Lovin' the Ecotec!
by IndyFan. 12/15/18 06:10 AM
Air Impact Wrench
by BenZahel. 12/15/18 05:19 AM
Luber finer 750 bypass oil filter info
by BigRich954. 12/15/18 03:59 AM
Ford Pickup Front Wheel Bearings 2WD
by benjamming. 12/14/18 10:52 PM
GMC oil fill tube
by Redright9. 12/14/18 10:24 PM
Where do I buy Toto toilets? That has them!
by Vern_in_IL. 12/14/18 10:04 PM
Best filter cutter for the price?
by DONWATERS. 12/14/18 09:38 PM
5W-40 vs 10W-30 for a 2018 Audi A4
by jcr1293. 12/14/18 09:25 PM
Gave up on quadrajet electric choke today...
by leroyd92. 12/14/18 08:54 PM
2015 Odyssey - Which synthetic ATF?
by AngryScientist. 12/14/18 07:56 PM
Hyundai extended my warranty
by ernied. 12/14/18 07:33 PM
2016 Traverse 6350mi Schaeffers 9000 5W30
by chevman4life. 12/14/18 07:21 PM
Oil filter for Canadian winter
by Popsy. 12/14/18 06:11 PM
12-14-18 only! Irwin vise @ Menards. $99.99
by Kruse. 12/14/18 06:01 PM
10" Subwoofer - $6.52 Each
by Greg L. 12/14/18 05:31 PM
Finding 507.00 spec oil
by sloinker. 12/14/18 05:31 PM
New Tires for the Old Chevy!
by dogememe. 12/14/18 05:09 PM
NEKGuy, Deltafaatl, wsalopek, jcr1293, maxwellk
66684 Registered Users
48 registered members (BenZahel, 4WD, bernardch, 2003f7, bfleeman, bullwinkle, 10 invisible), 963 guests, and 43 spiders.
Topics295,093
Posts4,927,688
Members66,684
Most Online2,553
Oct 27th, 2018
Gm V8 shaking in idle #4557532
10/28/17 05:23 PM
10/28/17 05:23 PM
ON, Canada
yugrus Offline OP
yugrus  Offline OP
ON, Canada
I have '14 Tahoe with 5.3L. Whenever I come to stop after driving, the engine doesn't idle smooth. Well, it does, for about 20 seconds. Silky smooth. After that, I can feel a faint shake through the floor. Before you say you don't feel it in your truck, put your left knee against the door trim while the engine is idling. Or look at the water in your plastic bottle in the cupholder.
The throttle body, MAF sensor and the engine's insides overall are clean. I wiped the intake pretty good through the TB opening while cleaning it. Smoked the engine multiple times through vacuum booster, no air leaks. I have AFM disabled through the stock tune (the only thing that is changed in the parameters). And there is a two-stage (sequential) catch can on the dirty driver's side.
I've been in several 5.3 trucks, and they all felt pretty much the same. Even the new gen DI engines have that faint shake.
So what is it? Why the engine is smooth for a while, and then shakes all of a sudden, and runs like that thereafter in idle?
'14 Chevrolet Tahoe
'15 Mazda CX-5
Re: Gm V8 shaking in idle [Re: yugrus] #4557569
10/28/17 05:47 PM
10/28/17 05:47 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
How much mileage do you have on the upstream oxygen sensor(s) ?
I have the exact same problem and have been thinking of changing the upstream oh-two.
Re: Gm V8 shaking in idle [Re: yugrus] #4557613
10/28/17 06:17 PM
10/28/17 06:17 PM
IL
04SE Offline
04SE  Offline
IL
My 2014 Silverado does the same thing BUT only on 87. If I have E85 in the tank she is silky smooth at idle.
Idling in park I don't notice it as much. Idling at a stop light with my foot on the brake is when I notice it most.
Life's little problems can be solved with a shovel and silence.
Re: Gm V8 shaking in idle [Re: yugrus] #4557621
10/28/17 06:21 PM
10/28/17 06:21 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
Does the shakiness change if you stop at a light and then put it in neutral? Could be motor mounts. Not necessarily bad motor mounts, just they might not be designed to make it so smooth you can balance a penny on the engine.
2015 Hyundai Sonata 2.4L 88k Motorcraft Synthetic Blend 5w30 & OEM
2000 Toyota Camry 2.2L 231k Valvoline 5w30 & Fram Ultra
1996 Jeep Cherokee 4.0L 147k Mobil 1 HM 10w40 & Fram Ultra
Re: Gm V8 shaking in idle [Re: yugrus] #4557636
10/28/17 06:30 PM
10/28/17 06:30 PM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
Find someone with an advanced code reader ( that can display real time data ) and that knows how to use it .
How are the spark plugs and the rest of the ignition system ?
Best of luck to you , :-)
Wyr
God bless
Re: Gm V8 shaking in idle [Re: yugrus] #4557642
10/28/17 06:37 PM
10/28/17 06:37 PM
Miami Beach
Tahoe4Life Offline
Tahoe4Life  Offline
Miami Beach
My 2016 Tahoe does it also. Not everyday though. Mostly in nasty gridlock. Does not bother me that much.
2016 Chevrolet Tahoe LT
Mobil 1 0w20 AFE or EP
AC Delco Filters
Re: Gm V8 shaking in idle [Re: yugrus] #4557716
10/28/17 07:27 PM
10/28/17 07:27 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
Could it be the IAC is a bit sticky and now allowing enough air in for a smooth idle?
'18 Dodge Grand Caravan GT - AMSOIL SS 5w20
'06 Santa Fe - 535,000km AMSOIL SS 0w30 / ATF
Re: Gm V8 shaking in idle [Re: yugrus] #4557784
10/28/17 08:18 PM
10/28/17 08:18 PM
NW Iowa
alchargo Offline
alchargo  Offline
NW Iowa
My '13 Avalanche does the exact same thing. As did my old Silverado 5.3. Seems to be a common issue. I think it comes with the ownership of a GM 5.3.
Re: Gm V8 shaking in idle [Re: yugrus] #4557888
10/28/17 09:51 PM
10/28/17 09:51 PM
Phoenix
dishdude Offline
dishdude  Offline
Phoenix
Could it be dropping the idle 50 or 100 RPM to save fuel?
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI
Re: Gm V8 shaking in idle [Re: yugrus] #4557897
10/28/17 09:57 PM
10/28/17 09:57 PM
PR CA, USA
2strokeNorthstar Offline
PR CA, USA
It's an emissions thing. They have to run them really lean at idle for smog reasons or so I was told. Had a 6.0L vortec that did it since new. The Drive-Thru was really annoying in that thing. Hate on Modular Fords all you want they are some smooth running motors.
Re: Gm V8 shaking in idle [Re: 2strokeNorthstar] #4557941
10/28/17 11:07 PM
10/28/17 11:07 PM
Clovis, CA
Merkava_4 Offline
Merkava_4  Offline
Clovis, CA
I always thought that an engine idling smoothy is an engine that's burning cleanly. No missfires.
Re: Gm V8 shaking in idle [Re: yugrus] #4557959
10/28/17 11:46 PM
10/28/17 11:46 PM
ON, Canada
yugrus Offline OP
yugrus  Offline OP
ON, Canada
Ok. Oxygen sensors are original, that makes it three years, pretty much brand new.
No E85 available here in Ontario where I am. Tried Shell 97, no ethanol, the truck didn't see the difference at all. Still shakes in idle.
Putting it in neutral doesn't make huge difference. Still shakes. Checked motor mounts for the torque twist, all solid.
I'very got Tech2,not sure what is more advanced reader there is... I didn't see anything out of order regarding fuel trim or air, idle or driving.
IAC- can't be sticky throttle plate, as I cleaned everything pretty good, including the shaft. It didn't make a difference anyway.
Gotta check actual injector timing when it starts happening. If they trim it significantly after idling for a while, will talk to Diablo to make some adjustments to the stock tune... I bet they know about the issue anyway...
I conclude that GM is doing it for emissions, as most owners would not notice that faint shake anyway. If I find a solution, I'll post it here.
'14 Chevrolet Tahoe
'15 Mazda CX-5
Re: Gm V8 shaking in idle [Re: yugrus] #4557974
10/29/17 12:06 AM
10/29/17 12:06 AM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
Shell 97 with no ethanol? I'm moving to Canada! thumbsup
This really seems to be a GM V8 thing. Got 3 NPR HDs with LS based engines, and the vibe is something they just do. Never thought about it, because they have a job to do, and I could care less about NVH, but it's something I might start investigating for the H of it.
On the other hand, I've had and come across a lot of silky big blocks.
Re: Gm V8 shaking in idle [Re: yugrus] #4558279
10/29/17 09:45 AM
10/29/17 09:45 AM
Texas
WyrTwister Offline
WyrTwister  Offline
Texas
For what it may or may not be worth , the company 2008 Chevy Silverado , I think has the 4.8l LS engine . 160,000 miles , still has the OEM spark plugs . Purrs along at idle , on E10 .
Best of luck , :-)
Wyr
God bless
Wyr
God bless
Re: Gm V8 shaking in idle [Re: yugrus] #4558718
10/29/17 06:56 PM
10/29/17 06:56 PM
Hudson, NH
LeakySeals Offline
LeakySeals  Offline
Hudson, NH
I've been complaining about a strange idle in my GM 6.0 for the past 3 years I've owned it. Not always there, but some days I feel it sitting at a light. Best way to describe it is an electrical pulse. I've changed a ton of stuff. Its not vacuum. Not knock sensors. Not the TB. Not the plugs, coils. Not the catalyst. Transmission mount really helped a lot. Motor mount on drivers side should be replaced, feel it a little in the wheel. Can't see the engine shaking. But if you put your hand on the engine you feel it. A vibration that doesn't feel like a traditional ruff idle. Does not feel or act like a skip. Something electrical. Could be the lean at idle thing cause replacing the knock sensors reduced the frequency. And on cooler days doesn't happen. I've spent enough trying to fix the idle. Now its gonna be the insulation between me and the engine. Rubber mounts. I can't feel it as much with M1 5w30 as I can with other oils. Why who knows
06 Escalade 6.0L LQ9 AWD 165k M1 0w40
03 Maxima 3.5L POS 152k ST HM 10w30
