How reliable turbos and CVT's really are?
Atlantic, Canada
Hey guys,
I will get a new car sooner or later, and a lot of models now have CVT's and turbo engines.
To a durability perspective, are these two items durable for 8-10 years with good maintenance?
with both turbos and cvt transmissions proper lubrication with a top quality oil is essential for longevity. There is a great online resource for information like that but i cant think of its name right now.
It's something like Ron is the oil man or boy or something
My old boss has a 90s turbo Volvo with close to 400k on it on the stock turbo. We talked cars often and he always talked about how good it was.
Originally Posted By: Emanuel
But I don't think a turbo would last 15 years and 300k miles
My 2000 VW GTI 1.8L turbo has 327k miles on the original turbo, with less than recommended maintenance.
First: Make sure the turbo charger is water cooled!!!
-Oil (only) cooed turbo's have a significantly higher risk of 'coking' the oil on shutdown, as their is no water to hold temperatures in the bearings below 100°C.
-This is responsible for many VW BKD 2.0L turbo failures
Always use the correct specification synthetic oil.
Change it at no more than 10,000kms. In Aus, anyone running turbo performance cars is 5,000kms. If you cruise the freeway to work regularly, 10,000kms is fine. 15,000mile OCI's on turbo petrol vehicles are a recipe for turbo failures. The sump's (too small) and filters simply can't deal with it. Big Diesel truck engines can get away with +20,000mile OCI's as the sump's are massive and have multi stage filtration. they also tend to run long kms cross country. most punters don't.
-As everyone here will attest, regular maintenance and inspection of your car is the simplest and cheapest way to ensure many years of happy motoring.
As for a CVT. the real question is do you have a soul (any sort of passion, not a religious thing?) and if the answer is yes, then why would you buy a car with an utterly soulless transmission.
I agree. Anyone trying to extend an OCI on a passenger car gas turbo is asking for it.
By the way. JFAllen, if you're looking to sponsor any one from the U.S.A. to Albury, I'm first in line!
Well you are right, but nowadays the turbos of downsized engines have to work a lot harder than the ones in your GTI. They gotta make boost even when you are accelerating slowly in traffic. On the other side the turbos of your GTI are used mostly in hard acceleration.
That is why I think that the turbos of new cars won't last as much as the ones from 10 years old plus engines
Not really true at all... I've pushed my CVT in my car many, many times. Well above the regular rpm range 2-3k rpm. A whole bunch of times 4400-6000 rpm. It has been just fine. And continues to be very good.
The turbos of today also have better metallurgy and engineering than turbos of old. Not saying they're all good, but I would definitely use an oil that is a beast at high temperature.
HDEO seems to be great at this, whether dino or syn. Probably because resistance to coking is a major part of an HDEO getting manufacturer certs.
Not just for the turbo, but because the pistons tend to run on the hot side of the spectrum as well. A lot of engine builders I have known who were into small displacement turbo engines have told me that turbo engine pistons love to cook almost as much as turbos in shutdown. Mainly in the ring pack.
We see some nasty stuff in the marine realm as well. Piston and oil temps can get real stupid when those things are wide open. People who like to put the hammer down with a dirty bottom sometimes melt them entirely.
Well...only 225,000 miles on the original turbo in my Wife's Volvo XC, so time will tell if it gets to 300,000.
192,000 on the original turbo on the T5. Original turbos on the s600 are at 96,000 now.
So, will a turbo last?
I'm betting they will. Two of my cars have already made it past your 15 year point. Most cars don't make it to 300,000, but my wife's is well on its way with its original turbo.
A turbocharged engine, operated on a quality synthetic oil, with regular oil changes, will last a very long time. The turbocharger itself will also last if the above conditions are met, along with the requirement for good air filtration and no chance of debris or water getting in. Over long periods of time, say 300K miles, the aluminum compressor will show signs of significant erosion with less than perfect air filtration due to various reasons (mostly poor maintenance) . Good maintenance is key.
I think the main issue with turbos is that they need proper maintenance. So in the used market, I'm going to be quite picky with seeing a good set of maintenance records before I buy a turbo car.
As of today, they are both very old, well established technologies. Like anything you can do it right and you can do it wrong, but there should be no fundamental reason why both wouldn't be reliable, long lasting units.
Ive driven multiple MB diesels >>200k with turbos being original.
Turbos arent new technology, its sort of laughable to conflict user error (the idiot who uses API SA top up oil to save a buck, or drives like an imbecile) from design error.
CVTs? eh.
