re: FlyNavyP3] #4558516
10/29/17 03:09 PM
10/29/17 03:09 PM
Houston, Texas
motor_oil_madman Offline
Houston, Texas
I can't remember when they switched over to ck4. I think it was around November 2016. Yes it was ck4 even though it said cj4 on the bottles. This question has been asked like 20 to.es before, so someone knows the answer.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Rotella 10w30 CK-4 in CJ-4/SM bottle? w/pictures!! [Re: FlyNavyP3] #4558695
10/29/17 06:24 PM
10/29/17 06:24 PM
Midwest, Illinois
beanoil Online content
beanoil  Online Content
Midwest, Illinois
No problem in your FourRunner.
Now if you had a FordRunner, there might be a discussion.....
beanoil: Tough under heat, real dirty afterwards.
Re: Rotella 10w30 CK-4 in CJ-4/SM bottle? w/pictures!! [Re: beanoil] #4559402
10/30/17 03:12 PM
10/30/17 03:12 PM
Jacksonville, FL
Jacksonville, FL
Isn't that the truth! What a mess Ford has with the CK-4 Diesel situation. On a side note the 4Runner made it to work and back without blowing up so I thought must be good wink
Luke
Re: Rotella 10w30 CK-4 in CJ-4/SM bottle? w/pictures!! [Re: FlyNavyP3] #4559958
10/31/17 07:45 AM
10/31/17 07:45 AM
Midwest, Illinois
Midwest, Illinois
Ford has never been great with fluid recommendations, they are just continuing a long standing tradition. grin
Mercon LV, or Mercon SP? 5w30, back spec to 5w20? 5w20 in the Ecoboost until it didn't work, then 5w30 was OK. 5w30 unless the tensioners act up, then 10w40....
Whoever is in charge of the folks in fluids at Ford should clean house, then be fired themselves.
Eventually, CK-4 will be OK because that's all you'll be able to get.
Re: Rotella 10w30 CK-4 in CJ-4/SM bottle? w/pictures!! [Re: FlyNavyP3] #4588641
11/29/17 10:42 AM
11/29/17 10:42 AM
Houston, TX
ChrisGuerrero Offline
Houston, TX
Hi FlyNavyP3, good question! The bottles do indeed contain the latest CK-4 formulation, though when you purchased the product, Rotella was in the midst of transitioning to the new packaging. Hope this helps!
Re: Rotella 10w30 CK-4 in CJ-4/SM bottle? w/pictures!! [Re: ChrisGuerrero] #4621977
01/02/18 05:02 PM
01/02/18 05:02 PM
Jacksonville, FL
Jacksonville, FL
Chris,
Thank you for clearing up my suspicions that this contained CK-4, the oil is currently in service in my truck and I will follow up with a UOA in a few months.
Thanks again for the feedback!
Luke
