I browsing on this forum and I found this article: Thinner oil provides better oil seal where an User called autoreign said this:
Quote:
The article seem suggest that the oil flow on the piston rings pack is more likely to flow through the gap on each piston ring to get to the top ring. Hence, lower viscosity oil, being able to flow better, will provide a thicker oil film at bottom of the Top ring,
Do you really think that a thinner viscosity oil could make a better seal in the piston rings? I thought that a higher viscosity oil would be better for sealing because the general recommendation when a engine starts to use oil is to switch to a higher viscosity oil and in fact I have noticed 37% more oil consumption in my car with 15w40 than with 20w50 (maybe the oil viscosity isn't the one increasing my consumption but other factors)
I really don't want to talk about my car's oil consumption in this post, what I would like to know if you have noticed lower oil consumption with thinner oils. Or if there is another factor in oil selection that can lower oil consumption like HTHS, VI, base oil quality, NOACK, etc.
