Tesla Crushing It
by JeffKeryk - 04/03/20 08:42 PM
Pacific Valley in Big Sur with the E46
by SLO_Town - 04/03/20 08:33 PM
I drove a Delta pilot to the airport today
by 14Accent - 04/03/20 07:41 PM
ALUMINUM BLACK™ metal finish touch-up pen
by vavavroom - 04/03/20 07:28 PM
Strut leak
by ford46guy - 04/03/20 06:30 PM
Orifice tube backwards, now can’t reach it
by gallydif - 04/03/20 06:14 PM
Bone creeper?
by JHZR2 - 04/03/20 05:58 PM
Wrangler TJ Engine Oil
by TJim - 04/03/20 04:53 PM
Virgin XG3600 cut open
by bullwinkle - 04/03/20 04:30 PM
Windows Update and Shutdown update confusion
by simple_gifts - 04/03/20 04:29 PM
Mildew Smell in AC System
by painfx - 04/03/20 04:17 PM
M1-113A CUT OPEN
by 53' Stude - 04/03/20 03:56 PM
MC FL500S 7,000 miles CUT OPEN
by 53' Stude - 04/03/20 03:43 PM
USS Theodore Roosevelt
by BMWTurboDzl - 04/03/20 03:42 PM
2020 Subaru Forester Base
by wagsrk08 - 04/03/20 03:41 PM
New Rislone Hy-per Fuel Product?
by Jackson_Slugger - 04/03/20 03:38 PM
Rislone New Gas Hy-per Cleaner Rebate
by Jackson_Slugger - 04/03/20 03:33 PM
2003 GM 6.0 LQ4 Oil Pan/Rear Main Leak, which oil
by apollo18 - 04/03/20 03:15 PM
FRAM Extra Guard PH16 CUT OPEN
by 53' Stude - 04/03/20 03:11 PM
CARQUEST R 84502 CUT OPEN 4,600 MILES
by 53' Stude - 04/03/20 02:58 PM
Peacock, Agauth12, PatGN, Fjordman95, TJim
71086 Registered Users
101 registered members (Alaskanmont, ArrestMeRedZ, AlienBug, aquariuscsm, asiancivicmaniac, Astro14, 8 invisible), 2,132 guests, and 19 spiders.
Topics303,549
Posts5,237,276
Members71,086
KIA Power Steering fluid - PSF-3 - Equivalent? #4555969 10/27/17 07:40 AM
J
JGmazda Offline OP
J
My 2008 KIA Sportage calls for PSF-3 (PSF-111) Power Steering Fluid.
Apparenty, this specification isn't used anymore and I want to make sure I use an equivalent fluid when I change it out.
Is there any PSF out there that meets this? The only fluid I've found was this:
Lubeguard - http://www.lubegard.com/~/C-1041/LUBEGARD+COMPLETE+Synthetic+Power+Steering+Fluid
2008 KIA Sportage
Re: KIA Power Steering fluid - PSF-3 - Equivalent? [Re: JGmazda] #4555970 10/27/17 07:44 AM
J
JGmazda Offline OP
J
2008 KIA Sportage
Re: KIA Power Steering fluid - PSF-3 - Equivalent? [Re: JGmazda] #4556026 10/27/17 08:47 AM
Sayjac Offline
In truth the LubeGard PSF shown doesn't state that it 'meets' any spec. Like most multivehicle products, it uses "suitable for" to describe it's use. Doesn't mean not a good/quality PSF, in fact being a synthetic PSF and Lubegard, likely a quality product. Not sure about the cost though.
Doing just a little googling it seems PSFIII equivalent to Dexron II/III ATF. 'If' true an easy spec to meet with ATF, including the Multivehicle Synthetic ATFs like MaxLife. My advice, google Kia PSF III equivalents, and go to some of the Hyun/Kia vehicle specific forums and see what the folks are using. Most I see using a Dex III 'or better' ATF equivalent, some MultiVehicle ATF products. And the LubeGard 'suitable for' listings would 'seem' to confirm information.
Re: KIA Power Steering fluid - PSF-3 - Equivalent? [Re: JGmazda] #4556053 10/27/17 09:21 AM
J
Jimzz Offline
J
I use transmission fluid in the power steeping systems for Kias/Hyundai's. I think mostly Valvoline Maxlife and Havoline syn transmission fluid.
yup
Re: KIA Power Steering fluid - PSF-3 - Equivalent? [Re: JGmazda] #4556095 10/27/17 09:59 AM
SHOZ Offline
I went with a qt of Prestone from Walmart in my Accent last year.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: KIA Power Steering fluid - PSF-3 - Equivalent? [Re: Sayjac] #4556151 10/27/17 10:41 AM
J
JGmazda Offline OP
J
Thank you. I did some searching and found this to be the case. Not 100% sure I feel confident about using ATF in a PS system, but I guess that's what the KIA fluid "was" at some point. Not much on the KIA forums regarding this question. Most have advised as you have.
2008 KIA Sportage
Re: KIA Power Steering fluid - PSF-3 - Equivalent? [Re: JGmazda] #4556179 10/27/17 11:10 AM
Sayjac Offline
Yeah, I get it. As comparison I have an 01 Tacoma and it calls for DexII/III ATF, but they don't use any coded name for the product like PSF-3, just straight out says the ATF spec. As noted, lots of good reasonably priced ATFs easily meet the Dex II/III spec.
And one anecdote on this thread supporting the ATF conclusion.
Re: KIA Power Steering fluid - PSF-3 - Equivalent? [Re: JGmazda] #4556201 10/27/17 11:39 AM
B
boom10ful Offline
B
I've used Maxlife Atf in my '03 Hyundai Santa Fe. Runs great with no noise. The one think that I will add is that I feel that it is thinner as it caused the power steering hoses to leak and the rack to leak. But I don't think that was the fluids fault as my car has a history of leaking hoses and the rack boots were torn up for a while when I got it.
2003 Hyundai Santa Fe (RIP) 148K
2016 Hyundai Sonata Hybrid 86K
Re: KIA Power Steering fluid - PSF-3 - Equivalent? [Re: JGmazda] #4556203 10/27/17 11:42 AM
K
knerml Offline
K
RAVENOL J1B1031 Power Steering Fluid - PSF is Hyundia/Kia PSF-3
2015 Hyundai Elantra Sport 2.0 GDI Mobil 1 5W30 & OEM Filter
2018 Hyundai Santa Fe Sport AWD 2.0T Mobil 1 5W30 & OEM Filter
Re: KIA Power Steering fluid - PSF-3 - Equivalent? [Re: JGmazda] #4556213 10/27/17 11:53 AM
J
JGmazda Offline OP
J
- Good to know! Thanks for your help!
- Thanks for your help
- Thanks for this!
2008 KIA Sportage
Re: KIA Power Steering fluid - PSF-3 - Equivalent? [Re: JGmazda] #4556259 10/27/17 12:38 PM
StevieC Offline
My Mom's Kia spectra required this and she used the Diamond SP-III ATF fluid and it worked fine. I used Amsoil Power Steering Fluid in my Hyundai Santa Fe and now in my Dodge Journey.
Just for some other options! thumbsup
'18 Caravan - 50k KM - AMSOIL SS 0w20, Fram Ultra, TC-W3 500:1
'06 Santa Fe - 535k KM (Retired)
There is no such thing as "lifetime" fluids! mad
Re: KIA Power Steering fluid - PSF-3 - Equivalent? [Re: JGmazda] #4556330 10/27/17 02:32 PM
E
Eddie Online Sleepy
Online Sleepy
E
I would go to a KIA dealer and talk to a mechanic. Ed
2014 CX5 Touring 2.5L :-)
Re: KIA Power Steering fluid - PSF-3 - Equivalent? [Re: JGmazda] #4556335 10/27/17 02:37 PM
Yah-Tah-Hey Offline
Doing just a little googling it seems PSFIII equivalent to Dexron II/III ATF. 'If' true an easy spec to meet with ATF, including the Multivehicle Synthetic ATFs like MaxLife. My advice, google Kia PSF III equivalents, and go to some of the Hyun/Kia vehicle specific forums and see what the folks are using. Most I see using a Dex III 'or better' ATF equivalent, some MultiVehicle ATF products. And the LubeGard 'suitable for' listings would 'seem' to confirm information. Power steering systems are nothing more than a simple hydraulic system. Nothing Special. You could use any ISO 32 or 46 hydraulic fluid in that system without a problem. A pump, a reservoir, hoses and a cylinder. Sometimes a cooler.
Re: KIA Power Steering fluid - PSF-3 - Equivalent? [Re: JGmazda] #4556378 10/27/17 03:18 PM
StevieC Offline
Call the "Parts Department" at your local Kia dealership I bet they will tell you to use ATF. The Hyundai dealers do. (Kia's parent company)
Re: KIA Power Steering fluid - PSF-3 - Equivalent? [Re: JGmazda] #4557340 10/28/17 02:46 PM
J
JTK Offline
J
I recall my 2008 Hyundai Santa Fe calling for Hyundai/Kia PSF-4 which was impossible to find aftermarket. I think it was the one fluid I didn't swap out on that vehicle. Hope the current owner appreciates it whomever that may be!
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
