Replaced halogen headlight with LED
by gman2304
17 minutes 31 seconds ago
Web Archive
by Duffyjr
Today at 10:25 AM
Sonoma This weekend!
by racin4ds
Today at 10:22 AM
low water pressure on new kitchen faucet
by Joe1
Today at 09:40 AM
Flashing third tail light
by Brigadier
Today at 08:59 AM
Intermittent AC Cooling
by Gebo
Today at 08:59 AM
Who includes full size spare in tire rotation?
by Parlay_Slow
Today at 08:45 AM
Crude and foul behavior
by mjoekingz28
Today at 08:31 AM
Best Off The Shelf Car Wash Liquid ?
by ChrisD46
Today at 08:30 AM
Wrecking Yards
by Snagglefoot
Today at 08:26 AM
F1 - 2018 French Grand Prix
by gofast182
Today at 08:14 AM
AAP 25% Off
by Egg_Head
Today at 06:03 AM
GM Ecotec 2.4 - Cracked Exhaust Manifold
by The Critic
Today at 05:05 AM
Half Price - Shell Helix HX7, Castrol Edge and GTX
by SR5
Today at 03:59 AM
Why hang your bicycle from the ceiling?
by mjoekingz28
Today at 03:47 AM
Oil For High Sustained RPM on BMW S52
by ZEK
Yesterday at 10:41 PM
Chevy brought the blazer back
by WiskyBadger
Yesterday at 10:07 PM
LC20 and uses in modern motor oil
by synman
Yesterday at 10:01 PM
Full Synthetic CJ-4 or > 5W-30 or 10W-30
by LeTempt
Yesterday at 09:57 PM
2018 RAM 1500 EcoDiesel
by OVERKILL
Yesterday at 08:37 PM
Fatbrowndog0822, DRNJR, ZEK, Dudewayne, kmdz
65294 Registered Users
76 registered (4WD, 2012AccentSE, bdcardinal, asiancivicmaniac, Al, 4 invisible), 1557 Guests and 39 Spiders online.
65294 Members
67 Forums
285764 Topics
#4557452 - 10/28/17 04:54 PM tiller wont stay running
Jakegday Offline
Loc: fremont nebraska
hey guys. I have a troy bilt rear tine tiller im borrowing from a relative. It worked perfect in the spring, but i just went to use it now, and it wont stay running. it ran for a couple minutes the first start, then i had to wait a couple hours before it would start again. Then when it did start again, it only ran for a few seconds. Air filter is good. Gas is good, and is getting to the carb. Spark plug looks ok. oil level is good. What should i try next?
2001 Pontiac Grand Prix GT
1981 Ford Fairmont
1978 Ford Ranchero GT
#4557462 - 10/28/17 05:04 PM Re: tiller wont stay running [Re: Jakegday]
ZZman Offline
Loc: Michigan
If it has a float bowl with a bolt on the bottom (jet) clean it. Make sure the holes in it are not clogged. You might try carb cleaner and even a pin to try and clean the holes. Dirt or rust particles may have clogged them.
Edited by ZZman (10/28/17 05:05 PM)
2003 Mercury Grand Marquis. Rotella T6 Multi-Vehicle oil
2008 Sebring Hardtop convertible. Rotella T6 Multi-Vehicle oil
2006 Kawasaki Vulcan 900 LT. Amsoil Metric 10w-40
#4557482 - 10/28/17 05:23 PM Re: tiller wont stay running [Re: Jakegday]
Warstud Offline
Loc: MIchigan
You may be in luck since it runs. Just get some Techron, Berrymans or Gumout Regane and pour the recommended amount in the gas tank and run it.
#4557503 - 10/28/17 05:45 PM Re: tiller wont stay running [Re: Jakegday]
boraticus Offline
Loc: Canada
Agree with ZZman but I'd also look at the float needle and seat for the fuel inlet to ensure fuel is getting into the float bowl in sufficient quantity to keep the engine running. Sounds like fuel is getting into the float bowl but not supplying enough for constant running.
Clean everything with a wire and blow the jets and galleries out with compressed air. Another place to check is the fuel line from the fuel tank. Make sure the tank isn't full of rust/sludge. Disconnect the fuel line from both carb & tank and blow it out. Also ensure the fuel cap air vent isn't blocked. Sometimes that malfunctions and air cannot get into the tank. Thus a vacuum occurs restricting fuel flow.
If the fuel system is working properly and the problem still exists, time to check out the coil/condenser if it's an older engine. Otherwise,if it has CDI ignition, it may be malfunctioning when it gets hot.
Cover the above bases and the machine should run.
#4557505 - 10/28/17 05:47 PM Re: tiller wont stay running [Re: Warstud]
krismoriah72 Offline
Loc: wv
ethanol related OPE problem. I have a troy bilt horse that I paid $75 for because it wouldnt stay running..cleaned the carb and installed a fuel shutoff valve..runs good. I dont think anything short of taking it apart would have gotten the ethanol goodies that were clogging the jets out.
#4557512 - 10/28/17 05:52 PM Re: tiller wont stay running [Re: krismoriah72]
boraticus Offline
Loc: Canada
Agreed. Snake oils are seldom ever effective at doing anything let alone clearing blocked jets/orifices and galleries.
#4557521 - 10/28/17 06:05 PM Re: tiller wont stay running [Re: Jakegday]
Merkava_4 Offline
Loc: Clovis, CA
Engine Brand ?
Model Number ?
Type Number ?
Code Number ?
Serial Number ?
#4557568 - 10/28/17 06:46 PM Re: tiller wont stay running [Re: Jakegday]
Jakegday Offline
well you guys were spot on.. I took the carb off, and took it apart. I shoved a small wire through the jet and every other opening, then sprayed a half can of carb cleaner in to, and all over it, and now its running perfect. Just ran it for 40 minutes straight at full load with no issue! thank you guys!
1981 Ford Fairmont
#4557622 - 10/28/17 07:22 PM Re: tiller wont stay running [Re: Jakegday]
Merkava_4 Offline
Loc: Clovis, CA
And now I'll never know which engine it was or the model number.
I have all this service information on my computer for nothing. frown
#4557672 - 10/28/17 08:01 PM Re: tiller wont stay running [Re: Jakegday]
ZZman Offline
Loc: Michigan
Great! Now buy a small fuel line filter and you will be set!
#4558073 - 10/29/17 07:32 AM Re: tiller wont stay running [Re: Merkava_4]
Vern_in_IL Offline
Loc: IL
It's a tiller, not a space shuttle. smile
