PEAK Full Synthetic -- Anyone Try It ??
by johnnyz73
06/18/18 07:40 PM
Why high resale value on Jeeps if frames rust out?
by Vern_in_IL
06/18/18 06:48 PM
Wearever Silver Semi-Metallic Brake Pads- Break In
by ET16
06/18/18 06:37 PM
Where to Buy Motul Oil in Stores?
by Hot_Ajax
06/18/18 06:13 PM
2011 Chevy equinox overheating
by hardcore302
06/18/18 06:00 PM
Are my rotors warped?
by Dylan1303
06/18/18 05:44 PM
Ultimate Fast Finish on sale at CDN tire.
by irv
06/18/18 05:23 PM
96 Civic 5w20 Castrol GTX Ultraclean UOA
by researcher
06/18/18 04:52 PM
VOA Castrol Magnatec D1G2, 5w30
by researcher
06/18/18 04:38 PM
Unused dented silicone Fram PH8316 cut open
by slacktide_bitog
06/18/18 04:28 PM
Bring back Merkava_4
by mjoekingz28
06/18/18 04:28 PM
Same grade with differing low start temps
by mjoekingz28
06/18/18 04:24 PM
Self defense
by Camprunner
06/18/18 03:13 PM
Any apple experts here?
by maverickfhs
06/18/18 02:50 PM
Cost-no-object 75W-90 GL-5 for a differential?
by d00df00d
06/18/18 02:34 PM
Pittsburgh Dad, this guy is a trip
by Rat407
06/18/18 02:06 PM
14 Jeep GC 5.7, PP 5w20 & 0w20
by Vigg
06/18/18 01:52 PM
Sell me on a SSD drive...........
by ZZman
06/18/18 01:07 PM
need some ideas on my issue
by matrass
06/18/18 12:36 PM
Put Pennzoil Platinum Euro L in a Honda.
by dunlop0078
06/18/18 12:36 PM
3horseman, Firedog45, WtsTacoma01, Orion62, Revd
65264 Registered Users
85 registered (2015_PSD, ARB1977, 08z06, 4WD, Audios, Astro14, 8 invisible), 1670 Guests and 46 Spiders online.
65264 Members
67 Forums
285539 Topics
#4557427 - 10/28/17 04:21 PM Evap sytem basic operation?
Rolomoto Offline
Loc: PA
From what I understand, the evap system works when refueling and when the car is running.
When refueling the excess air in the tank is forced through the charcoal canister, scrubbed and clean air is released through the air drain. When running, vapors in the tank are sucked into the canister and purged to the engine. My question is, if the vapors pass through the canister wouldn’t it be clean air (non-combustible) that is being purged to the engine?
Thanks for any clarification!
2011 Toyota Camry
2001 Toyota Echo
1995 Toyota Tercel
#4557434 - 10/28/17 04:27 PM Re: Evap sytem basic operation? [Re: Rolomoto]
redbone3 Offline
Loc: Reno, NV
I don't think the system works during refueling. The pipe from the gas tank is too small for that. Plus, a purge valve has to be turned on, which isn't going to happen when the car is turned off.
2014 Passat Wolfsburg, 1995 Miata.
#4557469 - 10/28/17 05:13 PM Re: Evap sytem basic operation? [Re: Rolomoto]
mk378 Offline
Loc: USA
It is mostly air that comes out of the canister while purging. It adds to the air the engine needs from the air cleaner. Any gasoline (hydrocarbon) vapors present should get burned in the engine though.
#4557565 - 10/28/17 06:44 PM Re: Evap sytem basic operation? [Re: Rolomoto]
eljefino Online   content
Loc: ME
When you park the tank is sealed. In the old days there was a vent to atmosphere. Now that vent goes to the charcoal canister which soaks it up. To dry out the charcoal the valves open under cruise and a trickle of air flows through the charcoal. Its dirty, VOC-laden air goes off to the combustion chamber.
OBD-II systems pressurize or depressurize the gas tank and EVAP lines to ensure they hold up. If you hear a whoosh when you open your gas cap things are good n' tight!
The gas cap has a vent, too, but it's designed to hold tighter than the EVAP one, so it's a fail-safe.
#4557816 - 10/28/17 09:48 PM Re: Evap sytem basic operation? [Re: Rolomoto]
JTK Offline
Loc: Buffalo, NY
There is typically a little filter element where fresh air is drawn in for the EVAP canister. Any other air can be drawn in through the check valve in your gas cap. The cap should allow air in, but not air out (easily).
A lot of late model EVAP system, such as those on Subarus have a pump that will run a diagnostic pressure test of the system at certain intervals, after the vehicle has been used, but then has sat a few minutes. Kind of startles you when you hear it whirring like you left something on or the fuel pump is still running.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
#4558847 - 10/29/17 10:02 PM Re: Evap sytem basic operation? [Re: Rolomoto]
NYEngineer Offline
Loc: NY, NY
On my 2009 Suburban, some solenoid failed closed and it wouldn't vent the tank
It also made it difficult to get gas
I replaced it with the new, improved part and it has been working perfectly for about seven years now
I had to drive with the cap cracked loose before I repaired it
