AeroShell W100 SAE50 in Motorcycles?
by CCI. 03/25/19 11:02 PM
Spark plug torque when using anti-seize
by Reddy45. 03/25/19 10:58 PM
My kid is 8 now - use the front seat?
by y_p_w. 03/25/19 10:53 PM
2005 Pontiac GTO | 44,750 miles | 6-Speed
by Georgiey22. 03/25/19 10:39 PM
GWR Silencer Spray
by agpatel. 03/25/19 10:30 PM
Fuel line insulation to remedy vapor lock?
by motor_oil_madman. 03/25/19 10:22 PM
Running a fan to reduce humidity
by motor_oil_madman. 03/25/19 10:15 PM
stuck grease zerk on my JD tractor
by PaulH. 03/25/19 09:33 PM
S&W M&P 2.0 9MM Range Time
by 2015_PSD. 03/25/19 09:26 PM
Poor quality Ford wheel finish...
by gregk24. 03/25/19 09:12 PM
2013 GMC SIERRA PICKUPS
by Honda2003. 03/25/19 09:10 PM
Fighting HOA - anyone have any luck?
by pezzy669. 03/25/19 09:05 PM
Here's an oldie "Riding a film of oil"
by dbias. 03/25/19 08:47 PM
'14 Mopar 62TE transmission service?'s
by sloinker. 03/25/19 08:25 PM
Dodge Transmissions (Humor)
by StevieC. 03/25/19 07:57 PM
How a differential works
by StevieC. 03/25/19 07:37 PM
My first!
by BigMoneyGrip. 03/25/19 07:20 PM
Sizing Rims for 17 inch Light Truck Tires
by Snagglefoot. 03/25/19 06:38 PM
DCDMan, silverbullet21, gentzel, ksu90, SMA2020
67622 Registered Users
56 registered members (aaronc7, ArrestMeRedZ, bbhero, 2003f7, Aero540T, 2010Civic, 3 invisible), 1,190 guests, and 68 spiders.
Topics286,439
Posts4,908,177
Members67,622
Most Online2,967
Mar 10th, 2019
2006 chrysler 300 NAG Transmission #4558307
10/29/17 11:35 AM
10/29/17 11:35 AM
ny
jeep58 Offline OP
jeep58  Offline OP
ny
I have this car with 74000 original miles on it, 3.5 engine with mercedes 6 speed transmission no dip stick! It shifts good, question should i have transmission serviced or just leave it alone, transmission shop can either flush it or change filter. I have heard to change the fluid and also just leave it alone frustrating can not even check the fluid on this transmission!
Re: 2006 chrysler 300 NAG Transmission [Re: jeep58] #4558312
10/29/17 11:44 AM
10/29/17 11:44 AM
Rainville, USA
JEL01 Offline
JEL01  Offline
Rainville, USA
Pan drop and filter change, OEM/MBZ approved fluid and OEM filter only. Mercedes transmissions are robust and live a long life with basic fluid and filter changes. Try to do it every 30-40k from here on
Cars I maintain:
02 MB CLK430-Edge 0w40
05 Honda Accord V6-Maxlife 5w30
13 Lexus RX350 AWD-M1 AFE 0w20
02 Toyota Tundra 4x4 M1 5w30
Re: 2006 chrysler 300 NAG Transmission [Re: jeep58] #4558330
10/29/17 12:03 PM
10/29/17 12:03 PM
ny
jeep58 Offline OP
jeep58  Offline OP
ny
Thanks, Should I have the stealership do this or a transmission shop do the job? I would do this myself but no dip stick is there so they really do not want you messing around with it!
Re: 2006 chrysler 300 NAG Transmission [Re: jeep58] #4558338
10/29/17 12:15 PM
10/29/17 12:15 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
I would change it. My dad's Dodge Caravan has a Mercedes sealed for life transmission and I change the fluid every 100K KM's. It's still going strong at 300K. There was lots of shrapnel stuck to the magnet in the pan. wink
'18 Dodge Grand Caravan GT - 26k KM - AMSOIL SS 0w20
'06 Hyundai Santa Fe - 535k KM AMSOIL SS 0w30
Re: 2006 chrysler 300 NAG Transmission [Re: jeep58] #4558358
10/29/17 12:49 PM
10/29/17 12:49 PM
Rainville, USA
JEL01 Offline
JEL01  Offline
Rainville, USA
Probably best to let the dealer do it, correct fluid and filter will be used. Another option would be a trustworthy indie who will use the right stuff.
Cars I maintain:
Re: 2006 chrysler 300 NAG Transmission [Re: jeep58] #4558368
10/29/17 01:10 PM
10/29/17 01:10 PM
USA
slacktide_bitog Online content
slacktide_bitog  Online Content
USA
If your transmission pan doesn't have a drain plug, get the Dorman pan that has one, making future ATF changes much easier. And Maxlife is good stuff and will work well in your transmission smile
Re: 2006 chrysler 300 NAG Transmission [Re: jeep58] #4558381
10/29/17 01:26 PM
10/29/17 01:26 PM
Georgia
AVB Offline
AVB  Offline
Georgia
I think that that one has the plastic pan that you are supposed to replace when removed. I will have to double check, I know it is a pain to check the fluid in those because the exhaust pipe is in the way of the plug which takes a Allen key.
Re: 2006 chrysler 300 NAG Transmission [Re: jeep58] #4558389
10/29/17 01:37 PM
10/29/17 01:37 PM
Georgia
AVB Offline
AVB  Offline
Georgia
Ok the Nag is the one that take a special dipstick to check, the dipstick tube is at the back of the intake manifold with a black plastic plug in the top. You have to check the fluid temperature with a scan tool with the transmission in drive, then you measure the level with the special dipstick in park and compare it to the graph that shows the proper level in mm for the fluid temp. It takes 5 liters of Atf+4 for a filter change and you can reuse the pan on that one.
Re: 2006 chrysler 300 NAG Transmission [Re: jeep58] #4558403
10/29/17 01:49 PM
10/29/17 01:49 PM
Georgia
AVB Offline
AVB  Offline
Georgia
The 8HP is the one that you have to replace the pan on and it takes a special green oil.
Re: 2006 chrysler 300 NAG Transmission [Re: jeep58] #4558445
10/29/17 02:29 PM
10/29/17 02:29 PM
ny
jeep58 Offline OP
jeep58  Offline OP
ny
I am thinking good job for dealer to do, wandering how much they get for this? Thanks for the good information!
Re: 2006 chrysler 300 NAG Transmission [Re: jeep58] #4570790
11/11/17 12:28 PM
11/11/17 12:28 PM
ny
jeep58 Offline OP
jeep58  Offline OP
ny
I had the dealer change fluid and filter only, I hope it will be ok so far so good!
