DIY alignment done right?
by tookien. 03/24/19 10:03 PM
Cell phone privacy question
by loneryder. 03/24/19 10:00 PM
Ride quality between 45 and 35 sidewall
by bowlofturtle. 03/24/19 09:23 PM
FRAM TG 7317 - 12K miles opened
by crazy_raccoon. 03/24/19 09:01 PM
2014-2017 Toyota Corolla CVT Quiet Recall
by StevieC. 03/24/19 08:11 PM
Finally Found Factory Ammo my 308 Bolt Gun Likes
by Fastzntn. 03/24/19 08:10 PM
Umarex Glock 19 Co2
by Sonic. 03/24/19 07:57 PM
I put in 2 1/2 qts, damage?
by JLawrence08648. 03/24/19 07:21 PM
How to dispose / recycle Li-Ion batteries?
by 92saturnsl2. 03/24/19 06:16 PM
New member of the (automotive) family!
by addyguy. 03/24/19 06:04 PM
6.2 f250 6.4 ram 2500 towing with a gasser
by FLORIDA. 03/24/19 05:55 PM
T5 15w40 for my bike?
by Degreaser. 03/24/19 05:47 PM
Studded tires in warm weather
by y_p_w. 03/24/19 05:28 PM
ST 15W40
by mobilaltima. 03/24/19 05:02 PM
I need a filter cutter person
by Marco620. 03/24/19 03:21 PM
VIRGIN BOSCH D+ 3421 CUT OPEN
by 53' Stude. 03/24/19 02:45 PM
My first cut. Donaldson P502503
by BeerCan. 03/24/19 02:25 PM
Rollo, Drifted, Jcar516, gregjr7, daveed
67613 Registered Users
89 registered members (4WD, 2015_PSD, 2010Civic, ArrestMeRedZ, aleneros, ammolab, 9 invisible), 1,680 guests, and 57 spiders.
Topics286,361
Posts4,907,079
Members67,613
Most Online2,967
Mar 10th, 2019
Page 1 of 3 1 2 3
Should I extend my oil change intervals? #4557446
10/28/17 04:47 PM
10/28/17 04:47 PM
Venezuela, South America
Emanuel Offline OP
Emanuel  Offline OP
I have a 01 Corolla with 285k miles, I have always used an API SL 20w50 Conventional oil and a 3k mile interval. When I began to browse through this forum I decided to start using an API CI4/SL rated 15w40 oil because I learned that a thicker oil isn't always the best option.
My car is using 1 qt of oil every 1k miles and it has a 4qt oil pan, so at the end of the interval I have added more than 3qts of make-up oil. I'm only getting 25 mpg because of the way I drive. My guess with this level of oil consumption and this fuel mileage is that I shouldn't extend my OCI too much, but I don't know if even in this "harsh" conditions a 3k OCI is an overkill. My next oil change will be with Motorcraft HDEO 15w40 CJ4 Rated BTW.
Re: Should I extend my oil change intervals? [Re: Emanuel] #4557460
10/28/17 05:03 PM
10/28/17 05:03 PM
texas
danez_yoda Offline
danez_yoda  Offline
texas
when did it start consuming that much oil? If its been gradual over time it may br the rings are caked up. I high mileage oil or cleaning oil additive may help slowly desolve it,
Using that much oil you could probably leave the filter on for 6k since you have already changed most of the oil.
How does the oil look on the dipstick at 3k with that much fresh oil added?
Re: Should I extend my oil change intervals? [Re: Emanuel] #4557464
10/28/17 05:06 PM
10/28/17 05:06 PM
Hawaii, USA
anndel Offline
anndel  Offline
Hawaii, USA
You may want to switch to a high mileage synthetic oil and extend the OCI to 5000-7500 miles. Do you know what's causing the oil loss? leaks? oil burning?
1993 Toyota 4x4 p/u, 2.4L 22RE 4 cyl - M1 EP 10W-30, Fram UG Filter
2005 Toyota Avalon XL, 3.5L V6, Amsoil SS 5W-30, Amsoil Filter
2014 Toyota Tacoma 4.0L V6, Amsoil SS 5W-30, Yota OEM Filter
Re: Should I extend my oil change intervals? [Re: Emanuel] #4557471
10/28/17 05:15 PM
10/28/17 05:15 PM
NoVA
Jimzz Offline
Jimzz  Offline
NoVA
SL rated? Is that really common oil in your country or old stock?
But yea I would go for 4-5k as long as you keep it topped off and use a newer rated oil. The Motorcraft HDEO 15w40 CJ4 will be fine. Try and see if you can find some Valvoline Maxlife 15w40.
yup
Re: Should I extend my oil change intervals? [Re: Emanuel] #4557493
10/28/17 05:31 PM
10/28/17 05:31 PM
Toronto Canada
WobblyElvis Offline
WobblyElvis  Offline
Toronto Canada
I would extend the oil change interval to maybe 6,000 miles or more. No need for synthetic in my opinion. If you cut open the oil filter and find carbon in the media pleats, burnt fuel is blowing past the rings and this will lead to carbon fouling the rings. Maybe this has already happened of the rings are simply worn.
Re: Should I extend my oil change intervals? [Re: Emanuel] #4557524
10/28/17 06:09 PM
10/28/17 06:09 PM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
What oil does the manual spec. 20W50 sounds thick.
2015 Ford F250 w/Powerstroke
Re: Should I extend my oil change intervals? [Re: Emanuel] #4557557
10/28/17 06:40 PM
10/28/17 06:40 PM
Crawfordville FL
SilverFusion2010 Online content
SilverFusion2010  Online Content
Crawfordville FL
You could run 10k with a fram ultra as long as you keep up with the top offs. Your car is basically changing its own oil. I would check all the usual suspects though.
PCV valve
Leaky gaskets
Some sort of engine flush to free up stuck rings. Kreen or BG109.
My personal favorite HM oil is M1 HM 10w-30. Its almost thick enough to be a 40 and has great cleaning cleaning power
2010 Ford Fusion SE 3.0L V6, 181 miles M1 HM 10w-30
Re: Should I extend my oil change intervals? [Re: Emanuel] #4557588
10/28/17 06:59 PM
10/28/17 06:59 PM
PA
Lasthope05 Offline
Lasthope05  Offline
PA
If you burn through almost all of your oil during a normal OCI what is the point of even worrying about changing it out. Using 1qt every 1000 miles, I wouldnt even bother changing the oil, just keep topping it off and only change the filter everything now and then. The add pack will constantly be refresh by the sheer quantity of oil being consumed.
Re: Should I extend my oil change intervals? [Re: Emanuel] #4557595
10/28/17 07:05 PM
10/28/17 07:05 PM
in the shop
sw99 Offline
sw99  Offline
in the shop
Sounds like a typical 1ZZ-FE. Here in the US, Toyota specs a 5w30 for that engine. I would use a high mileage 5w30 at 5k intervals. If you only have 15w40, thats lighter than the 20w50 you have been running. I averaged 35 MPG and had a few 37's on my previous 2001 Corolla with the 5w30. Most of these engine burn some oil just FYI.
2016 Nissan Versa S 1.6L
2018 Subaru Outback 2.5i
2019 Ford F250 6.7L CCSB
Re: Should I extend my oil change intervals? [Re: danez_yoda] #4557680
10/28/17 08:08 PM
10/28/17 08:08 PM
Emanuel Offline OP
Emanuel  Offline OP
The consumption increased gradually over its life. It went up from 0.8 qts to 1 qt every 1000 miles because I went from 20w50 to 15w40.
The user manual says you can use 20w50 in the temps that my engine sees, the coldest starting temp is 68 F, there are plenty of 300k miles plus engines that have used 20w50 without engine rebuild down here in Venezuela
It doesn[t looks black, but it does look dark brown, but I have learned in this forum that dark oil can have more usable life in it, the only way to know is with an UOA, but I cant do one, it is so expensive down here.
Re: Should I extend my oil change intervals? [Re: anndel] #4557683
10/28/17 08:09 PM
10/28/17 08:09 PM
Emanuel Offline OP
Emanuel  Offline OP
Not any leaks, it might be burning, but it the smoke isnt visible
Re: Should I extend my oil change intervals? [Re: Emanuel] #4557686
10/28/17 08:10 PM
10/28/17 08:10 PM
Cajun Country, La.
BlueOvalFitter Offline
Cajun Country, La.
My son owns a 96 Corolla with 260K miles on the 1.8 engine.
About a year and a half ago my friend changed the wp, by pass hose, upper & lower hoses, crank seal, timing belt with all of the timing components, valve cover gasket & plug tube gaskets, PCV valve, all of the drive belts, and cleaned the throttle body, all for $150 labor. My son bought all of the parts online from PEP BOYS and ROCK AUTO for $380.
Before any of this was done the engine was leaking and burning almost 2 qts. of oil in 1500 miles. It was getting like 22-23 mpg highway. Afterwards it went up to the usual 32-35 mpg. Prior to all the work we changed the plugs, wires, cap & rotor, trans. fluid and filter. We also did a 4 day piston soak with a mixture of MMO & SEAFOAM. He used HM 10W40 oil prior to all of the work and now uses HM 5W30. I bet if you did some of the similar things to your engine it might help! GOOD LUCK!
Re: Should I extend my oil change intervals? [Re: Jimzz] #4557690
10/28/17 08:13 PM
10/28/17 08:13 PM
Emanuel Offline OP
Emanuel  Offline OP
The more common oils are Conventional API Sl rated and Synth Blend SM Rated, there is a 5w40 SN Rated but I am scared to use it because it isnt high mileage oil and because I have seen an increse with oil consumption going from 20w50 to 15w40, so I think that with 5w40 it is going to be worst.
Could I be wrong? Can 5w40 Group 3 Synth SN rated lower my consumption if 15w40 increased it coming from a 20w50?
Re: Should I extend my oil change intervals? [Re: Emanuel] #4557695
10/28/17 08:17 PM
10/28/17 08:17 PM
ON, Canada eh?
StevieC Offline
StevieC  Offline
ON, Canada eh?
If it't using that much oil I would just keep topping off and not change the oil. Just change the filter every 10,000km or so. I had a 1986 Dodge Caravan that had a Mitsubishi engine that would burn the same amount of oil due to bad valve seals and that is what I did with it. Worked fine.
'18 Dodge Grand Caravan GT - 25k KM - AMSOIL SS 0w20
Fear 20wt oils if you want your engine to last. smirk2
Re: Should I extend my oil change intervals? [Re: WobblyElvis] #4557698
10/28/17 08:19 PM
10/28/17 08:19 PM
Emanuel Offline OP
Emanuel  Offline OP
Great idea! I am going to cut open the current oil filter to look for carbon in the media pleats.
The engine was overhauled with new piston, rings, gasket, seals and bearings 35k miles ago but the cylinders werent chechek in a machine shop, they might be out of round and thats whats causing the oil consumption.
I want help to decide an reasonable OCI in this conditions using whats avaible here: Conventional API SL oil or API SN Synthetic Oil.
Page 1 of 3 1 2 3
