Thoughts on this truck and price.
by ls1mike. 09/18/18 08:39 AM
Canadian Tire Lucas Synthetic Motorcycle Oil 20w50
by Snagglefoot. 09/18/18 07:58 AM
Blast from my past
by 53' Stude. 09/18/18 07:25 AM
Happy Birthday USAF!
by Astro14. 09/18/18 06:35 AM
Ever had a total engine failure?
by Exhaustgases. 09/18/18 02:58 AM
What is the take rate for AWD in small crossovers?
by slacktide_bitog. 09/17/18 11:12 PM
W10 driver for laptop HD4500 graphics
by asand1. 09/17/18 10:03 PM
Horizontal bladder type water tank freezing?
by WobblyElvis. 09/17/18 10:01 PM
Looking for a new carburetor for 2002 honda 90cc
by KeithCoates. 09/17/18 09:57 PM
2013 Passat fluid change
by Chuckh. 09/17/18 09:25 PM
Android Auto Recommendation
by JeffKeryk. 09/17/18 08:57 PM
Prestone Full Synthetic Power Steering Fluid
by TheLawnRanger. 09/17/18 08:55 PM
MAG1 website is excellent
by wemay. 09/17/18 08:46 PM
Does anyone know of a good free 2D cad program
by JimPghPA. 09/17/18 07:42 PM
AC DELCO PF 63E CUT OPEN
by 53' Stude. 09/17/18 06:36 PM
Last time you purchased new vehicle.
by littleant. 09/17/18 05:31 PM
$100 USD Of Gasoline
by GrtArtiste. 09/17/18 03:30 PM
Odd matchbook cover
by skyactiv. 09/17/18 03:29 PM
What are these on my snowblower?
by LeakySeals. 09/17/18 03:12 PM
tomkat22, tabar2004, SierraMan, Rennmeister, KeithCoates
66004 Registered Users
78 registered members (94astro, Ablebody, 97 GTP, 2004tdigls, ARB1977, ARCOgraphite, 7 invisible), 1,116 guests, and 36 spiders.
Topics290,582
Posts4,846,863
Members66,004
Most Online3,590
Jan 24th, 2017
Thinner Oil provides better Oil Seal #4557436
10/28/17 04:30 PM
10/28/17 04:30 PM
Venezuela, South America
Emanuel Offline OP
Emanuel  Offline OP
I browsing on this forum and I found this article: Thinner oil provides better oil seal where an User called autoreign said this:
Quote:
The article seem suggest that the oil flow on the piston rings pack is more likely to flow through the gap on each piston ring to get to the top ring. Hence, lower viscosity oil, being able to flow better, will provide a thicker oil film at bottom of the Top ring,
Do you really think that a thinner viscosity oil could make a better seal in the piston rings? I thought that a higher viscosity oil would be better for sealing because the general recommendation when a engine starts to use oil is to switch to a higher viscosity oil and in fact I have noticed 37% more oil consumption in my car with 15w40 than with 20w50 (maybe the oil viscosity isn't the one increasing my consumption but other factors)
I really don't want to talk about my car's oil consumption in this post, what I would like to know if you have noticed lower oil consumption with thinner oils. Or if there is another factor in oil selection that can lower oil consumption like HTHS, VI, base oil quality, NOACK, etc.
Re: Thinner Oil provides better Oil Seal [Re: Emanuel] #4557517
10/28/17 06:02 PM
10/28/17 06:02 PM
Fort Worth TX
TheKracken Offline
TheKracken  Offline
Fort Worth TX
My 281k mile sienna doesn't use any oil when I ran it on 0w20. I switched to a heavier oil this last change and it doesn't use much oil either but it is noticeably more sluggish and oil temps are hotter. I plan to switch back soon.
2011 Prius 96k miles RLI 5w20
97 Toy T100 4x4: amsoil 0w20 242k Miles
04 Toy Sienna awd: Pennzoil 0w20 281k Miles
Re: Thinner Oil provides better Oil Seal [Re: Emanuel] #4557555
10/28/17 06:38 PM
10/28/17 06:38 PM
New Zealand
Silk Offline
Silk  Offline
New Zealand
Oil burning is caused by oil being pumped up the ring lands, and needs worn ring grooves to pump more oil, a thicker oil would help here. Blocked drain holes, gummed rings will burn oil too. Those on this site will say thinner oil will stop oil burning - I have never seen a thinner oil reduce oil consumption, but thicker usually will. If it's the same car you've been talking about, you cooked it and the rings have lost tension.
1987 BMW R65 - Penrite V Twin 20/50
2005 Nissan Expert - Gulf Western 10W-40
1996 Volvo T5 - Penrite HPR15 - 15W-60. Ryco syntec filter.
Re: Thinner Oil provides better Oil Seal [Re: Silk] #4557684
10/28/17 08:09 PM
10/28/17 08:09 PM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Yeah, it's funny how the need to justify the OEM's push for thinner oils includes reduced oil consumption (and improved wear) as the "reason"...thinner just HAS to be better, because it's the U.S.
Which market stated that 1qt/1,000 miles was acceptable oil consumption ?
Re: Thinner Oil provides better Oil Seal [Re: Shannow] #4557739
10/28/17 08:47 PM
10/28/17 08:47 PM
Texas, Mentone for work, Galve...
Bryanccfshr Offline
Bryanccfshr  Offline
I have owned 4Toyota’s with 1gr fe since the 0w20 became the thing in the USA, I am well aware of the broader viscosity ranges recommended outside the USA.
I think about trying an hdeo 5w30from time to time but the 0w20has never been consumed and never gave me a evidence based reason to not use it.
2018 Trd Pro 4Runner M1 0w40
2018 Tacoma off-road Castrol 5w30 Magnatec
Re: Thinner Oil provides better Oil Seal [Re: Silk] #4557741
10/28/17 08:47 PM
10/28/17 08:47 PM
Emanuel Offline OP
Emanuel  Offline OP
The engine was overhauled 35k miles ago with new pistons, rings, gaskets, seals and bearings. It overheated pretty bad 12k miles ago, it burned 1.5 qt every 1k miles before the overheat and after the overheat 2.5 qt every 1k miles. My guess is that the cylinders arent perfectly round because of the wear.
Do you think that 35lk miles old rings could be cooked up?
Re: Thinner Oil provides better Oil Seal [Re: Emanuel] #4557742
10/28/17 08:49 PM
10/28/17 08:49 PM
Wet side WA
JohnnyJohnson Offline
Wet side WA
Emanuel I think its time to drive a newer car under your oil can so to speak.
2004 Corolla 124642
Out: VML 5w-30 TG4967 OCI 5007 Miles
In: EDGE EP 5W-30 Bosch 3311 122537 7-18-18
2006 Duramax 74277
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 74705 4-22-18
Re: Thinner Oil provides better Oil Seal [Re: JohnnyJohnson] #4557744
10/28/17 08:52 PM
10/28/17 08:52 PM
Emanuel Offline OP
Emanuel  Offline OP
Emanuel I think its time to drive a newer car under you oil can so to speak.
I live in Venezuela, we have 1200% accumulated inflation from the start of the year until now
Re: Thinner Oil provides better Oil Seal [Re: Emanuel] #4557752
10/28/17 08:57 PM
10/28/17 08:57 PM
New Zealand
Silk Offline
Silk  Offline
New Zealand
By cooked I mean overheated - I doubt apart from a seizure anything has happened to new pistons in 35,000km.
Re: Thinner Oil provides better Oil Seal [Re: Emanuel] #4557753
10/28/17 08:57 PM
10/28/17 08:57 PM
Bryanccfshr Offline
Bryanccfshr  Offline
In your situation I would simply run a hdeo for now, fuel,quality etc may be questionable and it is best to use traditional ways of preservation for longevity. That means a heavy duty engine oil changes more frequently with a focus on preventing overheats, and other damaging events.. I would spend more 9n your cooling system than lubrication until you have a more stable socio economic situation.
Re: Thinner Oil provides better Oil Seal [Re: Bryanccfshr] #4557767
10/28/17 09:06 PM
10/28/17 09:06 PM
Emanuel Offline OP
Emanuel  Offline OP
The overheat was caused because of a faulty radiator cap, I have the cooling system in optimal condition now.
So should I keep changing the oil every 3k miles or should I extend the interval?
Re: Thinner Oil provides better Oil Seal [Re: Silk] #4557768
10/28/17 09:07 PM
10/28/17 09:07 PM
Emanuel Offline OP
Emanuel  Offline OP
35k miles = 50k km
Re: Thinner Oil provides better Oil Seal [Re: Emanuel] #4557772
10/28/17 09:10 PM
10/28/17 09:10 PM
Emanuel Offline OP
Emanuel  Offline OP
Engine oil price has increased 2700% from March until now, so don't want to waste oil but I don't want to neglect the engine neither.
Do you think that a 4k miles interval would be safe? Or could I change the oil every 5k miles?
Re: Thinner Oil provides better Oil Seal [Re: Emanuel] #4557783
10/28/17 09:18 PM
10/28/17 09:18 PM
Bryanccfshr Offline
Bryanccfshr  Offline
The interval is very dependent on your service conditions, fuel quality and engines mechanical condition.
I run 5w20in a Ford F-150 4.6v8 in dusty oilfiledmservice with a lot of idling, rough roads and minimal usa fuel standards. It has 100k. it and is running clean and strong and does not consume a noticableamou t between oil changes. I run this on 5k mile or 6month intervals. I think this is a safe distance and time for any modern fuel injected engine with a modern engine oil.
Re: Thinner Oil provides better Oil Seal [Re: Emanuel] #4557791
10/28/17 09:22 PM
10/28/17 09:22 PM
Bryanccfshr Offline
Bryanccfshr  Offline
I don’t know what engine family or make you have but I really would lean to a (5w30or 10w30 mixed fleet hdeo for combine potential availability and detergency if you have to extend for unforeseen circumstances.
