Patman
Staff member
Here are the latest results from my wife's BMW, analysis done by Wearcheck Canada:
4,358 miles on oil
June 24 to Oct 21 (4 months)
93,000 miles on engine
Mobil 1 0w40 FS
Mann oil filter
7 quart oil capacity
No make up oil
Iron 13
Lead 0
Aluminum 4.5
Copper 6
Chromium 0.2
Nickel 0
Tin 0.3
Silver 0
Vanadium 0
Silicon 13
Potassium 3.2
Sodium 2.4
Sulfur 2075
Moly 74
Boron 153
Titanium 0
Calcium 3192
Magnesium 82
Manganese 1.7
Antimony 1.8
Barium 0
Lithium 0
Beryllium 0
Cadmium 0
Phosphorus 911
Zinc 1088
Oxidation 177%
Nitration 82%
Sulfation 115%
Soot 0
Glycol 0
Water 0
Fuel 0
Viscosity at 100c 12.7
This is my first interval with the new thinner "FS" formula of M1, and I've also noticed that compared to the old formula, boron is a lot higher, magnesium is a lot lower and calcium/phosphorus/zinc are all slightly higher. Moly is about the same.
I wanted to do a much shorter than usual interval to clean things up a bit, as I feel I overextended the intervals with this car a few times in a row. I was also anxious to see the results of this different formula. Oxidation is still very high but Wearcheck explained that they can't get an accurate reading on it with some synthetic oils. I probably won't even bother reporting oxidation on here anymore actually.
4,358 miles on oil
Mobil 1 0w40 FS
Mann oil filter
No make up oil
Iron 13
Lead 0
Aluminum 4.5
Copper 6
Chromium 0.2
Nickel 0
Tin 0.3
Silver 0
Vanadium 0
Silicon 13
Potassium 3.2
Sodium 2.4
Sulfur 2075
Moly 74
Boron 153
Titanium 0
Calcium 3192
Magnesium 82
Manganese 1.7
Antimony 1.8
Barium 0
Lithium 0
Beryllium 0
Cadmium 0
Phosphorus 911
Zinc 1088
Oxidation 177%
Nitration 82%
Sulfation 115%
Soot 0
Glycol 0
Water 0
Fuel 0
